#1301 |
![]() Join Date: Jul 2012
Re: 48 Burb, bagged, 5.3, 20 year wait
More floor and I did gusset under the engine mount for additional strength. The crossmember notch weld is still on the to do list.
#1302 |
Strapped the fuel tank in to begin running the fuel fill. The 90 degree elbow was just too tall even cutting it down as far as possible. I didn't want to trim any additional as there would be little for the hose clamp to clamp too.
#1303 |
![]() ![]() Join Date: May 2015
Floor looks good Doug...I like the peanut gallery in your shop...nothing like spectators...
#1304 |
I asked dwcsr...Dave Hollister Road Company...if a rubber 90 degree would work here. Yes was his quick email response...thanks Dave...and my local NAPA could have it next day.
Here you can see how much I trimmed the steel 90 down. I didn't start trimming on the hose yet....hopefully it will work out. If not, I am thinking I will fab a 90 degree in the size needed to fit. |
#1305 |
So I put that fuel fill on pause a bit as I wanted to install the Camaro pan on the engine, then get the powertrain installed in frame again for figuring out the steering.
Yeah, I forgot the Camaro pan was used and I hadn't cleaned it up yet. |
#1306 |
Is that a fuel grade rubber 90?
#1307 |
A few hours in the parts washer cleaned it up pretty well.
#1308 |
For the first time I dropped the truck pan to see what it looked like inside.
#1309 |
Found a little surface rust in one of the cylinders. It should clean up pretty easy and hopefully I can get back on it Sunday afternoon.
Hey Mongo, yes that is fuel fill hose and was a bit spendy. A good peanut gallery is always fun...though we don't get many visitors out here. Hope to pick my progress up a bunch this winter! Marc is going to pull way ahead of me in our Burb building competition and I need to get back in the swing of things... |
#1310 |
Yeah I had to buy some of that fuel filler hose for my ls swap..talk about sticker shock...
#1311 |
![]() Join Date: Mar 2007
Doug
The floors look good. I got back out myself and worked on welding in some floor structure myself.. I having the welder is great. I should have bought one years ago... Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1312 |
Ooops...
#1313 |
Thanks Marc, doing the fab work in these builds sure does make having a welder handy. Glad you have one now. Looking forward to see what you do for your floor.
#1314 |
When you do some things all at the same time, you need a space to rest and just look at what you have made
![]() But I see the chairs are empty, that means you were working on cars? ![]() Just joking ![]() Floors look good!! I'm sure you'll get the fuelfiller just the way you want it!! Is that motor a 350 sbc or a LS? Missed that I think....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1315 |
Thanks Kees, that is a 5.3 LS from a 2004 Chevy truck. The truck oil pan hangs below the front crossmember and the Camaro pan isn't as deep, staying about even with the crossmember.
#1316 |
Looking good Doug, did your Camaro pan come with the pickup,tube and dipstick?
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1317 | |
Oh yeah, that wagon has a new 9" rear from Quick Performance in Ames IA. Really nice set up. Here it is down at my buddy Luke's shop for some metal work around the rear side windows and lower quarters behind tires. |
#1318 |
Thats cool, Quick Performance is a really good co. to work with that's who I used for John's mustang rear diff.
Mark...
#1319 |
A few more updates like this and you will pull into the lead.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1320 |
looks cozy in there. making me second guess jumping back into my cold dungeon this year!!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1321 |
Yeah Mark, I believe the next time I need a complete rear I will give them the business. Reasonable prices and quality parts for sure.
I don't know Lowers...I need a bunch of updates like this. Winter with no yard work will help....I hope. 99, that spot is right under the radiant heater and is very cozy...zzzz... I was able to pull myself away from the peanuts and cozy spot long enough to throw the now clean Camaro pan on the engine. There is still more work to be done in prepping this engine for paint. Any slick ideas for removing the last of the engines dirt and corrosion? I plan to continue with Dremel, wire wheels, die grinder with rotary brush, simple green cleaner....lotta elbow grease. |
#1322 |
Cleaning a dirty LS1 brings back some memories..
It's getting there... Marc
#1323 |
SUPER CLEAN my man....works a ton better than simple green.
Just my own experience. Mark...
#1324 |
#1325 |
And before you know it,it will look like this!!!
Of course after Hrs of taping,painting,more tape and more paint...oh and then assembly ![]() Mark...
