#1 | |
Re: LT1 GenV swap
I am happy for you don't get me wrong but geeze its been almost two months..... |
Re: LT1 GenV swap
Looks like I should have my pan soon. Being a shop we ordered
My pan through a distributor. Sounds like they have had the pan for some time and it took us calling then to get the order rolling again.... hope to see the pan sometime next week... |
BMW & ASE Master Certified
Re: LT1 GenV swap
Glad to hear. Got around to the alternator bracket.. going to give this a try. Should work as there are other companies that offer setups like this
![]() And keeps the vacuum pump... just need to reinstall it as i was testing out another bracket idea. Need to remake the power steering brackets to incorporate an idler instead of a tensioner... Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: LT1 GenV swap
Got my pan in last week too. Clearance is perfect for my Porterbuilt suspension. Just waiting on Holley's LT accessory drive now. Looks like a couple more months.
#5 | |
Re: LT1 GenV swap
I only ask because I am running a V6 in a 67. and am anxiously awaiting my new 302-20 |
Re: LT1 GenV swap
Yes, the new Holley LT oil pan fits nicely with the Porterbuilt Dropmember. I'm running a version 7 Dropmember with a 2015 L83 engine in a 1972 Suburban.
Re: LT1 GenV swap
Random bag of spacers i found on the side of the street
![]() Surprisingly they fit the passenger side alternator mount lile a champ! ![]() Used up all the random length bolts i could round up for mock up. Now just need to print the final template and cut it out on some 3/8 plate... Ill re-do the power steering plates later to incorporate an idler pulley for more crank belt wrap.. maybe un necesssry but why not.. Still need to sort out the motor mounts.. 3/8 plate to adapt gen5 to sbc... leaves a 1/4 inch or so between the booster and valve cover.. so tight, i cannot install the beauty cover With this setup, I can keep the vacuum pump and not have to worry about vacuum although i have 2 l83 manifolds and going to try something with one amd post the results of the test Clint
Re: LT1 GenV swap
Last tweak and now im ready to cut them out. Needed to rotate the tensioner a few degrees now it can put the proper tension on the belt.
![]() Clint
Re: LT1 GenV swap
that looks great.
glad to see you are able to work through it all. |
Re: LT1 GenV swap
Looking good.
Re: LT1 GenV swap
I'll have your fuel pump seals shipped out tomorrow. Just noticed your screen name and location.
Re: LT1 GenV swap
Crimping my way through it
![]() Had to make a crimper for the insulation on the sealed connectors ![]() Pic of the crimp looks like a pair of pliLGers squished it, but it's a factory looking crimp! Clint
Re: LT1 GenV swap
Thanks man.
#14 | |
Re: LT1 GenV swap
