#426 |
![]() Join Date: Jan 2016
Re: What did you do to your Blazer/Jimmy today?
First I soda blasted the console. After a good wash and time to dry overnight, I sprayed 2 coats of SEM 39863 plastic adhesion promoter per can instructions. I followed that with 3 coats of SEM color coat satin black 15243.
#427 |
The console and tach look great.
#428 |
#429 |
#430 |
#431 |
![]() Join Date: Nov 2014
Took her to a car show!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#432 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Had a custom speedometer cable made around a firewall grommet from Classic Heartbeat - hate to cut grommets to fit around the cable.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#433 |
![]() Join Date: Aug 2012
#434 | |
Carpe manana
Shoot me a pm if I can facilitate anything locally. http://www.momamanufacturing.com/about.html
#435 |
2WD Jimmy
![]() Join Date: Mar 2005
Your grommet is backwards.
just kidding. lol |
#436 |
Carpe manana
Lol!!! I looked more than once before departing the shop for sure.
#437 | |
I'll call Mo-Ma Manufacturing this week. I replaced my cable and had to cut the grommet like you say, I hated doing it. This is a nice opportunity to do it correct. I'll talk to them about sending my cable for reference of length and fittings as well as a new grommet to build the new cable around. Thank you! |
#438 |
Installed a new grill insert. Because of a couple shipping scratches it was free! SCORE!!
#439 |
Chrome front bumper.
#440 |
Chrome rear bumper.
#441 |
sanded, painted and installed the top. c'mon!
#442 |
![]() Join Date: Nov 2013
Put one of those cheap Holleys on so
I can keep it going while I work on the LS1 swap Washed the dust off Cleaned the garage My K/5 lives here....close to the tool box...hahaha....!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#443 |
Took delivery of a 1971 Jimmy. First one for me in my lifetime. Should be fun.
Posted a pic in the new member section. Jimmyjon. |
#444 |
Built one of those high dollar tipping jigs. $23 for some hardware and a couple 2x6s with some scrap plywood I had laying around... Took 3 of us to lift the body off the frame but i'm able to tip it on its side on my own now.
#445 |
Installed the new dash pad, headlight switch and glove box liner. This is the 1st and LAST Counterparts dash pad I use. I've never had any issues with a dash pad made by Dashes Direct.
#446 |
![]() Join Date: Apr 2016
That's a rotisserie that will probably fit into my budget! Can you post some more photos & some details?
#447 |
A new 2 1/2 exhaust. Very impressed with their work! Almost done. .....
#448 |
Got my floor mats in that I ordered a few weeks ago. Real happy with the way they fit and how much of the floor they cover. I didn't realize my carpets were so faded, so may have to do something about that later this year.
#449 | |
For the rear I just bolted a short piece of scrap angle bar where the tailgate trunnions mount so I could bolt up the 2x6(used scrap plywood as spacer to keep it off the body). Up front we fabricated some simple triangle brackets to go between the 2x6 and the supports at the bottom of the firewall so it mounted perpendicular with the ground. The bolts holding the bracket to the body aren't ideally spaced but those holes are already there and I didn't want to drill more. The 2x6 were 8' long and I centered them on the body then trimmed the one side flush with the plywood once it was bolted up. The plywood was just some leftovers from when I replaced my roof a few years ago. It was 5/8 thick and about 20"x8'. I just cut it in half and put a full radius on one end of each piece. I measured from the ground up to about 4" below the lowest part of the body and set that as the height of the plywood. Also spaced it out about 6" from the side of the body. All the wood was bolted together using 5/16x 3.5" long carriage bolts with nuts and washers (Had to cut a few bolts down to size). Pack of 25ea from lowes was just enough to get er done. If I were going to use it for any extended period of time I'd add some support to the plywood to stiffen it up but I only plan to have it on there a week or two. |
#450 | |
