#1101 |
Re: Dutch '59 Fleetside Longbed
I've made some pics of the striping, in case of interest
![]() I know it isn't truck related, but this is what I love to do... Pic #1 is the car, 1948 Plymouth, chopped...
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1102 |
very nice art.
Kim |
#1103 |
![]() Join Date: Mar 2011
Looking good there buddy...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1104 |
A320 Pilot/USAF Retired
Nice lines!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#1105 |
![]() Join Date: Jul 2012
Looks really good Kees! You are very talented.
#1106 |
Very nice Kees Do you do it all free hand or do you draw it out first?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1107 |
Nice clean lines,and a really cool car!
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1108 |
That is tits man!
My Build: 57 Chevy Pro-Street |
#1109 | |
Thanks a lot guys!!!
Sometimes when I'm painting I add stuff along the way, sometimes I get rid of things. And the plus side is that I see it on the car (or whatever) before painting it. I want it to be look good, I'm just an amateur you know ![]() Here's a pic of the drawing on the car, the way I do it:
#1110 |
No updates, but I decided to go on airride.
Main reason was the sloppy rear coilovers. I did calculate some things and the outcome was that a complete airride was about $250 over only adjustable coilovers in the back. The airride would be on all corners and all are switched independent. There is no bolt on kit for Jags, so I have to make it myself. I emailed a few people around the world, they all been a great help, but I have to find out myself how to get it in. Well, that's Hot Roddin', aint it ![]() I ordered two Double Neede gages, four universal On-Off-On momentary switches, four 3 position 5 way solenoids, a pressure relief valve and an electric pressure on-off switch for the compressor. When this is inhouse, I'll get the rest such as compressor, airtank, airlines and air bags. All these I will buy in Holland, things I already ordered come from overseas. Hope to have it all ready and working before our trip to the UK. In the meantime I finished the '48 Plymouth. Only thing left to do is probably the fenderskirts. They are at the painter, when they are ready, I don't know. I have some pics of the trunk, I post them this evening.
#1111 |
As promissed ,the pics of the Plymouth, for those who are interested.
He's named his car "The Red Devil" so I put a Coop styled devil on there as well, as a present. ![]() Boy, did he like it!! ![]() ![]()
#1112 |
Kees, you are the man, great brush work and the "devel" is super, nice work...Jim
#1113 |
Awesome my friend!
#1114 |
Incredible art work Kees! and that toolbox turned our great as well. Did you TIG the bottom in? I hear aluminum is a biatch to weld
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#1115 |
Fantastic job, Love the devil.
#1116 |
Aluminum is not that bad to weld (just keep it clean!)
#1117 |
Thanks guys!!
The bottom of the toolbox exists out of two plates, TIG welded. The Floor itself is revited in (is this English ?? ![]() My buddy with the '48 Plymouth welded it, my TIG machine only has DC current, for TIG you need AC current.
#1118 |
We're on it again!!
This time it's sorting out the airride. Front axle shouldn't be a problem, drill the springcone out, make a new lower bagmount and your ready to go...so they say ![]() We'll see if that's true. I started today with dismanteling the Jag suspension, took the springs out and made a few templates for the rear bags. They have to go on the outside of the frame, so I've got to re-route the entire exhaust, bummer..... Question: If I dump the exhaust gasses in front of the rear axle, would it be much louder then? I now have a double system with H-pipe and mufflers at the very back, it is a nice rumbling sound, not hard, but a deep tone. Pic#1- I managed it to get it up high with no trouble ![]() Pic#2- The Jag IRS with full suspension on... Pic#3- The Jag IRS suspension without the coilovers, not much room for bags though.. Pic#4- How I undo the front LCA of the springplate, I find this easier then a bolt through the middle of the spring as Jag says.(pics is on it's side ![]()
#1119 |
also not available for Land/Range Rover? seeing they used a lot of parts from Jag, maybe an easier conversion
#1120 |
Correct, but they don't have IRS like this.
I think I already figured it out....
#1121 |
If you dump your exhaust under the truck you will get a drone more than a rumble and it will be louder.
#1122 |
![]() ![]() Join Date: Nov 2008
You're hugely talented, Kees. Congrats!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#1123 |
Thanks Dan!!
I wouldn't say that myself.... Thank you Lower. I can live with a bit louder, but don't like the drone..
#1124 |
Busy sorting out airride on the Jag IRS.
Made some templates and had them laser cut. All fits nice, now I can put the parts in the right model and bolt it together. Weld some brackets on the framerails and we're good to go ![]() ![]() I wish it was that easy.... On the front I saw a little rust hole where the springcup meets the IFS. So to prevent any damage later on, I changed my plans. I'm gonna make an extra plate on the IFS and bolt a springplate to it. You see it when I come to that. I'm now three days in the airride work and it almost goes to plan ![]() Pic#1- freshly cut parts, to be remodelled a bit... Pic#2- had to cut a piece of the hubcarrier away to make room for the bag. To be continued..
#1125 |
Nice pieces Kees!
That truck will look So awesome sitting on the ground!!
