Old 12-05-2016, 05:39 PM   #1
forestb
forestb's Avatar
striped th350 pan bolt holes
On my th350 one of the two bolt holes for the pan that are closest to the bell housing are stripped. Is it possible to put a nut on the other end like you are able to do with the rest of the bolts?
forestb is offline   Reply With Quote
Old 12-06-2016, 12:43 PM   #2
DieselSJ
Re: striped th350 pan bolt holes
Helicoil or nut-sert.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 12-06-2016, 02:28 PM   #3
forestb
forestb's Avatar
Thanks for your reply and I will probably do it if I can not put a bolt on the other end. With that said the question still stands. Is it possible to get any nuts inside there?
Old 12-06-2016, 11:13 PM   #4
cadillac_al
I would probably just tap it out to the next size, which might be metric, and have one odd ball bolt in my tranny.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-07-2016, 02:00 PM   #5
storm9c1
*** That's interesting ***
storm9c1's Avatar
I've done that before. Just borrow the gf/wife's red nail polish and put a dot on the bolt and on the pan to remind you it goes there so you don't accidentally force it into another hole and strip it next time.
Helicoil is the other option, which works well and is easy to install on aluminum. Just remember to break off the tab before installing the bolt.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 12-07-2016, 02:09 PM   #6
forestb
forestb's Avatar
So from what I am hearing you all don't think that I would be able to put a nut on the other side?
Old 12-07-2016, 02:41 PM   #7
MikeB
MikeB's Avatar
Nope.
Is this one of the corner bolt holes with 5/16"-18 threads? If so, your next step up in size is 3/8". But either way, you may not have room to drill and tap.
Metric probably won't work here because 8mm is only .050" larger than 5/16", and 10mm is larger than even 3/8".
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-07-2016, 03:24 PM   #8
forestb
forestb's Avatar
Originally Posted by MikeB View Post
Nope.
They are not the corner bolts they are the 2 center bolts bolts at the front of the pan that are closest to the torque converter cover. They are 5/16ths.
Old 12-07-2016, 03:25 PM   #9
forestb
forestb's Avatar
Does the nope mean you think I can put nuts on the other side or that I can not?
Nope.
Old 12-07-2016, 03:56 PM   #10
MikeB
MikeB's Avatar
No you cannot. Those are blind holes.
Mike
Old 12-07-2016, 04:16 PM   #11
forestb
forestb's Avatar
I'm sorry I go the feeling that you misread my post when you asked about the corner bolts. I am talking about the pan on a 350 transmission.
Old 12-07-2016, 07:41 PM   #12
forestb
forestb's Avatar
So it is a 5/16ths bolt. Should I use a 5/16ths drill bit and a 3/8 -16 tap to make a new hole?
It looks as though if I take off the fly wheel cover I can get to the other end of those holes but I am worried whether or not I will have room between the fly wheel and the nuts.
Old 12-12-2016, 12:21 PM   #13
forestb
forestb's Avatar
Well I ended up using the Helicoil and they worked awesome. Thanks for all the help. I am just glad that the two bolts that are next to the tail shaft are not stripped.
