11-29-2016, 09:15 PM | #1 |
Wtb Greaseable np205 bolt 71/72
Like the title says looking for
Greaseable np205 bolt 71/72 it holds the shift stick to the shift rails. Thank you |
11-30-2016, 01:05 PM | #2 | |
Re: Wtb Greaseable np205 bolt 71/72
To add to what I am looking for is GM 14009313 Thank you |
12-19-2016, 06:51 PM | #3 |
bump still looking
12-19-2016, 09:29 PM | #4 |
For the googly challenged: https://www.google.com/#q=GM+14009313+bolt
I always find it interesting that people are unable/unwilling to search the internet, or prefer to ask and wait rather than searching and getting answers is a second... |
12-19-2016, 10:08 PM | #5 |
One also has to be careful what one trusteth when he googleth. Perhaps Krex would prefer to go with something a bit more reputable, like a member. However, if you happen to successfully purchase one of these rather hard to find bolts for $3.19 (the first link in your search), and it arrives on your doorstep, I think we'd all love to hear about it. The second and third links show it as discontinued like just about every other place I've checked. I purchased one on here recently. Not cheap and not outrageous either, but I needed it, and I knew there was a human on the other end of it.
Krex, fwiw, the ones I've seen came with a hole that you would have to tap for the zerk - but it came with the zerk. I think it depends on date of manufacture for what you get with the part #. Good luck, hard to find gadget. My shifter rattles like crazy, haven't had a chance to install the bolt yet. Last edited by jocko; 12-19-2016 at 10:13 PM. |
12-19-2016, 10:44 PM | #6 |
I'll leave off the fake old English, but we pay /w credit card. No part; no pay.
I'd imagine that of 260 hits, one would have the part. I'm pretty sure there's another number due to the original being replaced as well. |
12-19-2016, 10:48 PM | #7 |
I have a few, but if I needed one and couldn't buy it, I'd probably get a bolt w/ the right length and thread, then locate a bronze bushing the right size, cut it in half and so on.
12-20-2016, 01:01 AM | #8 |
NP205 Greasable Pivot Bolt
This is a custom made greasable pivot bolt for 205 twin stick applications. The bolt has two full circumference grooves with two grease passages per groove. It will work with GM or Ford kits - see the twin stick description as this bolt is included in some kits. If you are using this on any shifter other than mine please verify that your shifter pivot hole is 3/4" in diameter. The picture shows the bolt on the end of grease gun with grease coming out of the dual passage grooves. Price: $20.00 here is his website http://jkwoffroad.com/offroadproducts.php Last edited by a1vintage69; 12-20-2016 at 01:16 AM. |
12-20-2016, 12:20 PM | #9 | |
Posted via Mobile Device |
12-20-2016, 01:02 PM | #10 | |
12-20-2016, 01:04 PM | #11 | |
my set up is 71 k20 with np205 with TH350 adapter. Thank you |
12-20-2016, 01:06 PM | #12 | |
Do you know it this works for a 71 stick with the TH350 adapter? Thank you |
12-20-2016, 01:31 PM | #13 |
12-20-2016, 07:11 PM | #14 |
12-20-2016, 07:16 PM | #15 |
Now I'm wondering if I have the right bolt Sutton in the box in my shelf!
12-20-2016, 08:03 PM | #16 | |
list me with the ones unable actually, I need one of those twin stick bolts, thanks for posting up
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-20-2016 at 08:30 PM. |
12-20-2016, 08:34 PM | #17 |
12-20-2016, 08:49 PM | #18 |
I was at a wrecking yard today, almost grabbed one. It did not have a grease zerk. I don't know why you couldn't drill a grease passage in it bolt without one and thread it for a zerk.
12-20-2016, 09:33 PM | #19 | |
You can pm or post thank you. |
12-20-2016, 11:05 PM | #20 |
If after you find a bolt, you need someone to drill and tap it, LMK as I can do it for you, if you don't have a lathe and drill press
12-20-2016, 11:57 PM | #21 |
Have to ask - what is the desire for two stick conversions? Interesting website with some real nice quality parts in the link above, but why would one want independent control like that? Is it a rock crawler thing? Just curious.
12-21-2016, 01:20 AM | #22 |
All about them K’s
Yea its an off road thing, it's actually pretty useful when you get into certain sticky situations.. One useful thing is You can partially lock the emergency brake up and use the front wheel drive (rear wheels in neutral) to then pivot the front end to get around obstacles or what ever the case may be.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-21-2016, 11:19 AM | #23 |
OK, since I just ordered my twin stic pivot bolt my oem bolt is available for sale. looks new, never used. paypal 20.00 plus shipping
IT DOESN'T HAVE A ZERK, but I can fix it
12-21-2016, 11:36 AM | #24 |
12-21-2016, 12:21 PM | #25 |
I'd be interested in buying the bolt, if you'd drill & tap it for the zerk fitting !
Of course after Krex !!! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Tags |
np205 |
