12-20-2016, 10:32 PM | #176 |
Re: Boyd Welding Fuel Tanks: Limited Time Group Buy
12-22-2016, 12:36 PM | #177 |
I'm way late to the party but any chance to still get one of these at Black Friday pricing? Needing one for a 71' center fill add on option
12-22-2016, 12:38 PM | #178 |
01-02-2017, 07:01 PM | #179 |
I'm also interested------
Posted via Mobile Device |
01-02-2017, 09:04 PM | #180 |
Can you get me a price shipped on a 67-72 efi fuel tank?
01-03-2017, 07:08 PM | #181 |
If Im going with an LS conversion in my '65...do I need the 0-90 OHMS sending unit? I'm pretty sure the older SBC are 0-90...and assuming the LS1 would be the same? Can I get a quote for an efi tank for a 65 with an LS1?
01-03-2017, 08:15 PM | #182 |
It all depends on the gauges you plan on using, not so much the engine. If you plan on running stock gauges, then a 0-30 will be ideal. If planning to use Dakota or most other aftermarket gauges, then I would go with 0-90 ohm.
01-04-2017, 08:40 PM | #183 |
Can I get a price on 67-72 STANDARD (BED FILL) NON-EFI
01-05-2017, 10:52 AM | #184 |
The carb tanks runs $349, plus whichever options you choose.
http://www.azproperformance.com/Boyd...ill-14001.html |
01-08-2017, 05:26 PM | #185 |
So nice!
01-08-2017, 07:44 PM | #186 |
I want to thank Travis publicly. I was sent the wrong tank on accident, he immediately said no prob, hooked me up with a return label and is having a new tank sent out. Great customer service guys! Thanks
01-13-2017, 05:44 PM | #187 |
02-26-2017, 11:29 AM | #188 |
Can you quote me an efi tank for a 69 c10. Efi, rollover vent, 0-90ohm, center fill but angled 45* to the rear (and also a separate quote with the normal center fill) both with black powder coat.
02-28-2017, 11:23 AM | #189 |
Good talking with you and thanks for the order.
03-03-2017, 01:03 AM | #190 |
Thanks again. Will Boyds send out a shipping notification when it ships? I only ask because I will be in Italy from the 16th to the 1st.
03-03-2017, 08:33 AM | #191 |
Soooo wish there was a cheaper way to get these to Australia!....id be all over getting one ASAP!...
03-03-2017, 12:19 PM | #192 |
I defiantly recommend the tank, I installed mine about a month ago, prior to install I polished the tank with some metal polished and got it to look just about like chrome, defiantly a nice piece: metal:
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 |
03-03-2017, 03:38 PM | #193 | ||
Nice! |
03-03-2017, 04:22 PM | #194 |
If you'd like, tens us your full address to: sales@azproperformance.com and can get you a shipping quote.
Pretty sure have done before off eBay......shipping cost was more then cost of tank!!😳 |
03-06-2017, 08:47 AM | #195 |
Can you confirm the Boyd tank will fit a leaf suspension short bed? Also, does the rear cross member need to be moved back to install the tank?
Could I get a quote for a Boyd EFI/Side Fill with: 1) sending unit 2) mounting kit 3) roll over vent 4) powder coated black Shipped to 03809. Thanks.
71 Cheyenne SWB |
03-06-2017, 10:27 AM | #196 |
I also have a 72 c10 shortbed leaf spring with wood floor and was wondering if and any mods were needed to install.
03-06-2017, 07:36 PM | #197 | ||
No mods needed, as if I remember right, the rear crossmembers are in the same location. The tank is 19" from front to back. |
03-11-2017, 11:39 AM | #198 |
i have an existing boyds tank in my 66 (non efi) i am interested in flush mount bed fill kit part 27042.my existing tank has twist on cap not threaded.will this fill kit work with my tank? thanks dan
03-13-2017, 12:41 PM | #199 | |
http://www.azproperformance.com/Boyd...Kit-27042.html Travis |
03-13-2017, 04:17 PM | #200 |
Does Boyd's offer these for a '59 GMC with a side fill option? Also a pump suitable for LS engine and shipping to zip 30710? Quote would be great.
Mark |
