#851 |
![]() Join Date: Mar 2013
Re: Tricked-out Chevy six cylinder engines
Looks good man! Love me some hopped up 6 bangers!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#852 |
Long read thru 35 pages but lots of neat motors. I am also starting on a new 292 for my 65 pickup. Just pulling the shortblock apart now to check it out. Cylinder head work was done in the summer time. Lump ports, new springs and the larger valves and a little porting. The machinist was very impressed with the flow numbers this head flowed as high as the V8 Vortec heads do. Now to read a couple more chapters in Leo's book.
#853 |
1967 GM 292 bored 60 with Nitrous
#854 |
That is sweet man! Been awhile since I posted mine.
#855 |
![]() Join Date: Feb 2002
Nice eye candy, TJ. Not green or orange like all the rest, but it's your engine in your truck.
Where's the fuel pump? I see a block-off plate where a mech pump goes, and a steel fuel line coming from over the transmission hump. Looks like you have plumbed the in/out of the Clifford intake carb heat by bypassing the bypass hose elbow. Is that a 3-Bbl'd Demon carb? Who's Shorty headers? Strange things.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-18-2017 at 02:48 PM. |
#856 |
Wish I could have this one back for my C10. Built it for my no options 67 Chevelle 300 years ago. Lump port head with split exhaust, HEI and lumpy cam.
#857 |
Just sent my 250 out for rebuild - will have Offenhauser intake, 390 cfm Holley carb, 292 exhaust manifold, cam. Shooting for 9:1 compression. Builder is Baldwin Racing Engines in Friedheim, Mo.
If you don't like this ![]() |
#858 | |
4 barrel 625 cfm demon. Am considering a 3 barrel conversion though but would need a bigger carb I believe. Probably a 750. Clifford shorty headers. ![]()
#859 | |
1968 chevy c10 lwb, 250 inline6, 4 speed, ![]() |
#860 |
![]() Join Date: Jan 2015
Here's mine. 250. cam, split header, 4 barrel. It will stay for a bit but it will be replaced and used in another car I have. Fun to drive though. Right now there is a 3 on the tree behind it but I'm going to swap in a 4 speed I have.
![]() Here's a short clip of it running. https://youtu.be/xEJjbPWQvZU Last edited by raidmagic; 12-20-2017 at 01:05 PM. |
#861 |
Wow, Like the return spring bracket.
#862 |
#863 |
Moderator
![]() ![]() Join Date: Aug 2011
You know after looking at this thread I might go back and do another one.
#864 | |
1998 Chevy Tahoe 2D 1949 Willys CJ2A 1967 C-20 Flatbed (Sold) |
#865 |
#866 |
#867 |
Moderator
I's a 48/53 Custom GMC Panel - see in my signature.
#868 |
#869 |
OK, not a tricked out motor, but a very dependable, and in some rpm ranges, torquey as hell 250 inch motor. Damn thing loves to climb hills. It's in a '65, but as near as I can tell, it's about a '69 or '70 motor by the casting numbers.
This was in my truck when I got it. When I replaced the valve cover gasket, was amazed by how clean it was inside- no sludge at all. It may be a Jasper motor ( a motor rebuilding company) , don't know, but it uses no oil at all. I've grown to really like it, especially the sound. Some day I'll doll it all up. ![]() ![]()
Everybody has to believe in something. I believe I'll have another beer. |
#870 | |
#871 | |
#872 |
here is my 63 on its way to be tricked,, and the pending 292 to be freshened up
#873 |
You already trick you your fuel line. lol
#874 |
#875 |
Yeah, that is some fancy jet-engine type plumbing just to a one-barrel.
