Old 02-20-2017, 09:14 PM   #201
Cape Codder
Cape Codder's Avatar
Re: Shucks First Build
Inside of panels usually gets one coat of clear but also a shot of paint down inside the panels if it is my own. When I have a panel off one of my own vehicles I take left over paint from other jobs and spray inside till it comes out between the welds and out the drain holes. Then use the correct color for painting the inside that shows.
Glad to see you have the paint situation squared away it is looking good so far.
Cape Codder is offline   Reply With Quote
Old 02-22-2017, 04:48 PM   #202
Shucks
Shucks's Avatar
Minor update.
Degreased the whole cab and got the windows out.
And so far these fenders absolutely suck to remove
On the other hand, these dried nicely.
C H E V R O L E T
Check out my build thread!
Shucks First Build
Shucks is offline   Reply With Quote
Old 02-22-2017, 06:28 PM   #203
Cape Codder
Looking good , It would suck trying to paint the bed with the fenders on too so get them off. Do you have access to am impact driver. It is a hand held thing you put your bit in engage the screw twist and wack it with a hammer. If you are hitting it hard enough you will probably wack your hand a time or two but they do pretty good at breaking them free. If not soak with penetrent and an impact gun with the pressure turned back a bit
Old 02-22-2017, 06:53 PM   #204
moregrip
moregrip's Avatar
Originally Posted by Shucks View Post
Minor update.
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 02-22-2017, 11:27 PM   #205
Shucks
Shucks's Avatar
I have to have these fenders off, they're rotted inside and they have fuel doors, which LMC makes them without fuel doors, so I'll just go get new ones. What I may end up doing is drilling out just passed the sheet metal and taking a chisel to the head of the bolt, no need to save the fenders.
C H E V R O L E T
Shucks First Build
Old 02-23-2017, 12:15 AM   #206
Cape Codder
If tossing the fenders just cut the fender off close to the bedside,heat the welded in nut with a torch and the bolts will come out easy.
Old 02-25-2017, 12:16 AM   #207
Shucks
Shucks's Avatar
Full day of sanding, bondo, sanding, welding, and sanding.
Snagged a good door to replace that p.o.s aftermarket door I thought was good.
C H E V R O L E T
Shucks First Build
Old 02-27-2017, 09:09 PM   #208
Shucks
Shucks's Avatar
C H E V R O L E T
Shucks First Build
Old 02-27-2017, 09:12 PM   #209
Cape Codder
Making good progress. Who's shop is that ? nice a spacious
Old 02-27-2017, 09:28 PM   #210
Shucks
Shucks's Avatar
Lord knows I wish I could say it's mine... it's my uncles. It has a little spare room I probably should move into considering how much time I spend there. Nice and heated as well.
This is his 1980 he and his son did a while ago just never finished.
C H E V R O L E T
Shucks First Build
Old 03-01-2017, 11:01 AM   #211
Shucks
Shucks's Avatar
Anyone done this tire and wheel package? The rear backspacing seems much but I'm curious if anyone thinks these would work on my stepside
C H E V R O L E T
Shucks First Build
Old 03-01-2017, 11:10 AM   #212
aggie91
I'm just glad to be here!
aggie91's Avatar
Based on the wheels I used on the '82 stepside I built a few years ago, I would find some 1/2" spacers to run that rear wheel with the 5.75" back spacing. We had a 5.5" BS and used a 1/4" spacer and pushed in the inner bed side about 1/4". We ran a 315/35-20 tire in the rear, so a 295/40-20 tire would look good too and give you about 10mm more clearance on the inside.
Use a spacer like this one:
http://www.ebay.com/itm/2pcs-1-2-Che...FWO6yD&vxp=mtr
You might need to get longer wheel studs to make up for the spacer. We used a Dorman replacement stud that was longer. I will see if I can find the one we used.
Look at the pic in my "Sunburn" thread in my signature.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-01-2017, 11:46 AM   #213
Shucks
Shucks's Avatar
Cool, thanks for the links. I dig those wheels you and Korbin put on that truck, that thread is also a big inspiration, you guys did a fantastic job on it. Looks like mine will be looking really close to how his is!
