Old 02-24-2017, 11:35 PM   #1
Wulfaz
Factory 1/2 ton dually???
I recently was given a 1970 Chevy pickup from a family member. I am trying to figure out exactly what I now have. It has a 350 motor and is a dually (with the extra wheels going under the bed, Not sticking out the side of the truck). But according to the VIN number it is a half ton. It also has a gooseneck ball in the bed.
Did chevy make a factory 1/2 dually or did somebody do this aftermarket? Also would a 1/2 ton frame even be able to handle a gooseneck trailer?
Wulfaz is offline   Reply With Quote
Old 02-25-2017, 12:17 AM   #2
El Dorado Jim
Re: Factory 1/2 ton dually???
pictures? and welcome to the forum...
El Dorado Jim is offline   Reply With Quote
Old 02-25-2017, 08:12 AM   #3
uncle
Probably had a cab swap.
uncle is offline   Reply With Quote
Old 02-25-2017, 08:12 AM   #4
Welcome to the board! Yes, pictures would help. Is it a 6-lug or 8-lug? I wonder if the cab wasn't swapped from a 1/2t onto a 1t chassis. If the wheels don't stick out it must be a factory C/30 DRW cab & chassis model. Any other factory rear would put the extra tires out past the the other tire.
No, GM never made a 1/2t dual rear truck. But, they did make a 3/4t cab & chassis. You can't tell one from a 1t till you look at the VIN or take a closer look. Both are 8-lug
Old 02-25-2017, 11:20 AM   #5
Wulfaz
Here are a few pictures. I haven't had a chance to clean the truck up yet.
Old 02-25-2017, 11:41 AM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I would say someone built that. It looks to have 1 ton front end and the rear inner fenders have been widened. I'm not sure about which frame it has under it. More pics please. I like it, nice truck.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 02-25-2017, 11:51 AM   #7
yuccales
yuccales's Avatar
That is one cool, beefy looking rig! Home made, yes. Well done,yes.
yuccales is online now   Reply With Quote
Old 02-25-2017, 12:10 PM   #8
67swb72klb
67swb72klb's Avatar
Research the VIN# and the frame numbers too there is a partial number on the frame on top by the steering box... Nice truck!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-25-2017, 12:26 PM   #9
weq92f
weq92f's Avatar
Didn't come from the factory like that! Very likely somebody built that specifically for some working purpose.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-25-2017, 03:53 PM   #10
custom10nut
custom10nut's Avatar
Cool truck!
Carefully pull that dent, shine it up, and run!
Sit it out in the sun sun, use suction cup pullers and a rubber mallet, and that dent should come out easy.
custom10nut is offline   Reply With Quote
Old 02-25-2017, 04:14 PM   #11
El Dorado Jim
definitely a custom built rig,very nice! all 1 ton running gear
Old 02-25-2017, 04:19 PM   #12
James the III
Dig it..
if not going to use it as a dually..
put micky steam rollers on the back..
James the III is offline   Reply With Quote
Old 02-25-2017, 04:56 PM   #13
RGT
Very cool truck
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering.
RGT is offline   Reply With Quote
Old 08-30-2021, 09:33 PM   #14
jondancer
I want that , do you still own it ?
jondancer is offline   Reply With Quote
Old 08-30-2021, 10:06 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
He hasn't been on the board since 2017, shortly after he posted this.
Leon
Old 09-01-2021, 06:51 AM   #16
It probably was a cab/chassis style frame and some one added the longhorn bed and cab setup. A few folks did that years ago on here. I almost bought one..
Old 09-01-2021, 10:00 AM   #17
tdangle
tdangle's Avatar
My guess is that it was a cab/chassis model that had a camper/motorhome on it. Someone took it off and then swapped cabs since the back of the cab was cut open. I like the look, especially with the widened tubs in the back. You can verify if the cab vin matches the frame vin, the frame has the last few numbers of the vin on the drivers side top of the frame right behind the motor mounts
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-01-2021, 08:47 PM   #18
factorystock
factorystock's Avatar
Old thread, but interesting. It appears somebody had the big dually idea before 1973. Chevy toyed with the idea for the '72 model year, GM artist rendition shown, but it never materialized.
factorystock is offline   Reply With Quote
Old 09-01-2021, 09:34 PM   #19
CG
BlahBlahBlah
Right click ... save. Cant believe Ive never seen that pic before, thanks.
Old 09-02-2021, 09:28 PM   #20
hugger6933
Not a longhorn bed werent they all wood floors?[ Floorboards] I thought all of the longhorns had a visible seam and wood floor I need on for my one ton sitting at my shop I have a pair of step side fenders I was gonna make a dually type bed for it but it hasnt happened yet. Oh by the way, nice four eyes. Jim
hugger6933 is offline   Reply With Quote
Old 09-02-2021, 09:51 PM   #21
Either it's the whole 1/2t with the 1t axle and front end swapped under or it's a 1t chassis that was shortened to 127" WB. I think it's the first choice. Can you see evidence of the frame being cut and welded? EDIT: Oops. Forgot this is an old thread.
Old 09-03-2021, 04:39 PM   #22
factorystock
Yes, kind of a rare configuration, introduced in '63, disappeared somewhere after '68? Anyway, IMO, it is a regular C 20 which the previous owner added front adapter hub off a C 30, and threw some duals on back of the standard narrow C 20 axle, hence extra wide inner fender tubs for clearance. Wondering if it was done for show or if someone did it for extra stability when towing or hauling something. We'll never know, but it's an interesting concept, and not something you see everyday. Note photo is a '63 C 20 with coil rear end.
Old 09-03-2021, 05:07 PM   #23
CG
BlahBlahBlah
On my 71 C30 factory duals if I wanted to put a box on it it will require widening the bed tubs and the outside tire will stick out just a tad past the fender lip.
Old 09-03-2021, 09:24 PM   #24
mr48chev
mr48chev's Avatar
It looks like the OP was only on here for 2 days in 2017.
I have to agree that it is a 1/2 ton long bed truck that someone hung 1 ton running gear under. The front end is just unbolt and bolt The rear axle would have to be narrowed to put the dual wheels inside the fenders.
I've seen guys go both ways between 1/2 ton and 3/4 ton running gear under 67/72 trucks. The 3/4 to 1/2 ton because he had a great looking 3/4 ton and wanted to run 5 lug wheels and the 1/2 to 3/4 because he had a camper that was too heavy for the 1/2 ton and his buddy had a banged up 3/4 the same year with good running gear and springs.
They did that one in a weekend and it turned out pretty nice.
My ongoing truck projects:
Old 09-03-2021, 09:47 PM   #25
57taskforce
All about them K’s
57taskforce's Avatar
Now that is some good stuff; that’s the first I’ve ever seen this documented
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
1970, dually
