03-31-2017, 02:30 PM | #1 | |
Moderator
Re: A/C condenser
Honestly, as long as it's not contaminated by black death, the original condenser is so big it's not necessary to get a parallel flow unit. Flush the old oil and crud out of all the hard lines, Evaporator, and condenser. Then replace the dryer/accumulator. Too bad the A6 rebuilds are of such poor quality. It's such a huge compressor so it'll will freeze you right out of the cabin even on R134a. One thing to keep in mind about replacement compressors is the oil it ships with will be of unknown pedigree and contaminated with water. I always dump it out and re-fill with fresh clean oil from an unopened container just before I close the system up and vac it down or sweep with MIG or TIG welding gas.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-31-2017, 02:37 PM | #2 | |||
Re: A/C condenser
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
03-31-2017, 02:45 PM | #3 | |
Moderator
Re: A/C condenser
Suburbans, Crew Cabs, and Blazers may be another story. HFC152 & Hydrocarbon refrigerants will work very very well using the old tube and fin condenser with much lower head pressures than the R134a. I've used both. If you have to replace the condenser then installing a parallel flow unit is just fine. Whatever replacement refrigerant you run you can't just charge it by weight the first time. I've posted the JungleEddy method to charge with your favorite without overcharging the system. If you use a scale to weigh how much it takes to properly fill the system you can write the charge weight down to make subsequent re-charges easier. I tend to lean toward Ester oil for retrofit refrigerant charges because, unlike PAG, it'll put up with any mineral oil you can't get flushed out of the system.
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-31-2017 at 02:55 PM. |
04-01-2017, 02:43 PM | #4 |
Re: A/C condenser
DieselSJ: Which H6 compressor did you use? It looks to me like the mounting, hose attachments, etc. are different than the A6. Is is a direct fit with no modifications required? Do you have a link to the one you used?
04-03-2017, 02:46 PM | #5 | |
Re: A/C condenser
04-03-2017, 03:06 PM | #6 |
Re: A/C condenser
Thanks for the link. Did it require mods? Autozone shows "does not fit your 1983 C20."
04-19-2017, 01:59 AM | #7 |
Re: A/C condenser
Been looking for a parallel flow condenser with the inlet and outlet on different sides for my 1974 c10. I know I'll have to fab up some brackets, but I can't find one that ha the inlet and outlet on ether end. I guess once its time to get reinstate the a/c i'll ether use the original, or get the one like in the link and have a a/c shop add a line to re route on the the ports on the condenser to the other side of the core support.
Keep on truckin' |
04-19-2017, 09:09 AM | #8 | |
Moderator
Re: A/C condenser
04-21-2017, 10:13 PM | #9 |
Re: A/C condenser
The A/C shop I took my 83 C20 to (see above) said that AC Delco 15-6960 will be a direct fit on my truck. He has an 84 BB. I have no personal experience with this one.
Some customers seem unhappy with it: https://www.amazon.com/ACDelco-15-69.../dp/B000C9DGMI |
