Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-16-2017, 06:33 PM   #226
Okiefromwatonga
Re: 68 C50 Looongbed pickup build
Ouch, thats Highway robbery
Okiefromwatonga is offline   Reply With Quote
Old 01-17-2017, 01:15 PM   #227
Deer_hunter_088
Deer_hunter_088's Avatar
Finally!!!!!!!!!!!!! Been waitin, what about the schoolbus or the 89 radiator?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 01-17-2017, 01:42 PM   #228
flashed
Patience ,Grasshopper .LOL
flashed is offline   Reply With Quote
Old 01-17-2017, 03:48 PM   #229
Deer_hunter_088
I cant help it i love trucks lol And i was on lunch and i am hyper today. you know why john.
1998 S10ZR2
Old 01-17-2017, 04:51 PM   #230
flashed
Yes I know .
Old 01-17-2017, 10:36 PM   #231
rkn463
rkn463's Avatar
I have to get a couple more quotes. I know that if I tell them to build it within a week I'll find a used one for cheap... Just the way it goes.
The bus and the 89 had the same rad, both two inches too tall. I could extend the hold downs but the hood wouldn't shut. If I put a body lift on it then I can extend the bottom of the core support down, but then I get steering column problems too. It's a lot to take in. I just need to chew on it for a while.
Patience indeed. Our young grasshopper has not graced us with any pictures of his lifted 69.
Just sayin...
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-19-2017, 10:43 AM   #232
Deer_hunter_088
Just sayin...
-Richard
I dont think ive worked on it in a few weeks
1998 S10ZR2
Old 01-19-2017, 10:47 AM   #233
Deer_hunter_088
THERE YA GO A CONCEPT PHOTO!!!!!!!!!! but seriously i love the look of this truck.
1998 S10ZR2
Old 01-19-2017, 08:06 PM   #234
Stephen717
Stephen717's Avatar
good progress on the truck, and that lifted stepside looks sweet. my blue knight is still getting gutted, all I have left on the wiring is whats running to the tail lights and reverse lights. work is slow when you're truck ain't covered and monies not plentiful. Now if only I could find the intake bolt that I dropped. I didn't think that an orange bolt would blend in so well with grass and gravel.
Stephen717 is offline   Reply With Quote
Old 01-19-2017, 10:01 PM   #235
Deer_hunter_088
Rnk just for you today i took a picture of franken truck. Its sad i think i need a grill asap. And an oem steerin coloum. But i wanna drive ittttttt. But ive came up eith an awesome fuel filler idea.
1998 S10ZR2
Old 01-20-2017, 11:16 PM   #236
rkn463
rkn463's Avatar
I dont think ive worked on it in a few weeks :lol
Daaaaaaaaam! If you manage to create something like that I will indeed be impressed. That is a great one to shoot for. It almost makes me want to convert my 67 stepside into a 4x4 (the truck in my avatar)
Thanks Stephen, I don't recall a build on your blue knight, do you have a build thread going on it?
I feel your pain on the missing bolt, check out the last picture in post 66 of this build. That roll of tape fell and landed there!
...ok... Did you post it?
Come on deer hunter, you're killing me!
-Richard
Old 01-22-2017, 07:53 PM   #237
Stephen717
Stephen717's Avatar
I don't have an actual build thread. I thought about it but couldn't justify having one what with the cold rainy days and no dry place to work on it quicker. But here is how she sits now minus the grille or front bumper
Old 01-23-2017, 10:11 AM   #238
Deer_hunter_088
There ya go!!!!!!!!!!
1998 S10ZR2
Old 01-23-2017, 10:13 AM   #239
Deer_hunter_088
Ahhhhhhhhhh i remember this day, the day i brought the ole girl home. and dude if ya ever near me i have a front axle so ya can make yout 67 a 4x4
1998 S10ZR2
Old 01-23-2017, 11:33 PM   #240
rkn463
rkn463's Avatar
Looks like a good start.
Ah, finally! Thanks for sharing, get that thing going and drive it
-Richard
Old 01-24-2017, 10:37 PM   #241
rkn463
rkn463's Avatar
Update from last weekend:
I really wanted to bolt the front sheet metal back on and rig the too big radiator in and drive it. However... I still needed to deal with the park brake first. And even bigger deal, if the weather would permit I needed to work on my fencing project between my neighbor and myself. Well, the weather was good Saturday so I worked on the fence most of the day. Around 4:30 a squall blew in and ran me off of that. So I stopped for the day, washed off the poison ivy and had supper after that I attacked the park brake.
