Old 12-11-2016, 06:36 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Has anyone seen these add-ons before ?
The truck in the link is for sale on EBay now. Has anyone ever seen a cylinder hooked up like this one between the cab and box. I guess the truck pulled a 5th wheel at some time and thats maybe why its mounted like that. Also is the block on the brake pedal a trailer brake or block cause the driver was short. Noticing above the windshield inside the cab does anyone think a potential rust problem is looming?
http://www.ebay.com/itm/252675601767...%3AMEBIDX%3AIT
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-11-2016, 07:25 PM   #2
hugger6933
Re: Has anyone seen these add-ons before ?
Thats a cool 68 GMC IDK what those things are for. It looks like a 4X4 steering stabilizer
hugger6933 is offline   Reply With Quote
Old 12-11-2016, 08:06 PM   #3
I've seen those dampeners used for hauling slide-in campers. Also seen them mounted at overhang on camper down to cowl on truck. Kinda silly when you think about it since the bed is rigid mounted to the frame. What do they stabilize?
If you only see rust seepage at the window there is probably rust between the gasket and flange, not down from the drip rail. I'd have to look closer. Often they first leak at the body seam in the drip rail right above the windshield post. I see seepage on the passenger post
Old 12-12-2016, 05:23 PM   #4
Already Gone
I'm really curious about the brake pedal thing, anyone ?
Old 12-12-2016, 05:49 PM   #5
weq92f
weq92f's Avatar
The add-on there between cab/bed doesn't look very useful.
Re: the brake switch or whatever: improvised brake light switch or safety during startup? Maybe a gear lockout in park?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-12-2016, 06:18 PM   #6
LONGHORN1962
LONGHORN1962's Avatar
Possibly a trailer brake controller. If memory serves I believe Tekonsha made one like that.
LONGHORN1962 is offline   Reply With Quote
Old 12-12-2016, 06:44 PM   #7
jocko
jocko's Avatar
Short driver - precursor to adjustable pedals.
As for the struts or shocks or whatever they are - have seen before, but not many. Could one of several purposes, none of which I'd imagine it accomplished very well.
Old 12-12-2016, 09:45 PM   #8
James the III
They stop the spring action of the unsupported frame c section ,when a heavy load is placed with bias at the frame center not over the wheels..
most slide in campers are nose heavy, putting the load on the frame between the cab and bed..
James the III is offline   Reply With Quote
Old 12-12-2016, 10:01 PM   #9
SS Tim
SS Tim's Avatar
The horizontal shocks are dampers intended to reduce cab bounce by tying the bed (hard mounted) and cab (rubber mounted) together. On this truck they were an aftermarket offering.
In 73 Chevrolet introduced them (inside the bed through the front panel) as well as verticle camper to cowl shocks as the Elimpitch system included in the Z83 Camper Special Deluxe Camper Group on C30 Fleetsides.
How effective they would be towing a fifth wheel is purely speculative. But like so many add-ons, once you drill the holes you tended to become a believer.
SS Tim is offline   Reply With Quote
Old 12-12-2016, 10:51 PM   #10
TheCougarine
TheCougarine's Avatar
The 73 C30 I just picked up has those mounted inside the bed as Tim said. It spent 90% of its life with a slide in camper in the bed. I can grab a picture of them tomorrow if anyone wants to see how they're set up.
TheCougarine is offline   Reply With Quote
Old 12-13-2016, 12:14 AM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
The bed is mounted to the frame with eight carriage bolts. It is separated from the cab for a reason (frame flexing). I'd consider these "shock absorbers" to be a sales pitch, along with dealer-added paint or parking lot protection strips. If a truck is a Custom Camper, it has been designed to carry the load. It has a heavier frame, leaf springs, and a Dana 60 axle (at least mine does). Maybe I'm missing something?
~Steven
Simi Valley, CA
Old 12-13-2016, 12:46 AM   #12
TheCougarine
I'd imagine the exterior stabilizers have a lot more to do with stabilizing the weight hanging over the sides of the truck rather than actually increasing any load carrying abilities. Carrying a load and keeping it from shifting around are two different things.
Old 12-13-2016, 01:50 AM   #13
geunther
geunther's Avatar
Grew up with a 73 Camper Special. Had them inside the bed as previously mentioned. The brake pedal thing is a trailer brake controller, also as mentioned.
Shocks did perform function for campers, but for a 5th wheel, the hitch should be secured to the frame, so any functionality would be negated.
geunther is offline   Reply With Quote
