Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-08-2017, 01:05 PM   #37
Pacific Fabrication
Pacific Fabrication's Avatar
Re: '73-'91 GM Truck LS Engine Crossmember Kits
When swapping an LSx motor in your '73-'91 GM truck you will quickly discover the factory engine crossmember is in the way.To alleviate this issue we've developed this crossmember kit. This kit is designed in CAD like our other products and cut out on a CNC plasma to ensure fit. The unit is a bolt together modular style for an extra simple install, but does require drilling 4 holes. It ships with grade 8 hardware and is cut from 1/4" mild steel plate.
$299
Pacific Fabrication is offline
