Closed Thread
Old 12-11-2016, 10:01 PM   #4726
supercheyenne
Re: What did you do to your truck today? Chapter II
Originally Posted by matthamby View Post
installed my first "modern" accessory!
[/URL]
Details my friend!
Please and thank you.
supercheyenne is offline
Old 12-11-2016, 11:22 PM   #4727
matthamby
This is the link to the item I purchased (eBay):
12V-24V Car Vehicle Waterproof 5V 2.1A + 2.1A Dual USB Power Sockets Outlet
I had to use a "step bit", it's used to cut small holes into larger ones for conduit into electrical panels (I have used them many times) they are about $35 at Lowe's Home Improvement, make sure to get the one that is up to 1-1/8", at least that's what mine was. See if you have an electrician friend, they may have one you could use. Don't try holding a hole saw in place - it won't turn out well (for the truck or you, I have seen people try it). I have several vehicles that I want to add one of the sockets to, so the $35 wasn't a bad deal.
I took a round file to remove the barbs that remained from the bit. It was a really tight fit so it doesn't move around inside the hole, I just got it in there, I started to hook up the wires, but when I started looking at the wiring, it was quite obvious that whoever installed the radio (non factory, i don't think a dealer did it either), there was a nest of wires, a lot of them were cut and hanging loose, so I need to chase them out and see what goes where and remove wires that are not necessary. Nothing can ever be easy!
You may be able to use a small grinding wheel on a Dremel tool to make the hole larger, mark the hole needed then cut, this would also allow you to leave the sides flat so the power adapter is "keyed" into the hole.
After that you just simply connect the old cigarette wires to the back using the supplied crimp connectors.
That's about all I know that you would need. I hope it helps!
Thanks guys!
matthamby is offline
Old 12-12-2016, 12:07 AM   #4728
toolboxchev
Originally Posted by mild68 View Post
Put a little more time today detailing parts.
Got the power steering pump pulley back on.
Disassembled and detailed alternator.
Heat with Torch, Spray with hose, repeat...Spray with PB Blaster, let sit overnight...repeat until it breaks free.
This has not failed me yet. The different metals with expand and contract at different rates breaking the corrosion bond. You do not need much torque. It will break free when the bond is broken.
toolboxchev is offline
Old 12-12-2016, 12:36 AM   #4729
supercheyenne
Thanks guys!
You are the man. With everyone having smart phones nowadays you can never have too many outlets for charging.
I appreciate it.
Old 12-12-2016, 10:17 PM   #4730
74baggedbug
Shipped the hinges off to be rebuilt and still waiting on warmer temps to apply the epoxy on the wood floor project
74baggedbug is offline
Old 12-12-2016, 10:53 PM   #4731
FRCvette
Ordered more parts to get ready to lower my 70. Should have all pieces I need to get project started. Going to do 3 and 4 inch drop and install front sway bar and adjustable track bar in rear with lowered shocks. Hope to get started soon.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline
Old 12-12-2016, 11:01 PM   #4732
Metaldoc
Metaldoc's Avatar
That is one purdy blue. It's turning out great.
Metaldoc is offline
Old 12-12-2016, 11:43 PM   #4733
74baggedbug
Thanks!!!
Old 12-12-2016, 11:49 PM   #4734
mud.man.rj
mud.man.rj's Avatar
I have never been much for blue,,,but yours has totally captivated me, so nice a shade and the perfect rim and size, you hit the mark with your truck and I don't say that lightly.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 12-13-2016, 12:10 AM   #4735
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Mudman.
Once again, I'm right there with you, Mud.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 12-13-2016, 11:20 AM   #4736
74baggedbug
Mudman.
Thanks!! It's a love/hate relationship with this truck..
Old 12-13-2016, 03:56 PM   #4737
BlackedOut67shorty
BlackedOut67shorty's Avatar
Went from all blacked out to chrome, blazer is still blacked out so im not to bothered by not having a completly blacked out vehicle
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline
Old 12-13-2016, 10:17 PM   #4738
74baggedbug
Took a day off from work and the temp was above 75 so I poured the epoxy.. my wife tells me I'm inpatient lol.. it's not as slick as I'd like so I'll wait a week sand it with 220grit and pour another coat of epoxy
Old 12-13-2016, 11:13 PM   #4739
Boog
laying low
Boog's Avatar
But it looks like glass already!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 12-14-2016, 01:17 AM   #4740
MikeB69C10
MikeB69C10's Avatar
Before
After
Thank you TruckSeats
MikeB69C10 is offline
Old 12-14-2016, 09:36 AM   #4741
matthamby
this was on my FB feed this morning, thought you guys would get a kick out of it. Ingenuity at it's finest!
"Roads? Where we're going, we don't need roads!"
I think he needs to paint the rims white and make some hub caps to match the front!
Old 12-15-2016, 11:03 PM   #4742
rsgt
rsgt's Avatar
I have been working on installing this cup holder and I got it finished today.
rsgt is offline
Old 12-16-2016, 08:14 AM   #4743
chevytruckguy70
I like that cup holder much better than the ash tray version I'm using. What did that come out of?
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI.
2007 Chevy 2500HD 4x4 Duramax
1970 Chevy K20 (SOLD)
1972 Chevy C15 (1/2 C10, 1/2 c20)
1970 Chevy C10 (parting out)
chevytruckguy70 is offline
Old 12-16-2016, 08:25 AM   #4744
BugzC10
BugzC10's Avatar
Looks good...what did your rear mounting bracket end up looking like?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 12-16-2016, 10:53 AM   #4745
rsgt
rsgt's Avatar
It is a 88-94 Chevy truck part.
I wish I had a picture. I used two 3/4x1/8 strap steel, curved and bolted to the lower heater control mounting bolts on the bottom of the dash then screwed to the lower heater housing. I bolted on each strap a small piece of the strap metal sticking out to catch the mounting clip on the cup holder.
rsgt is offline
Old 12-16-2016, 08:37 PM   #4746
ole dollor
ole dollor's Avatar
now thats a cool go anywhere kinda truck.....
ole dollor is offline
Old 12-16-2016, 09:10 PM   #4747
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
I need a couple of these for the 56 Bel Air and 64 SS Impala!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 12-17-2016, 08:59 PM   #4748
findog78
Nice job installing the carpet too. Mine looks like a wrinkle bomb and not even close to as smooth as yours.
findog78 is offline
Old 12-17-2016, 09:59 PM   #4749
mild68
mild68's Avatar
Cleaned up and painted transmission.
Installed new front seal and made a tool to install the balancer.
mild68 is offline
Old 12-17-2016, 10:17 PM   #4750
Toolman_69
I installed a bench seat I got cheap but it's in excel lane condition. I also cleaned up my differential and started the new yukon gear posi carrier install with a 4.10 gear... With a 4 speed it'll be really fun behind that 454....
Toolman_69 is offline
Closed Thread
