Old 02-22-2017, 03:22 PM   #26
davepl
davepl's Avatar
Re: Why all the hype about horse power and torque?
Originally Posted by truckster View Post
I haven't seen anyone else talking about two-footing it in the cold because that's what real men do. The OP was looking for simple. It doesn't get any simpler than replacing the stock carb with a remanufactured carb of the same type.
Yeah, and if you read my post (#3), that's what I told him and I even gave him a part/casting number for it. Then people chimed in with the theory that they don't need to run well because they're old. It's up there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-22-2017, 10:11 PM   #27
396C-10
Wow! What a response! 1st off, THANK YOU all for your input, I wasn't expecting a wealth of information like this.
What I have going on was a transplant, where I removed a straight 6 three on the tree and installed a big block 396/402 from a 70 Chevelle.
I did not have a carburetor when the engine was built, so I bought a Holley 0-3310S 750CFM 4bbl Carburetor brand new. Name:  received_1231111450235552.jpg
It ran like crap, so I sent the carburetor to a NASCAR guy to tune and dyno for me. What I got back was way over the top,Name:  IMG_20170220_144239.jpg
though I paid him the $400.00 and happily brought the carburetor home and mounted it to the intake.
I do not plan on drag racing and I have yet to run the modified carb, but I think this is way, way too much carburetor for my needs.
I am thinking the ROCHESTER QUADRAJET 7040206 is more in line with my plans and I will put my new Williams Built Holley in a glass case to be viewed by my buddies.....
396C-10 is offline   Reply With Quote
Old 02-22-2017, 10:18 PM   #28
396C-10
It looks great, and I am sure it will be great for the 1/4 mile, but I'm not planning on racing it... I will test it out to see how it runs, but I still think this is way too much carb.
Old 02-22-2017, 10:24 PM   #29
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by James the III View Post
The difference is the edel is a vacuum 2nd carb and only mildly tune able.
The holley either in vacuum 2nd (street) or double pumper (street/strip)
is you can tune everything on it..
The q-jet is in the same boat as the edel.. as far as user tuning but has tiny primary bores for crisp throttle response and flipp'n huge 2nd's..
and when tuned correctly will run as good as the holley . most times better..
Holley claim to fame is K.I.S.S. and user changeable parts to tune it to your app.
Think of it this way, your shower head the q jet is the fine mist, the holley is the thick streams..
holley dumps the fuel, the edel and q-jet meter it..
I feel I definitely lost power with the Edelbrock. It had a perfectly good Rochester. I still have it. I had never serviced a carb. before and needed a choke very soon. The mechanic talked me into the Edelbrock. He said he's not a fan of Rochester, but more than that I bet he just didn't want to deal with it. Since then I've discovered you can add an electric choke onto a Rochester. I don't know if that would require the heat stove & pipe, but I'm guessing not.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 02-22-2017, 10:33 PM   #30
truckster
truckster's Avatar
You're correct. All the electric choke requires is 12 volts.
truckster is offline   Reply With Quote
Old 02-22-2017, 11:38 PM   #31
geezer#99
geezer#99's Avatar
Attachment 1625421
What a waste of a good carb!!
Don't matter what you run for a carb, your intake choice and likely a lack of timing will make it run like crap.
JMHO.
Old 02-22-2017, 11:41 PM   #32
71CHEVYSHORTBED402
The mechanic is an old gent, but he's somewhat a hustler. To think I got a new carb. when all I needed was a (*^()^ electronic choke for a legit Rochester. I won't use that guy again, except.........
His shop is SPOTLESS and I know one of the mechanics. About 100 years experience between the two. They work on top restorations all the time, and have a board to hover over engine bays. It's a VERY cool cart. At any rate, once this project is ready to fire, the first key will be in his shop.
Tony
Old 02-22-2017, 11:50 PM   #33
71CHEVYSHORTBED402
Attachment 1625421
I'll be that's quite a carb. I don't know if there's a difference less part numbers, but my Rochesters are:
The correct model is 4MV
1971 402: 7041209
1972 402: 7042206
Tony
Old 02-23-2017, 07:50 AM   #34
James the III
I did not have a carburetor when the engine was built, so I bought a Holley 0-3310S 750CFM 4bbl Carburetor brand new. Attachment 1625412
It ran like crap, so I sent the carburetor to a NASCAR guy to tune and dyno for me. What I got back was way over the top,Attachment 1625413
Welp he got your new carb and sent you back a worked over used one..
James the III is offline   Reply With Quote
Old 02-23-2017, 08:00 AM   #35
James the III
Yup most likely didn't want to deal with it as he can't make any money..
the time it take him to rebuild it, and it still have a vacuum leak at the throttle shaft that he didn't fix would make a customer mad..
bonus is the part mark up on the new 300.00 carb.. the shop got for 30 minutes of work..
In and out and most customers will not care as long as it stars and runs correctly..
If he is an older guy he also had had to deal with the plugs in the base leaking and having to fix, and all the other issues that would take time to fix before he sent it out the door with his name on the work..
better for him to pop on a new carb and call it good..
Same reason shops don't rebuild starters,alt,water pumps, ect they make more just replacing them..
Old 02-23-2017, 10:09 AM   #36
1972RedNeck
1972RedNeck's Avatar
Originally Posted by franken View Post
Torque has units, HP has none.