C H E V R O L E T
Shucks First Build
Old 03-01-2017, 08:15 PM   #214
Shucks
Shucks's Avatar
Just keep on keepin on... endless work.
Bye bye holes
C H E V R O L E T
Shucks First Build
Old 03-06-2017, 11:00 PM   #215
Shucks
Shucks's Avatar
Finally got this taken care of...
Can you see why these needed to be removed?
Both sides are done, only pic I have.
C H E V R O L E T
Shucks First Build
Old 03-08-2017, 05:16 PM   #216
Shucks
Shucks's Avatar
I feel like I should have a huge update since I've got hours and hours in this body work but it sure doesn't show it. I had a professional painter come out and take a look and his biggest thing he told me was I wasn't spreading my filler past the damage or the weld wide enough. Sure I covered the dent but it didn't flow into the body correctly. So basically I have to start again... I've probably got my over 100 hours in it and I can hardly tell it...Bummer
C H E V R O L E T
Shucks First Build
Old 03-08-2017, 08:11 PM   #217
Cape Codder
Effort = Results A sign I saw on the wall in Roger Penski's office when he did a TV interview. Keep at it you will get better as you go.
Old 03-08-2017, 09:08 PM   #218
Nick_R_23
Nick_R_23's Avatar
That's how you learn, looks great so far though!
Old 03-09-2017, 10:27 AM   #219
N2TRUX
Happy to be here
N2TRUX's Avatar
You dont have to start over, you have to finish up what you started. Some of those areas could be improved with a liberal dosage of filler primer.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-09-2017, 10:34 AM   #220
aggie91
aggie91's Avatar
I see a lot of time and work put into it so far. Body work is one of the items that takes the longest time to see actual results. Spending the time on prep and body work will show in the final paint job. The actual color spraying is only about 5-10% for the finished job.
One suggestion that I could make based on what your pro told you. Don't "start over". I would spray a couple of coats of a high build primer such as Slick Sand, apply a light coat of a contrasting primer color or guide coat. Block it out with a long board and 180 grit paper. The guide coat will show you the "low" spots and the "high" spots will be all the way thru the slick sand.
This will show you where to apply a light weight feathering filler to the low spots and repeat the process. Take a look at the last few pages of this thread, it is a great source of pics of the process I just described:
http://67-72chevytrucks.com/vboard/s...d.php?t=386569
You are doing a good job, don't give up hope!
Karl
The LST Challenge:
Old 03-09-2017, 01:56 PM   #221
daddyjeep
daddyjeep's Avatar
I feel your pain slightly. I am just doing body work on a couple patches right now and it just seems to take forever to see any results. I am not even expecting good results. I am just taking care of some rust spots so I can get mine inspected soon. I am not looking forward to final body work and paint prep. That is still a ways off for me.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-09-2017, 02:22 PM   #222
Low Elco
x2.. Hit your repair areas with a couple good rounds of Slick Sand, and hit it with 80 on a long block. Levels er out goooood.
Low Elco is offline   Reply With Quote
Old 03-09-2017, 06:32 PM   #223
Cape Codder
Been sanding bondo for a living since 1974. Putting primer on before the filler is straight is a waste of materials. Use guide coat or just lightly spray with black spray paint form about 18'' away that will show where you need more filler. Primer is for smoothing out sand scratches not straightening panels.
Old 03-10-2017, 08:16 PM   #224
Shucks
Shucks's Avatar
Thanks for the replies guys. It all helps to get a little motivation! I got a ton done in the last couple of days. Long days of sanding and spreading but honestly feel really comfortable where I'm at. Three quarts of body putty later and The roof, doors and fenders all turned out way better than I planned. Did the guide coats and fixed a lot.. Guide coat saved my butt! After I finish sanding this red door I'll be priming the cab again, doing the fenders and doors and getting it ready to paint.
How I have to drive home every night because I'm a fright.
C H E V R O L E T
Shucks First Build
Old 03-20-2017, 09:07 PM   #225
Shucks
Shucks's Avatar
Update day
C H E V R O L E T
Shucks First Build
