Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-31-2017, 01:43 PM   #601
DWilbur
Re: Project 68 k10 LWB..aka "The Hulk"
I should clear up my question the lower radiator hose is for LS engine swap with stock radiator.
DWilbur is offline   Reply With Quote
Old 01-31-2017, 02:03 PM   #602
First c10
First c10's Avatar
Yes that is what I am using. It's a stock replacement. Aluminum radiator.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-31-2017, 09:18 PM   #603
87max
87max's Avatar
That color is going to look great
87max is offline   Reply With Quote
Old 02-01-2017, 12:28 AM   #604
First c10
First c10's Avatar
Thank you! I hope so. We are going to have a white pearl top.
Picked up the cab today/tonight. Got it in the shop. Now need some time to put it on the frame. Can't wait.
GO GO!!!
Old 02-01-2017, 12:13 PM   #605
7dee2
7dee2's Avatar
Good deal! Mocking up all of your sheet metal the plan?
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 02-01-2017, 12:42 PM   #606
First c10
First c10's Avatar
Yes... the plan is to put it on the frame and mock up the sheet metal for the last time and blow it apart to jamb them and re assemble and paint.
Problem is the bed situation..... still not sure what to do with it yet.
GO GO!!!
Old 02-20-2017, 09:00 PM   #607
First c10
First c10's Avatar
Ok don't laugh. Since it was pouring down rain outside I didn't want to take the cab outside so I made this work inside dropped right on no problems.
GO GO!!!
Old 02-20-2017, 09:06 PM   #608
First c10
First c10's Avatar
Talk about a tight fit!!! I know I measured many many times. But man fit in nice and tight but enough room to slide my hand in around the back of the motor.
The only thing that is to close for me is the return transmission line. It is hitting the cab. So I ordered a 45° elbow that will replace the straight fitting and we should be good.
Now for a question. What is the best way to square up the cab to the frame?
GO GO!!!
Old 02-20-2017, 09:11 PM   #609
First c10
First c10's Avatar
After getting all the body bushings and bolts in I stood back and as was like wow!!!!
I have not seen this truck assembled this far.
Remember this truck is coming together from pieces, non of these parts have ever been on the same truck together.
GO GO!!!
Old 02-21-2017, 10:59 AM   #610
7dee2
7dee2's Avatar
Wow, looks great! Laughed just a little bit, very ingenious Scott!
Not a body guy but I would think you can check inner rocker to frame for side to side and some squaring. That’ll get you close but needs the front clip and then a bed to tell the whole story.
Brett
Old 02-21-2017, 08:03 PM   #611
First c10
First c10's Avatar
Thanks Brett, to tell the truth I laughed also...... in fact if something bad would have happened I would not have posted the pictures!!!!lol My son came to help and was like "Dad that looks shady!"
All we did was raise and lower as it didn't move other than that.
I did what you were saying regarding trying to square the Cab to the frame.
I just wanted to make sure that it was even on both sides and not needed to be like a 1/2" to one side for some reason.
GO GO!!!
Old 02-22-2017, 11:58 AM   #612
First c10
First c10's Avatar
Good morning guys.
Had some time last night to get the doors mounted and adjusted. Thought what the heck keep going!!! Got the fenders on and grill installed. Need to adjust the passenger fender a little more but couldn't do it by myself. When I left last night it was 1/8" out of square. Not bad for doing it by myself. The aftermarket radiator support needs some work holes don't line up etc. I will drill them out and repair after I blow it apart for paint.
Feeling pretty good about it. I took a picture of the truck and sent it to him with the caption "check out MY truck". LOL. With sports, FFA and homework he doesn't have much time to help.
Oh and he said. "Your crazy"
GO GO!!!
Old 02-23-2017, 12:32 AM   #613
First c10
First c10's Avatar
Anyone up for a little window frame bending????
Talked to my body guy. He said it was looking good. Gave me a little encouragement on getting the window frame correct. I knew I had to bend it but wanted him to verify. 10 min after he left. It was ready!!!!
