#1026 |
![]() ![]() Join Date: Jul 2002
Re: Project two tone.
Nice going TJ. Slowly going back to being a truck again!
#1027 |
![]() Join Date: Mar 2013
Thanks Palf!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#1028 |
Looks great Brotha!!! Enjoy the coming year!!!
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#1029 |
Thanks Brotha!
![]() Little early, but Happy New Year folks! Tiny update to end the evening. ![]() ![]() Later guyz. ![]() ![]()
#1030 |
Do you have a build up on your motor or did I miss it. I am redoing my 65 ickup. It has had a stock 292 and 5 speed in it for about 20 years and want to update the motor. What did you use for pistons and a cam?
Thanks |
#1031 | |
Head work: 1.94 intake and 1.60 exhaust valves. Lump ports .030 shaved off the bottom BBC screw in studs Comp cams 1.75 ratio bbc roller rockers Z/28 valve springs Block work: zero decked .040 over ross forged aluminum pistons. .170 dish and 100+ grams lighter than stock Stock rods balanced and refitted with arp studs and bolts. Crank ground and balanced. Comp cams 268H 219@.050 .499 lift 110 lobe center Comp cams lifters Smith brothers pushrods. Aluminum timing gears Clevite rod, main, and cam bearings. Melling stock type oil pump. Misc: Clifford Intake and short tube headers 625 CFM demon carb DUI 50K HEI 12bolt.com finned aluminum valve cover. ![]()
#1032 |
Thanks. My head is the same as yours but didnt shave anything off it. What compression were the pistons? Do you know what final compression ratio is? Have you put any miles on the motor yet? Happy with it?
#1033 | |
#1034 |
Hi guys! Well it has been awhile since the truck has been touched. Weather took a turn for the worst and work was super slow.
Spring is around the corner and the weather should be getting better soon which means....Painting time! ![]() So plans are to fire up and break in the 292 sometime within the next two months. Shooting for May. Already getting the ball rolling. Got a list of the last needed parts to get her running and it's already getting smaller. ![]() This weekend I will be doing some small work on the truck. Today I picked up a new starter, hose fittings, fan belt, thermostat, and some other misc stuff. Parts are on the way from Classic Parts and should be here sometime this coming week. Also with the help of my dad I'll be setting the cab right side up on the stand to start working on the floor this weekend so I am excited about that! Hope to have the entire cab in primer late spring early summer and then onto painting. ![]() Lot's to do folks! Until next time! ![]()
#1035 |
Looking forward to the vroooooooooom
#1036 |
#1037 |
Get after it Brotha!!!
#1038 |
Thanks brotha! Good to hear from ya!
![]() Hope you are doing well and they aren't working you to hard over there. ![]()
#1039 |
Hey guys! Few small updates to get the week started.
![]() Since I am planning on getting this engine going soon I've been working on getting it finished so it can be ran. Lotta small stuff still needed to be done. Fan belt I had was too long so I got a shorter one and that takes care of That. lol See pic. Also got my new starter mounted up. Still debating on painting it black.....Thoughts????? Got some gasket maker and made some gaskets for the adapter plate and then purchased a 1/2 inch thick gasket for the carb mount. I'll show the reason for all that later this week. Had to raise the carb up a little. Anyhow....also got some brass 90's for the water heating jacket on the intake manifold so I can rout the water hoses better. Oh yeah, siliconed the thermo stat housing in place so that is on permanent. Well all this and not much was done, but it beats nothing at all. lol Should have some better updates this weekend as parts will be coming in and I'll be trying to spend most of the day working on the truck. Weather has been cold and nasty as well so time to get the wood stove fired up! Later guys! ![]()
#1040 |
![]() Join Date: Mar 2015
Making progress!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
#1041 |
#1042 |
Afternoon Gents!
Through out the past week I have been tinkering with the 66. Weather has been bad so cab work has not happened, but parts have been coming in for the 66. ![]() Got my hei dizzy in and plug wires cut to size. Found this braided hose sleeving that I could not pass up so I have been braiding all the hoses. Not quite as good as the real thing.....but looks good none the less. Also got my lokar throttle cable mount installed. ![]()
#1043 |
Waiting on the lower rad hose which should be in tomorrow. Then I'll sleeve it up and install it.
Not much left to do to get this motor running. ![]() Also got the cab set upright again to start working on the floors. Waiting on decent weather now. All for now gents! ![]() ![]()
#1044 |
![]() ![]() ![]() Awesome looking Brotha!!! Waiting on a running engine video... Diggin' those headers... ![]()
#1045 |
T.J. I can't wait to hear that monster, I'm sure you can't wait either...Just takes time...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#1046 |
Can't wait to hear it fire up!!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#1047 | ||
Thanks man! ![]()
#1048 |
Your rolling stock looks really good TJ. I remember when I was working on my cab and you kept saying someday. Know you are there.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#1049 |
Thanks Bret! Yeah, goes slow....but goes fast at the same time. haha
#1050 |
It will almost be a shame to cover that up with a body. Lookin good.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
