Old 04-04-2017, 07:33 PM   #1
69 c10 - dsm
Driver side brackets on BBC
I'm trying to find a power steering bracket and an alternator bracket that will work together on the drivers side of the motor (454 BBC). Do any of you have them? and if so what kind? Thank you in advance for any information/suggestions.
69 c10 - dsm is offline   Reply With Quote
Old 04-04-2017, 10:23 PM   #2
100%Chevy
Re: Driver side brackets on BBC
Depends on your water pump.
Long or short?
Mike.
100%Chevy is offline   Reply With Quote
Old 04-04-2017, 11:36 PM   #3
69 c10 - dsm
Sorry my bad - it is a short water pump
Old 04-06-2017, 06:08 AM   #4
dennislbrooks
dennislbrooks's Avatar
Are you running a/c on the passenger side? I run a short pump on my bbc with a/c on the passenger side. My alternator runs off the double pulley on my power steering unit both on driver side.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 04-06-2017, 08:08 AM   #5
Mike C
Mike C's Avatar
CPP sells the 68-71 big block power steering setup. It is same as 65-68 Chevelle. You can also run the Chevelle or 67-68 Camaro big block alternator bracket.
I just pieced all this together for my '69 that I'm swapping 427 into. I went with 67-68 375hp 396 pulleys which are deep groove high perf.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-06-2017, 12:39 PM   #6
68is4me
68is4me's Avatar
Look in the for sale section. They come up often. The factory 68-72 mounts will work if you are looking for a factory setup. The factory pump did have a remote reservoir so that might be required when doing the change.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 04-06-2017, 06:46 PM   #7
Mike C
Mike C's Avatar
The CPP kit I mentioned above comes with the wide mount bracket and the pump housing with the remote reservoir. Even comes with a hose.
http://www.ebay.com/itm/282120206049...%3AMEBIDX%3AIT
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-06-2017, 07:19 PM   #8
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
suprachrgd82 is offline   Reply With Quote
Old 04-10-2017, 10:06 PM   #9
Crabass
Take a look at this site, maybe something there that will work for you:
http://www.alangrovecomponents.com/index.htm
Crabass is offline   Reply With Quote
Old 04-14-2017, 10:09 PM   #10
69 c10 - dsm
Thank you everyone for the information. I am still trying to work through the issues. I do APPRECIATE all the input have a Happy Easter!
Old 04-14-2017, 11:13 PM   #11
clay68c10
clay68c10's Avatar
I got Alan Grove compressor mounts for my old 68 BBC truck years ago. Very stout, simple and well made. I wouldn't hesitate to use their stuff again.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
