04-11-2017, 11:52 PM | #1276 | |
Re: Nik's 62 build
Thanks Tj, they are not what I was thinking of when I bought my truck, but seeing how good they look on many of the trucks on the forum made me realize that they are what I really want, I'm pretty happy with these.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
04-14-2017, 07:48 PM | #1277 |
Re: Nik's 62 build
I've been busy and the weather has been bad for the past week or so and I haven't got much done. But today was the first day of a four day long weekend so I got to work on the panhard bar. I decided to use the stock 60-62 panhard bar and bracket, so I cut the bracket off of the old rear end. I bolted one end of the panhard bar to the frame and made sure the rear end was centred under the frame. I then tack welded the bracket to the rear end and checked to make sure it was all good.
04-14-2017, 07:51 PM | #1278 |
Re: Nik's 62 build
Once confirmed it was in the correct spot I welded it on solid. It still needs painting just as the rear end cover does as well.
04-15-2017, 06:00 PM | #1279 |
Re: Nik's 62 build
Way to go on all counts of your truck build.
The attention to detail and the over all way you have crafted your mods. is very inspiring to me. I'm just plodding along trying to figure out how to do some of what you have done. The power steering sector to frame mod. is too cool. I had wondered about doing something similar and notching the frame to allow the sector to mount like on the late model frame. I had also thought about cutting the frame where the sector mounts on my donor truck and wielding that section into the 62 frame. The way you built your on power brake and clutch master cylinder mount is really impressive as is all your work on your truck and your dad's. I had a very rough time getting the control arm bushings off of my donor control arms too. Congrats. on your progress and on a very nice truck. Also this is one of the best build threads on the forum. Thanks too for your kind words on my thread.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
04-17-2017, 12:41 AM | #1280 | |
Re: Nik's 62 build
Today I spent some time on brake lines, I cut one piece that goes from the proportioning block to the front drivers brake hose. I made double inverted flares on both sides. |
04-17-2017, 12:44 AM | #1281 |
Re: Nik's 62 build
And without a line bending tool I needed some other way to make nice bends in the line. So I just used a piece of exhaust tubing and wrapped the line around, then slid it off. I then installed the line, I still need to pick up some parts such as brake hoses, calipers and pads but it's getting close, should be on the road in no time
04-17-2017, 12:48 AM | #1282 |
Re: Nik's 62 build
Also spent some time disassembling the mirrors, I got the arms all stripped down to bare metal with the wire wheel.
04-18-2017, 08:58 PM | #1283 |
Re: Nik's 62 build
Beauty! Yeah I'll keep you posted on the travel plans. The wife and I will be going to the UK for three weeks in June and I have a family reunion on August, I will be making a plan to travel out to the Okanagan some time in between. I will for sure keep in touch. As for parts, I'll have to figure it out, I'm thinking some nice bed sides to finish up the rust repair on the rear quarters.
04-25-2017, 04:29 PM | #1284 | |
Re: Nik's 62 build
04-25-2017, 04:32 PM | #1285 |
Re: Nik's 62 build
The past week or so I've been under the weather with a nasty cold and haven't gotten much done, but I'm thinking I should be feeling better in the next couple days so I should have a progress update this weekend for you guys.
04-30-2017, 10:29 PM | #1286 |
Re: Nik's 62 build
This weekend I finally was starting to feel a little better after my cold so I went out and worked on the truck. I removed the power steering pump and bracket and gave them a good clean and painted them up in gloss black. I allowed them to dry and them reinstalled them.
04-30-2017, 10:37 PM | #1287 |
Re: Nik's 62 build
I also did some work on brake lines. I bent up this peice out of new line an slipped the old coil over it (don't know what it's really called but it looks like a spring and slides over the brake line).
04-30-2017, 10:38 PM | #1288 |
Re: Nik's 62 build
A close up of the double flares I made.
05-01-2017, 06:45 AM | #1289 |
Re: Nik's 62 build
Glad to hear you are feeling better and able to get in some truck time.
05-01-2017, 11:06 AM | #1290 |
Re: Nik's 62 build
Progress
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-01-2017, 02:01 PM | #1291 |
Re: Nik's 62 build
Glad you are up and about again. Work looks good as always.
05-02-2017, 02:53 AM | #1292 | |
Re: Nik's 62 build
Oh yeah Thanks bill 🙂
05-02-2017, 10:41 AM | #1293 |
Re: Nik's 62 build
Hey Nik. Glad you're feeling better. Truck time is the best therapy.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
05-02-2017, 07:21 PM | #1294 | |
Re: Nik's 62 build
The past few days it's been about 15 degrees and sunny here, I'm glad to finally see the weather get nice after the long winter, It's much more enjoyable working outside. Today I got a lot of work done at school in the shop. I scavenged up some old exhaust systems and cut off enough tubing to finish my exhaust so when I fire the truck up I won't piss off the neighbors again! . I then spent some time building a radiatior shroud. I cut two pieces of 4.5"- 36" 20 ga sheet metal on the foot shear and then used the roller to make them into half circles. I then bead rolled both to add strength and just because it looks nice. Here they are, I'm extremely pleased with how they came out. |
05-02-2017, 07:23 PM | #1295 |
Re: Nik's 62 build
Another shot. I just can't get over how good they look!
05-02-2017, 07:25 PM | #1296 |
Re: Nik's 62 build
I still need to bolt the two pieces together to make it a full circle and make up some mounting brackets but I wanted to test fit it first, here it is mocked up sitting flush against the radiator.
05-02-2017, 09:09 PM | #1297 |
Re: Nik's 62 build
WOW! That shroud is very nice!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
05-03-2017, 12:14 AM | #1298 |
60-66 Nut
Re: Nik's 62 build
Very nice work on the shroud Nik
05-03-2017, 06:32 AM | #1299 |
Re: Nik's 62 build
Great job on the shroud.
05-03-2017, 12:52 PM | #1300 |
Re: Nik's 62 build
Awesome job! Glad to hear your feeling better, the colds have been going around