This is almost as good what brand of oil is best.
When it comes to horsepower and torque measurements, one is no good without the other.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-23-2017, 12:00 PM   #37
hamjet
hamjet's Avatar
WOW! thats a far cry from a big block sewing machine that was posted in your 1st thread..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 02-23-2017, 12:55 PM   #38
LongBox
This thread was sure not what I expected when I read the title "Why all the hype about horsepower and torque." Lots of good information on carbs here, but some guys really do want a vehicle that has lots and lots of acceleration, and they are prepared to live with hard starting, lumpy idle, etc. etc. etc.
My 350 on the 69 has the stock Q-Jet, and despite the potential in the design of that carb (small primaries), the truck gets really lousy gas mileage. I don't think anybody cared back in the 60s. So, for the OP, getting the factory stock, smooth idling, easy starting, sewing machine carb might mean poor mileage, when it doesn't have to be that way. Things have improved since the 60s.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 02-23-2017, 04:24 PM   #39
James the III
This used to be true.. and still is somewhat, there is a Draw an addiction to being in control of the reins of a bucking bull.. and the adrenaline rush. of that bull in the china shop v8..
but today you can build a mild mannered just as powerful turbo'd v8 that is smooth but goes like stink..
Asking a carb designed for mileage to work on a hipo v8 and still do that without getting into it.. is well.. um.. not going to happen..
the q-jet unlike the holley you can't just unscrew and change air bleeds, etc.
it takes knowing what it needs/wants and getting it right the 1st time..
Many don't have that skill.. but everyone at any show thinks they do with a holley.. key word think..
The best thing to come along is the a/f meter and data logging.. so you can see what it's doing and adjust it with data to back up it, not just a guess..
Old 02-23-2017, 11:27 PM   #40
palallin
It is possible to set up the Q-Jet to get good mileage if you set it up to keep from opening the secondaries till you need 'em. To many q-Jets go down the road with the secondaries partly open.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 02-24-2017, 01:35 PM   #41
70cst
70cst's Avatar
I would agree
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-24-2017, 02:00 PM   #42
davepl
davepl's Avatar
Originally Posted by 70cst View Post
I would agree
Does this sound like someone concerned with cold start driveability:
Your mom and my mom who drives a camry most likely forgot what it was like with older vehicles, that you back then, started and waited a few minutes before popping it into gear.. Today they get in and go..
The removing the other factory equipment will cause cold start/run issues.. but that only matters if the vehicle gets started and run in the cold..
Stuff like that.
Old 02-24-2017, 11:19 PM   #43
The writing on the wall on that carb was "had a Nascar guy build my carb". If all you did was drive wide open down the interstate I'd say he's your man for a carb tweak. But that ain't reality. The key is what you need through the range.
Old 02-25-2017, 09:32 AM   #44
James the III
Maybe, but circle track be it the local bull rings or the nascar pro series. don't run wide open all race,, other than 2 tracks.. (super speedways)
but their rpm range is much higher than any thing on the street..
Old 02-25-2017, 09:50 AM   #45
They don't stop or shift much
Old 02-25-2017, 12:22 PM   #46
davepl
davepl's Avatar
Probably true for carbs, never thought of that. I had a NASCAR engine builder do my 402 (he retired up here and still putters on projects) but I figure if you can built a motor to live for 500 racing miles, my 402 will live.
But it might not transfer to carbs, as you say, because they're basically wide open all the time!
You know who you really want? That unnamed grey-bearded old tech who worked at the corner Texaco for 40 years. That dude can fix anything. But avoid his brother, he's terrible. Unfortunately they look identical...
Old 02-25-2017, 03:50 PM   #47
James the III
If a guy can tune a carb for each track and it's gearing and rpm and shifting..
He can tune a street carb.. but you have to be honest on what it's going on and it's use..
most fib. here and with cams, and converters then wonder why it's ruff, coughing mess..
that is junk till 3000 rpm than it's like you hit a light switch..
Old 02-26-2017, 01:38 AM   #48
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
That aint no sewing machine! Thats a 396 Big Block Chevy motor. You make snide remarks about horsepower and torque and then go buy a Holly? Quit messin around and put a Quadrajet on that Chevy motor! Leave the Camrey's (whatever that is) and the sewing machines to grandma. Dont you have a spreadbore intake? NO other 4bbl carb will get the mileage a Quadrajet can get. And consequently no other carb has 2-1/4" secondaries to make your sewing machine set your hair on fire! Learn your carb, welcome to the performance world...~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-26-2017, 02:55 AM   #49
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
FWIW...
I am running a 7043207 on my basically stock 73 C/20 454, .060 over, low cast iron intake, small valve non ported 049 heads, & Thorley Tri-Y's.
This Quadrajet was a simple recolor & rebuild.
Doing some detailed assembly and THOROUGHLY inspecting everything, done right, it works just fine.
My only issue is that I need to change the needles as it runs just a little bit to rich.
Otherwise, no complaints
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 02-26-2017, 12:21 PM   #50
HO455
HO455's Avatar
As to answer the OP's question. It's all about marketing and selling stuff. The factory did their work to make people like you happy. What are your expectations for fuel mileage? The BBC is notorious for poor fuel mileage.
RIP Bob Parks.
