Old 01-20-2017, 11:06 PM   #26
2B32
Re: Still Chasing Carb Gremlins
Originally Posted by geezer#99 View Post
X2!!
Turn up your high idle and. lean your choke a bit.
The pops or backfires is because it's puddling fuel. It's lean.
I just want to make sure I understand you correctly. Is it popping because it's rich, or lean?
2B32 is offline   Reply With Quote
Old 01-21-2017, 12:05 AM   #27
geezer#99
geezer#99's Avatar
It's lean!
THe fuel vapor that gets to the cylinder is lean. Too lean for good combustion. So it misfires.
Old 01-21-2017, 12:06 AM   #28
jkeady
jkeady's Avatar
Just for giggles, if it's not too inconvenient, when it's bone-cold, hit the accelerator once to set the choke, then take a picture of the fast idle cam on the right side of the carb.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 01-21-2017, 06:19 PM   #29
2B32
Originally Posted by jkeady View Post
just for giggles, if it's not too inconvenient, when it's bone-cold, hit the accelerator once to set the choke, then take a picture of the fast idle cam on the right side of the carb.
I don't know why it loaded upside down, and I can't change it now. Sorry.
Old 01-21-2017, 11:21 PM   #30
Gromit
My sense is the answer is more likely in the very early responses to your question; particularly geezer99's
But more on the kooky side (which is my specialty) where is that purple wire going? Because if I lay a wire right up against an HEI ignition wire; I would expect that ignition wire to induce a relatively big inductive current down that purple wire. Maybe it is an optical illusion in your photo and it really isn't right up against?
Hopefully someone who really knows will correct me here and I will learn something if I am wrong.
I do think that the induced current falls by at least the square of the distance between the wires, so you could eliminate my concern my just putting a zip tie's distance between those two wires.
One strategy that has helped me is to always have one extra carb and one extra distributor rebuilt and cleaned up and ready to swap in. They are quick to change out and it can help for troubleshooting. $335 for a carb and $100 for a distributor is maybe a lot but still cheaper than seeking help at a shop.
My other thought is that a worn throttle arm bushing in the carb can cause lots of intermittent gremlins - sometimes its fine then the next minute it isn't. Just two or three thou wear on the throttle arm bushing can make the difference (I think)..
Gromit is offline   Reply With Quote
Old 01-21-2017, 11:32 PM   #31
2B32
The purple wire is the keyed power to the electric choke.
Old 01-22-2017, 12:06 AM   #32
jkeady
jkeady's Avatar
Originally Posted by 2B32 View Post
Attachment 1613678
It's all good, I just wanted to see where on the fast idle cam the screw was hitting. It's not doing you any good to just turn the fast idle screw in a half-turn, eh?
Josh