Now I need to get the holes in the fenders welded up and get them either dipped or blasted. I am going to clean up what I can but will soak the seams/pinch welds with rust converter.
Bad thing is no one is close to me that does that stuff. I guess I could just blast them with media from tractor supply or soda blast them.
any ideas?
GO GO!!!
Old 02-23-2017, 10:17 AM   #614
7dee2
7dee2's Avatar
Very, very nice Scott, great stance!
Kind of a PITA, but if you've got a compressor that'll keep up you could blast those parts yourself?
Brett
Old 02-23-2017, 05:24 PM   #615
First c10
First c10's Avatar
Thank you.
Yes I have a large 80 gallon 5.5 hp compressor. Just not sure the best media to use and where to get it. Also. Be nice to just drop off and pick up lol.
GO GO!!!
Old 02-23-2017, 05:52 PM   #616
DWilbur
I use black oxide for blasting. Tractor supply is the cheapest place to get it. or fine grit sand. I also filter the black oxide and reuse it several times to save cost.
Old 02-26-2017, 12:03 AM   #617
First c10
First c10's Avatar
Until I figure out what I am going to do with the blasting. I went ahead and welded up the holes on the door from the trim.
More to come.
GO GO!!!
Old 02-26-2017, 01:10 PM   #618
87max
87max's Avatar
I do the exact same, sometimes the grit is critical depending on blaster type so it flows. I put down 6 mil plastic outside for easy sweeping then run it through a stainless colander that happened to fit perfect in the top of my blaster.
Old 02-28-2017, 11:10 AM   #619
First c10
First c10's Avatar
I picked up some 80 grit Garnet at work to see if it would work. A little aggressive but not to bad. The Garnet was nice to clean up. I will see if we have anything a little finer and try it. Tractor supply was out of the black oxide so I will have to wait.
I was able to get the passenger fender cleaned up on the inside. I am going to coat the pinch welds/lap joints with rust encapsulator. I think that it will help keep the fender from rusting in places I cant get to, to clean up the rust. my paint and body guy said that it would not hurt.
Sorry no pictures today.
GO GO!!!
Old 03-06-2017, 09:42 PM   #620
swamp rat
swamp rat's Avatar
That's exactly what i have been doing with my stuff, Vic suggested a product called GEM, its a liquid that has wicking properties so it work its way into the pinch welds and lap joints pretty well. http://www.gemrustkiller.com/
Per the Black Diamond, I think i bought the medium grit then decided it was to course so bought some fine grit.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-07-2017, 01:48 AM   #621
First c10
First c10's Avatar
Hey Mike thanks for the link. I will look into it. I know my body guy uses rust mort. But I like the idea of the wicking properties you spoke of.
An update.
I was able to get the doors and fenders and cowl aligned about as good as I can. Got all the gaps as close as I can get. So now I have a few questions. Is it common to cut up or weld up on the cowl to make the gaps correct? I am trying to keep the gaps at 3/16" no more than 1/4"
Check out the pictures of the passenger side.
GO GO!!!
Old 03-07-2017, 01:55 AM   #622
First c10
First c10's Avatar
The driver side gaps are much better. I was hoping that both would be this good but no luck.
GO GO!!!
Old 03-07-2017, 02:03 AM   #623
First c10
First c10's Avatar
Motor Monday picture!!!
Ok so I got the hood hinges installed. Now time to square it all up and put the hood on and check fitment
GO GO!!!
Old 03-07-2017, 05:35 AM   #624
swamp rat
swamp rat's Avatar
I have seen a couple builds here where they sliced and diced the cowl a bit, nothing I have done so I can advise much on that. It does look like that maybe the addition of a length of welding rod to the rear of the passenger side may help get that gap to the door closed up a bit.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-07-2017, 11:00 AM   #625
7dee2
7dee2's Avatar
It looks great, thinking your gaps are well within GM specs! I concur time to see what the hood will tell you?
Brett
