#26 |
Re: 69C40/build
We're currently making room for the radiator and intercooler we should have it done today I'll post a picture of it with the short nose trucks there sure isn't a lot of room!
#27 |
Re: 69C40/build
We modified the course support today to accommodate the intercooler and radiator sure not a lot of room inside of these things!
#28 |
Re: 69C40/build
I started the frame brackets to mount the bed & I changed out the leaf springs to 3/4 ton springs I'm going to install 4"drop hangers and shackles and raise them another 3" inches for a 7"rear drop!
#29 |
Re: 69C40/build
Waiting on the 4"drop hangers and shackles I raised the existing ones 3"
#30 |
Re: 69C40/build
Just a rendering of truck but it's pretty much spot on
#31 |
Re: 69C40/build
Just a rendering of truck but it's pretty much spot onAttachment 1624496
#32 |
Re: 69C40/build
Very cool build! Not everyday to see one of these trucks so I'm in.
#33 |
Re: 69C40/build
A little perspective on ride height!
#34 |
Loves all GMC trucks
![]() Join Date: Jul 2010
Re: 69C40/build
Digging the vibe of this truck!
I can't wait to see more pics and progress!
Mike If your helping someone and expecting something in return... your doing business not kindness! |
#35 |
Re: 69C40/build
Tires and wheels are ordered the ride height is close now it's time to design the fuel tanks
#36 |
Re: 69C40/build
Very Nice Truck . I have a C50 build in heavy haulers . I have a chassis like yours for a 56 i am building , wish i had used it on the 1970 . Ended up using a 86 dually chassis , alot more work for sure . keep up the great work .
1970 Gmc6500 1951 chevy gasser 1986 crew cab dually 1956 Gmc extended soon to be ? |
#37 |
Re: 69C40/build
#38 | |
Active Member
![]() Join Date: Sep 2013
Re: 69C40/build
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
#39 |
Re: 69C40/build
Don't want to high jack this awesome thread . Mine is under heavy haulers .
#40 |
Re: 69C40/build
Thanks guys! Nice build shortchev I look forward to seeing it done I can imagine how difficult your build is grafting that front end on that chassis can't be fun? C10-72 II no this is the only thread on this project. I'd like check out your 68 though!
#41 | |
Re: 69C40/build
#42 |
Re: 69C40/build
We're in the process of dropping the wheel openings 2 1/2" to fill the gaps!
#43 |
Re: 69C40/build
subscribed this is cool
#44 |
Re: 69C40/build
Got the tires today the wheels next week!
#45 |
Re: 69C40/build
#46 |
Re: 69C40/build
I bought 22.5x8.25 Alcoa semi wheels and had them milled down to 22x9!
#47 |
Re: 69C40/build
Tires are 285/45/22 Toyo proxie s/t-05
#48 |
Re: 69C40/build
Mounted the wheels and since we decided on wider wheels we need to widen the rear fenders!
#49 |
Re: 69C40/build
Had to get the fender just right!
#50 |
![]() Join Date: Dec 2012
Re: 69C40/build
unbelievable build!! You are very talented!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
