Old 01-05-2017, 12:18 AM   #1
HeloCrewChief
HeloCrewChief's Avatar
Which aftermarket gas pedal?
Just wanted to see which pedal works best in one of our 55-59 trucks. These are the 3 different styles I've seen and they all mount differently. Which one works best in our trucks?
http://www.ebay.com/itm/Lokar-Chrome...dU65P9&vxp=mtr
http://www.ebay.com/itm/Lokar-Elimin...dU62tk&vxp=mtr
http://www.ebay.com/itm/Lokar-Midnig...9WXH5o&vxp=mtr
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 01-05-2017, 12:37 AM   #2
roger55
roger55's Avatar
Re: Which aftermarket gas pedal?
The last one is specifically for 55-57 cars. I have one in my '55 Belair.
I have the second one in my '57 pickup. It works perfectly and the position is very comfortable. The install is kind of a pain though.
roger55 is offline   Reply With Quote
Old 01-05-2017, 01:03 AM   #3
HeloCrewChief
Thank you for your response. What was a pain about the install? Would you go with that pedal again? It is definitely the one I'm leaning toward.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 01-05-2017, 11:17 AM   #4
Speedbumpauto
Speedbumpauto's Avatar
Used the same one on my 55. Works well and doesn't take too much space. The pain, to me, is the bracket being on one side of the firewall and the pedal on the other. Arms don't reach that long!!! My fix was to bolt the bracket to the floor without the pedal, drill a hole through the floor and bracket on the center of each side, remove the bracket and install nutserts and use two 10x24 pan head screws to mount the bracket to the floor independent of the pedal. I relieved the bottom of the pedal bracket some so it would sit over the screw heads, but on some the carpet might take care of that. All that didn't make the install easier the first time but it SURE made it easier the multiple times I've taken it out since for different mods to the truck.
Speedbumpauto is offline   Reply With Quote
Old 01-05-2017, 12:00 PM   #5
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i have a spoon style pedal in my buick. pretty simple install, but the arm is pretty short. i am going to lengthen the pedal arm to get it closer to the floorboard so my wife's shorter feet can rest on the floor and still reach the throttle pedal. if you go with that, pay close attention to the height you mount the pivot at.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 01-05-2017, 03:42 PM   #6
bowt1ed
HCC, hope you don't mind I jump in as well - I've seen a lot of our TF's with the first style and have been leaning that direction on mine. Guys, what's the feedback on that one? Space/comfort issue?
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 01-05-2017, 05:31 PM   #7
DPete
DPete's Avatar
I have #2 also, works good
56' 3100 shortbed
DPete is offline   Reply With Quote
Old 01-05-2017, 07:22 PM   #8
Russell Ashley
Russell Ashley's Avatar
No question in my mind, number two. As mentioned, a little trouble to install by yourself, and more difficult if the engine and transmission is in the truck, but worth the effort. I mounted an original style pedal on mine to retain the stock look.
Russell Ashley is offline   Reply With Quote
Old 01-05-2017, 11:40 PM   #9
HeloCrewChief
Cheers, Jim
Feel free man. This is what the forum is for. I will be going with pedal design number 2. It seems to be the cleanest install and looks like it is pretty comfortable. Thank you for all the help and pictures guys.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 01-07-2017, 09:32 AM   #10
jams97355
I have pedal #1. It works great in the shop. Haven't had it out on the road yet but it fits nice with my setup and was pretty easy to install.
jams97355 is offline   Reply With Quote
Old 01-07-2017, 11:07 AM   #11
my56chevytruck
my56chevytruck's Avatar
Do you know how to weld? I used the 1st one but before mounting I made a stand that the pedal mounted to. Basically, I took a piece of steel plate bent it so it was about 1/2" tall with sides I could weld to the firewall. I did this so i didnt have to drill holes in my firewall, (it's completely flat). But of course, you have to know where the gas cable comes thru your firewall. If you need pics PM me. If you can weld, it's very simple.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 01-07-2017, 01:45 PM   #12
Russell Ashley
I have expressed my preference in a previous comment but forgot to mention one advantage to using the number two version. With the other two the cable comes through the firewall near the carburetor and this makes for a short cable which can be difficult to work with. With the floor mounted pedal the cable mounts to the pedal arm behind the engine and makes it easy to route the cable with no hard bends in it.
Just thought I'd throw this out as my truck had one of the other kind in it when I got it and I didn't like the feel of it. My truck has a 350 in the stock location which puts the carburetor fairly close to the firewall. Just trying to help out.
