09-23-2016, 09:31 PM | #1 |
SWB 4x4 Collector
Project Daily Crew
Hey guys, with putting in lots of fab time in on my 72 Crew Cab project, and having open heart surgery last summer, I decided to buy a truck to build and drive in the meantime while continuing my big build.
I found a 89' V3500 for a good price and went to look at it which I bought and drove home. Enjoying the feeling of driving an old truck, plus a crew cab, which is a new feeling for me. The truck came with a set of brand new SRW Hubs, so that was a plus. Here she was when I drove her home.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 09-23-2016 at 09:38 PM. |
09-23-2016, 09:36 PM | #2 |
SWB 4x4 Collector
Re: Project Daily Crew
Drug it home and began Dismantling. Decided it was too long for me, so chopped her down. Found a usuable bed floor in a salvage yard for $100 and decided to buy new bedsides. Also, converted the front to SRW.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
09-23-2016, 09:43 PM | #3 |
SWB 4x4 Collector
Then came the itch to lift her. Had a set of new 37" 16.5 wheels and tires. Started with a 4" I bought from a salvage yard with a 1" ez rate in the front. These are without lift in the rear yet.
09-23-2016, 09:49 PM | #4 |
SWB 4x4 Collector
Finally got the rear lifted via an ORD 4" Shackle flip and stock 1ton springs.
09-23-2016, 09:53 PM | #5 |
SWB 4x4 Collector
Got my bedsides but didn't want to wait for Classic Parts to get some in with doors, so I just picked so.e up at LMC and added the doors in to keep moving.
09-23-2016, 09:54 PM | #6 |
I dig it, especially like the aluminum slots.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
09-23-2016, 10:00 PM | #7 |
SWB 4x4 Collector
Then found a great body for my truck only an hour away. So I pulled the trigger and drug it home and began Dismantling again.
09-23-2016, 10:03 PM | #8 |
SWB 4x4 Collector
Started pulling the red body off the frame. It's drivetrain was 454, th400, np205. The C30 was 454,4 speed.
09-23-2016, 10:09 PM | #9 |
SWB 4x4 Collector
The back half of the C30 frame was in a lot better shape than the v3500's. So I decided to rob the 4x4 brackets off the red frame and out them on the gray frame and redo my frame chop with the better section. I would rather it be done right and it only made sense to use it since I had it. It was also when i located a FF14bolt and rebuilt it. So out came the Dana70HD.
09-23-2016, 10:16 PM | #10 |
SWB 4x4 Collector
Found a great deal on a nv4500 on Craigslist and figured it would make this truck come alive more than the th400 auto. Stepped up and bought the advanced adapters conversion bellhousing, slave bracket, and spacer to make the job easier.
09-23-2016, 10:25 PM | #11 |
SWB 4x4 Collector
Figured it was time to clean up the frame. I sandblasted the frame and expoxy primed, then good ole tractor paint for the frame. I have had great results with the tractor paint holding up on frames.
09-23-2016, 10:29 PM | #12 |
SWB 4x4 Collector
Picked up some 16x10 Eagles and modified Chevy caps to work with them. Also found a set of brand new 315/75/16 Goodyear Duratracs for an unbeatable price.
09-23-2016, 10:34 PM | #13 |
SWB 4x4 Collector
Also pulled the engine for some tlc.
09-23-2016, 10:36 PM | #14 |
SWB 4x4 Collector
Got the engine sat back in the frame, and that's where I am now.
09-23-2016, 11:58 PM | #15 |
Holy cow. Cool truck and nice work. How long have you been at the project? Keeping the TBI on the 454?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
09-25-2016, 08:50 AM | #16 |
SWB 4x4 Collector
I drove the truck home in March, and have occasionally been working on her.
I will be keeping the TBI unit on the 454, that's until I run into a 12V Cummins maybe. It wouls be nice to already double the mileage.
09-25-2016, 09:54 AM | #17 |
LOL at this being the small filler project. Nice work!
09-25-2016, 10:29 AM | #18 |
SWB 4x4 Collector
I did get the tranny and transfer case in. Had to make a 2" square tube spacer for the bottom of the nv4500 to work. Also replaced my rear driveshaft joints.
09-25-2016, 02:20 PM | #19 |
Master Hater
Man I hate to see a long bed truck cut up and go to a more useless bed, but the resto work looks good ..
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
12-28-2016, 11:12 PM | #20 |
SWB 4x4 Collector
Got some more done on the old girl. Deciding paint colors since I am just about to that stage.
12-29-2016, 09:41 AM | #21 |
looking good!
12-30-2016, 07:57 AM | #22 |
That looks really good!
