07-03-2014, 12:19 AM | #1 |
Nv4500
Hey guys and gals i have looked everywhere .Whats the best way to hook up a speedo on my2wd 68 GMC mechanical speedo. The nv4500 from a p 30 van that i'm putting in has a VSS electronic speedo out put.Has any one converted this trans to mechanical?Do i have to change the whole main shaft and housing?Has anyone converted the stock mechanical speedo to a electronic ?If so what parts did you use?I know i can get a converter from Abbott but they are over 300.00!I only paid 600 for my trans im trying to do this on a budget .Any help would be greatly appreciated.Oz
07-03-2014, 01:22 AM | #2 |
Re: Nv4500
You will either have to swap in an electronic speedo or get one of those cable driver kits. Cheaper alternative is to swap the speedo, you can get it for less than $200, then you would have to modify your gauge cluster to fit. Any of the swaps for mechanical speedo on the trans will be expensive.
07-03-2014, 01:56 AM | #3 |
Re: Nv4500
Have you done one?I'm wondering if i can remove just my stock speedo and replace it or if i will have to replace the whole cluster ?Thanks for any and all info.I am looking at replacement speedos and wonder if they will work with the NV4500 vss or if you need an additional adapter for the signal looking at GPS also .Thanks Oz
07-03-2014, 07:18 AM | #4 |
Re: Nv4500
I almost sure that a speedo gear can be placed on the shaft where the reluctor is now on the mainshaft of almost any of the electric trans. also a speedo housing can be had the same size as the hole size in the case to hold the driven gear and to screw the cable on to. Jim
07-03-2014, 08:49 AM | #5 |
The Older Generation
Re: Nv4500
You could use a GPS speedometer, that way it wouldn't matter what transmission, rear end, tires & wheels or anything else you had.... Here are a couple of threads on them. http://67-72chevytrucks.com/vboard/s...d.php?t=421745 http://67-72chevytrucks.com/vboard/s...d.php?t=453615 Most of the installed pictures in Andy4639's thread are down toward the bottom. He ended up using the full set of Speedhut gauges. LockDoc
07-03-2014, 09:45 PM | #6 | ||
Re: Nv4500
Also, if that NV4500 is from a later model (one with a PCM) it might not work with an aftermarket speedo. I think the year cutoff is '95? Not sure. Hope that all helps. Last edited by 69SCSS; 07-03-2014 at 09:54 PM. |
07-11-2014, 11:43 AM | #7 |
6>8 Plugless........
Re: Nv4500
Have you removed the sensor and looked inside to see if there is a gear on the out put shaft? I've removed the vss from several dodge 47rh's and replaced them with mechanical speedo drives from 727s. I know you can do it on the transfer case as I have done it too so I don't see why you can't do it on the nv4500. Usually the gear difference is the tooth count to change the ratio, and on these typically you replace the one on the vss or cable adapter, not the out put shaft on these.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-11-2014, 11:58 AM | #8 |
Re: Nv4500
Wow i will certainly look all the research i did said the vss had a reluctor wheel not a gear .Advanced adapters said i would have to change the shaft because the gear was a different size on the shaft than the reluctor wheel for the vss .Hope your right!Thanks for the info.Oz
07-11-2014, 12:21 PM | #9 | |
Re: Nv4500
07-11-2014, 07:11 PM | #10 |
Re: Nv4500
All the NV4500's I mess with are from dodges. I don't know if that will make a difference or not. Good luck.
07-18-2014, 03:40 PM | #11 | |
Re: Nv4500
In the end you get the ability to dial in your speedo/odo accuracy to 0.5% by using a GPS to calibrate. This is nice because you’ll never have to worry about gear or tire diameter changes screwing up your speedo cal…
1965 C20, 350 cid, '71 front Disc brakes, NV4500 5-spd, 4.10 FF 14-bolt |
03-18-2017, 06:10 PM | #12 | |
Re: Nv4500
I am looking at using a speedo gear set from an SM465 and modifying the tail housing on the nv45 to accept the set. The geometry looks possible but I'm uncertain if the beefy reluctor wheel serves any purpose more than holding the reluctor teeth. For example, it looks like it might be built to reinforce the output shaft in which case I may not want to cut the reluctor wheel or turn it down to the necessary diameter. I believe the dodge gas version had no reluctor wheel and it seems to be preferred so I'm assuming that the Dodge version shaft diameter is fine without the beefy, pressed on reluctor wheel that GM uses. If those assumptions are correct then I can cut the reluctor wheel sleeve where the teeth are and insert a speedometer drive gear set. That all assumes that the reluctor wheel is NOT designed with the intention of providing additional support to the output shaft. I really do know if it can be cut without sacrificing the strength of the output. |
03-18-2017, 06:44 PM | #13 | |
Re: Nv4500
Please keep us updated on the progress.... Thanks, LockDoc
03-18-2017, 07:35 PM | #14 |
Re: Nv4500
I will, rain or shine. I'm hesitant because I do not have a dodge gas version to compare the output shafts. Finding design specs on the outputs, (specific lengths and diameters) is problematic.
I am wondering what the diameter of the dodge shaft is at the location where the speedo drive gear rides. If the dodge shaft is reliable without the beefy reluctor wheel used on the GM versions, the reluctor wheel may not be structurally important. I know the sleeve is pressed against the fifth gear via the yoke nut, but that can still be achieved by a two piece spacer with a gear set between them. These are just thoughts and I really don't know if it will work, but it looks like it might. |
