12-05-2016, 07:52 PM | #1176 |
Re: My 57 Pro Street
Can't wait to you get better and get back to your truck! Wish you the best
I pity the fool with only 2 headlights! |
12-05-2016, 08:17 PM | #1177 | |
Kim |
12-05-2016, 08:19 PM | #1178 | |
I need to down load some pics of the progress. Kim |
12-06-2016, 03:52 PM | #1179 |
Finally was able to get some things done on the truck.
I needed to fab a trans cover so this is what i came up with. Pic #1 shows a frame work i came up with. #2 Lay out of the bends to be made. #3 As I don't have a brake I cut 1" slits an inch apart. #4 and #5 Clamped it to my bench and made the bends. Worked out pretty good. Kim |
12-06-2016, 03:57 PM | #1180 |
More of trans cover.
#1 and #2Tacked to my frame. #3 A frame that is welded to the truck floor with holes that I tapped so I can remove the cover (probably will never happen). #4 and #5 Sitting in place. Welded my slits up so it looks a little better. I'm using 1/4x20 button head screws to attach it. Kim |
12-06-2016, 04:02 PM | #1181 |
Was also able to get the cab very close to being put on the frame.
I just need to figure what color I want the fire wall to bve. Probably go with gloss black as I'm not ready to purchase the paint for the entire truck yet. Still need to do a final sanding and seal on it. Kim |
12-06-2016, 04:04 PM | #1182 |
hey, nice job Kim. I like your bench mounted sheet metal break, it seems to work good.
it's -22C here this morning. not much gettin done these days. |
12-06-2016, 04:04 PM | #1183 |
And a few of the dash.
Not perfect but pretty good as I'm no body man. Kim |
12-06-2016, 04:07 PM | #1184 |
now that's smooth. lots of guys are installing a guage cluster these days though, haha.
bodywork looks great. are you full on now or starting back slow? don't wanna overdue it and end up on the couch again. |
12-06-2016, 04:21 PM | #1185 |
The cab looks really straight, inside and out!
I like the transcover, suits the cab good, just as smooth. Glad seeing updates again Kim!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-06-2016, 04:21 PM | #1186 |
NICE, NICE, NICE !!! This is what we been waiting for glad to see you back.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
12-06-2016, 04:48 PM | #1187 |
Certified Car Nut
Everything looks great. Really nice work there
12-06-2016, 06:11 PM | #1188 |
Really nice work Kim and good to see you back at it, Love the smoothed out dash too, really different.
12-06-2016, 06:19 PM | #1189 |
Thanks for the compliments guys.
Not over doing it for now. Try to get in an hour or two as time and my body permits. Kim |
12-06-2016, 07:17 PM | #1190 |
it is coming along nice. that is how it gets done, an hour at a time. if you're lucky you don't have to put it all away in between the work times. that is half my problem. it takes me more time to dig it out and get started and then clean up after working than the time I get to work on it. right now I am just looking at it because of the shoulder surgery.
an hour a ta time and you'll be driving it soon. |
12-06-2016, 08:10 PM | #1191 |
Kim, nice work and I really like the detail for the transmission cover. That gives me ideas for mine. Thanks for sharing.
12-06-2016, 08:20 PM | #1192 | ||
Leaves my DD out but the wife gats her car inside. Hope your shoulder heals quickly.. Quote:
Kim |
12-06-2016, 08:48 PM | #1193 |
Kim, nice job on everything, looks super. Been years since I've seen a VW fastback (background), looks to be in great shape...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-07-2016, 12:31 AM | #1194 |
Good to hear your slowly getting back at it. Trans cover turned out really good, cab looks nice so far. You could always paint the fire wall dark gray? Something a bit different than black.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
12-07-2016, 08:50 AM | #1195 | ||
It fits his gear better than a bug. He plays guitars and has a real gift for the base. Quote:
Kim |
12-07-2016, 10:26 AM | #1196 |
Very Slick looking Kim.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-07-2016, 02:24 PM | #1197 |
Man, everything looks great, Kim! If you're, "not a body man" you're doing a helluva good impression of one, ha ha.
What will you use for gauges on your dash? I thought long & hard about smoothing my dash but leaving the hump instead of the '55 car dash. In fact I almost went with it when the first deal I found on a car dash fell through. Really looking forward to how you finish it. Maybe I missed it - do you have a final color in mind? I ask because with all the nice custom work you're doing it would be nice to have your firewall and inner fenders match the outside - but that's just my opinion and you know what those are worth, ha ha!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
12-07-2016, 02:27 PM | #1198 | |
If you want to get fancy and since your firewall is flat a cool idea might be a big engine turned panel adhered to the surface (Man, we're good at spending other guy's money, huh?)
12-07-2016, 09:54 PM | #1200 |
Thanks guys.
Kim |