The 68 had the park brake bolted directly to the transmission, sticking up to the right of the shifter. The 89 was under the dash next to the driver side kick panel and was cable operated. My original plan was to adapt the trans mounted brake lever but when I compared the throw the 68 moved the linkage less than an inch where the 89 was about an inch and a half. Rather than re-engineer the whole mess I decided to just reuse the whole 89 brake lever and mount it in the 68. The lever used three bolts, one aimed forward through the firewall and two bolted to the floorboard on the wheel hump. The height of the mount points meant that I needed to make it taller or have it too close to the floor. The two bolts that hold it to the floor were welded to the bracket so I not-so-delicately removed them, you can see in these pictures with one stuck back through the hole and the second with them gone.
Size:  22.9 KBName:  bbb.jpg
I figured out the height, drilled a hole in the firewall and screwed the assembly to the firewall. To hold it level I stuck a bolt through one of the holes while I measured for the new ears. Finally I cut off the old ears and added my home made pieces. The welds weren't perfect but are getting better.
Size:  37.2 KBName:  ddd.jpg
One last picture of the assembly installed.
more to come...
-Richard
Old 01-24-2017, 10:58 PM   #242
rkn463
rkn463's Avatar
...more on the park brake:
What I did not get pictures of was that I pulled the park brake assembly back out and painted it, I also sanded the part of the floor that it will cover and hit it with Rustoleum rust reformer paint.
I was a bit stumped as to how the brake cable was supposed to be routed but eventually found a picture that hadn't made the cut to be posted at the time. But you get to see it now . As you can see the cable came out of the firewall, looped behind the body mount, over the trans and then down to connect at the back of the trans on the passenger side. (thank goodness for reference photos!)
Since I wasn't able to locate that picture until Monday I didn't finish hooking it up over the weekend. Once it is connected there is literally nothing left that has to be done before the sheet metal goes back on. So pending fence work I may make it look like a truck again next weekend.
Also, I have requested a quote from another radiator shop, so we'll see what they say.
Oh, and last; that danged circuit breaker finally made it in from China!
That's all for now folks, hopefully I'll have more to show next week!
-Richard
Old 01-24-2017, 11:04 PM   #243
Hewfil1
Hewfil1's Avatar
Good to see someone's making progress on their truck! I ain't touched mine in months. She still needs new 3/8" fuel line, the tank dropped and cleaned, removing the frame in-line filter, and all new rubber hose.
Hewfil1 is offline   Reply With Quote
Old 01-25-2017, 10:38 AM   #244
Deer_hunter_088
Finnaly!!! and yeah money is whats keepin mine from runnin.
1998 S10ZR2
Old 01-25-2017, 08:12 PM   #245
Advanced Design
Advanced Design's Avatar
Richard, that is a good idea on the parking brake. Circuit breaker took its time....oh, my box cutter hasn't turned up yet either.
Appreciate the updates....were you putting up wire fence?
Advanced Design is offline   Reply With Quote
Old 01-25-2017, 09:57 PM   #246
rkn463
rkn463's Avatar
My advice (for what it's worth) sit down, make a list and then pick a couple of fairly cheap and easy things to do first. The feeling of accomplishment can be very motivating.
Been there, done that! At this point in my life available time is a bigger problem than funding. If I don't get moving life expectancy may become an issue!
That is one crafty box cutter you have hiding from you!
The wire fence is down on the property where the truck resides. I'm on my iPad right now, next time I get on the PC I'll try to get a screen capture from google maps to show you what I have going.
I haven't checked out your burb in a Few days. I think I'll head over there now.
-Richard
Old 01-25-2017, 10:08 PM   #247
rkn463
rkn463's Avatar
I got a quote from a radiator shop here in Fort Worth, $650, that is $225 cheaper than the previous one. Who would have thought that I would be quoted 650 for a radiator and be happy about it!?
-Richard
Old 01-26-2017, 11:41 AM   #248
Hewfil1
Hewfil1's Avatar
-Richard
Well in that case, maybe I'll take a day to remove the fenders and Gunk the whole motor. Hah.
Old 01-26-2017, 12:59 PM   #249
Deer_hunter_088
-Richard
I applied to a local grocery store, so i can keep my s10 runnin, and slowly restore my k10. hopin i get the job
1998 S10ZR2
Old 01-26-2017, 09:28 PM   #250
Stephen717
Stephen717's Avatar
Good luck on the job Noah, and gunk is always nice when you have a hose or pressure washer to get it off with.
22.5 wheels, c50, disk brake conversions, hydroboost, pickup
