Old 04-08-2002, 08:19 AM   #1
scull67
scull67's Avatar
Post Pulling rear u-bolts
My rear suspension is a rusted out mess. Found new trailing arms, shock mounts, spring cups. Now it is time to get off the bolts. Any suggestions? Can I grind it off with my grinder? No torch.
Hoboken, N.J.(home)/ Washington, D.C.(work)
scull67 is offline   Reply With Quote
Old 04-08-2002, 10:27 AM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Post
LOTS OF KROIL or any good penitrating oil and a BIG breaker bar. Thats what I used and if you clean the showing treads good once you get it going the'll come off. Stay away from the torch, oooh that hurts
Good Luck
Steve's 70 CST
Soon to have a BB
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 04-08-2002, 05:13 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
lots of the time the u bolts will rustoweld themselves to the rest of the axle/inside the trailing arms.... best way is to just cut them into two pieces and replace with new
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-08-2002, 05:53 PM   #4
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
Torch the bolts and you will be done in less than 5 minutes.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-08-2002, 07:22 PM   #5
scull67
scull67's Avatar
Post
Should I cut off the nuts, or the bolts next to the axle? I was thinking next to the axle. Thanks for the replys.
