Closed Thread
Old 01-24-2017, 12:59 PM   #4876
66clow
66clow's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 72_swb View Post
I put the new flex plate and starter on. Went with the 98 delco truck starter.
I adjusted my head lights and and went for a cruise.
Is that a small starter? Is it a high torque starter? For what engine?
66clow is offline
Old 01-24-2017, 07:23 PM   #4877
Barnfind46
Barnfind46's Avatar
Swapped out the back glass rubber for a used one with the stainless trim.I bought a back glass with trim for $20.00 at my local pick and pull.My back glass was in better shape so I just used the rubber and trim.
Barnfind46 is offline
Old 01-24-2017, 08:22 PM   #4878
ohboy321
ohboy321's Avatar
Today I pulled the old JVC radio out to see if the dash had been hacked up by any of the previous owners. It was nice to see that it wasn't. I will get an original looking radio some day.
This week I ordered pins and bushings to rebuild the door hinges, as well as a NOS door stop retainer to replace one that is missing.
ohboy321 is offline
Old 01-24-2017, 09:46 PM   #4879
72_swb
72_swb's Avatar
yes its a smaller starter. I think they may consider them high torque mini. not sure on that. We used one a 468 13 to 1 motor. Im not sure when gm started using them? I just order a starter for a 98 1/2 ton 350. Used them on several cars now. It was 210 from the chevy house. half the weight and size of the old starters.
72_swb is offline
Old 01-24-2017, 10:18 PM   #4880
firedemon
spent the evening on the internet researching roller motor with mechanical fuel pump realize I need a better job or a good lotto win
firedemon is offline
Old 01-24-2017, 11:28 PM   #4881
74baggedbug
Installed these aluminum header gaskets.. I've heard mixed reviews but worth a shot
74baggedbug is offline
Old 01-24-2017, 11:58 PM   #4882
toolboxchev
Great looking engine and compartment!
toolboxchev is offline
Old 01-25-2017, 09:11 AM   #4883
hewittca
hewittca's Avatar
I never liked the stock location of the step bumper on my truck. It always looked too low to me. So, after doing the 2.5" frame raise in the rear, it was the perfect opportunity to tuck the bumper higher up. I think it looks much cleaner now. I was originally going to ditch this bumper for a sport bumper, but this simple step bumper is growing on me. I think I may keep it.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline
Old 01-25-2017, 10:27 AM   #4884
dfwright
dfwright's Avatar
I really like what you've done there. I have a similar bumper, and the same issue with it mounting an inch too low. I may just have to do this myself. It looks much better.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline
Old 01-25-2017, 01:33 PM   #4885
Metaldoc
Metaldoc's Avatar
These old bumpers look great But I'd like to raise mine an inch. My tailgate hinge points and bed are raised, when I close the gate there's a 1 1/2 gap.
Metaldoc is offline
Old 01-25-2017, 01:37 PM   #4886
Metaldoc
Metaldoc's Avatar
Mounted the inverter and Bluetooth, usb, sd card, 1/8 jack, FM radio install started.
Metaldoc is offline
Old 01-25-2017, 03:02 PM   #4887
hewittca
hewittca's Avatar
I love your tailgate mod. That is one of the coolest mods I've seen on this forum. I think with all the fab work you've done on your truck, you could knock out that bumper raise in no time
hewittca is offline
Old 01-25-2017, 04:51 PM   #4888
Metaldoc
Metaldoc's Avatar
Thanks it was not easy to get all of it to fit, but nothing is impossible, it's just never been done. I've done quite a few mods that only a trained eye would see.
Metaldoc is offline
Old 01-25-2017, 05:20 PM   #4889
hamjet
hamjet's Avatar
I changed out the ignition switch today. it was acting up, ( cranked fine but wouldn't start till I let off the key to run position ). All planets are once again aligned....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 01-26-2017, 02:30 PM   #4890
BugzC10
BugzC10's Avatar
Installed new fuel line, filter and guage....old rubber one was clogging up filter.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 01-26-2017, 10:08 PM   #4891
SoCoC10
SoCoC10's Avatar
Before
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 01-26-2017, 10:13 PM   #4892
SoCoC10
SoCoC10's Avatar
After
SoCoC10 is offline
Old 01-26-2017, 11:42 PM   #4893
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Worked on the Ramp Rat tonight. Got the electric washer jug plumbed and the screen in the cowl installed. Picked up some epoxy putty to start on the rebuild of the GM steering wheel tomorrow also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 01-27-2017, 12:18 AM   #4894
Absolute home
Absolute home's Avatar
Started to put body molding on, not really digging it seems cheap and flimsy. Not so much the side stuff but for sure the tailgate.
Absolute home is offline
Old 01-27-2017, 07:28 PM   #4895
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Took the old seat out and replaced with a 90 model seat. Put the drivers side harness in have to make a LQ yard run to pick up some more belts. Installed the new strob light also.
Took the hump out and sealed it up good and put more screws in it.
Got to get a rubber mat for it and the inside should be done.
Andy4639 is offline
Old 01-27-2017, 08:44 PM   #4896
firedemon
looks good though
Old 01-28-2017, 08:23 AM   #4897
SoCoC10
SoCoC10's Avatar
Rust repair and body work is done. Got some paint on her. Custom PPG not the original "Medium Red" and not quite "Hugger Orange".
SoCoC10 is offline
Old 01-28-2017, 08:25 AM   #4898
SoCoC10
SoCoC10's Avatar
New Goodmark bed sides.
SoCoC10 is offline
Old 01-28-2017, 10:01 AM   #4899
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1485611782
Painted my later model console fawn beige to fit in between my Procar seats in my Vermillion 67
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline
Old 01-28-2017, 10:25 AM   #4900
berch 69GMC
berch 69GMC's Avatar
Paint looks great SOCO.
berch 69GMC is offline
Closed Thread
