04-21-2017, 02:51 PM | #1701 |
Re: 1969 SuperBurb build-up (Bagged and Blown!)
You will. Just not sure what year....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-21-2017, 06:17 PM | #1702 |
Headliner turned out great! I'm almost to the point I need to get on this in my Sub. Did you need to use a heat gun, or something, to get the plastic to stay curved at the sides?
And was there a certain order putting them in that made things easier? One more! - looking at the plastic now, how would you rate the "look" of it? |
04-21-2017, 09:05 PM | #1703 |
I will try to remember on Monday to check and see if it is possible.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-22-2017, 12:45 AM | #1704 |
C10 Club Tennessee
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
04-22-2017, 08:46 AM | #1705 |
Headliner looks great !!! Let us know if the re-pop ribs work out.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
04-22-2017, 09:47 AM | #1706 | |||
I do too, but with everything lately seeming to take twice as long, no guarantees.... Quote:
I installed them in this order, rear panel, front panel and then the two smaller panels (your choice on which one first). The front panel was the hardest and you really need help to work it in because of the compound curve in each corner. You really need help on this one because you will be "slapping" the panel forward and you need someone to help guide it into the 1/2" metal channel that the edges of each roof board goes in. That's why I did the rear panel first as it easier to install. You have to "slap" it to get it to move also, but not having the curve makes it little easier and it gives you some practice at it. So the way I began installing each panel was to put one side into the 1/2" channel (L or R, doesn't matter). Then, I would let it sag in the middle, which allowed me to put the other side in the channel. The FRP is flexible enough to do this, just be careful. Once both side are seated in the channel, then you can push up on the middle until it fits the contour of the roof. If your panel is trimmed correctly, the tension created by the bow of the roof should hold it up and there should be no ripples in it. I cut my panels a little wide (1/8") to make sure I had plenty of material. Plus, it's always easier to cut more off than to add it back, . It took me several removal/installations and trimmings to get each panel to fit the way I wanted them to. Once you are happy with the fit, then you can start "slapping" it to slide it in the rear groove (front and back panel only). Be careful, because if you slap to hard, you can actually crack the FRP, which is a $35 mistake (don't ask how I know...). You can then fit the two center panels such that when you push up in the middle they are in place. Bottom line, if you take your time (I played around with mine for a week or two), you can get a really nice finished product. Maybe not factory, but pretty close AND I think it will last longer as these panels are waterproof and should not warp. One more tip, If you take a marker and color the brackets where the screws go to hold the center of each panel up, you can gently rub the panel after you have fitted it in order to mark where your screw hole should go. Also, if you don't have your original headliner boards to use for templates, there are some good diagrams and info in this thread that will get you started: http://67-72chevytrucks.com/vboard/s...install&page=2
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-24-2017 at 09:34 AM. |
04-22-2017, 10:23 AM | #1707 |
Kvn1011
Im just here to say that it still looks awesome!!
My Build Thead (Project Slow Motion) |
04-22-2017, 08:34 PM | #1708 |
Rob,
Thanks for the great write-up, Man! I copied and pasted that into my headliner file so I can study it later. Looking forward to any thing else you might you remember! |
04-23-2017, 12:00 PM | #1709 | |
Thanks!
On a side note, since I changed the door panels to 72, I had to change all the door mechanisms to the longer 72 pivot arm. This was fairly simple everywhere expect for the rear door window regulators. You can't purchase them aftermarket as no one makes them, and I gave up finding a good set of used ones. I happened to have a good set of 72 front door regulators, so I disassembled them and removed the longer 72 pivot arm. I then disassembled my original 67-71 rear door regulators, regreased everything and swapped out the pivot arm and put everything back together. Waaalaaahhh, it worked like a charm! As soon as I get my new window seals and door felt in, I'll be able to wrap up the rear window install, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-24-2017 at 09:38 AM. |
04-23-2017, 01:35 PM | #1710 |
[QUOTE=Hart_Rod;7923426
No problem. Are you using Portheadlights diagrams? [/QUOTE] I do have those handwritten diagrams with measurements, but I was able to recently pick up a set of complete original headliners that I'm planning to use as templates. They are not quite good enough to salvage and use, but complete enough to use as templates. How are you liking the "look" of the plastic you used? I haven't settled 100% on a material yet, but that plastic looks pretty good, at least in pictures. |
04-23-2017, 01:55 PM | #1711 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-24-2017 at 09:43 AM. |
04-24-2017, 07:48 PM | #1712 |
I looked into getting into the header void (?) to no avail. Using a piece of 14 guage soild conductor wire I could get from the bolt out, but not into the void, and I couldn't get from the void through the hinge bolt holes or the hinge cutouts. The green arrow shows where I got through and the red ones where I couldn't.
04-25-2017, 09:03 AM | #1713 | |
04-26-2017, 12:41 PM | #1714 |
Sorry for not being clear. Turning the photo may help. I put the test wire into the bolt hole and got it to come out under the headliner. (Next to those stupid crimp clamp connectors the PO used for trailer lights). That would be the green arrow.
I thought you wanted to get past the weld seam into the void area where the hinge bolts on. That is what all the red arrows were about.
04-26-2017, 01:35 PM | #1715 | |
05-06-2017, 08:15 PM | #1716 |
C10 Club Tennessee
Thought I'd share a pic of Rob's burb from the Battle in Bama show today. I believe it was its maiden voyage. See you in July at the Southeastern ALL Chevy/GMC Truck Nationals, Rob
05-06-2017, 09:20 PM | #1717 |
Wish I could have made it over there.
05-06-2017, 09:51 PM | #1718 |
Rollin' Old Skool
Would be nice to see it there. Looks awesome, Rob!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
05-07-2017, 04:38 AM | #1719 |
Worth every penny!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
05-08-2017, 08:35 AM | #1720 |
Congrats on the maiden voyage Rob, the Burb looks awesome.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-09-2017, 08:19 AM | #1721 | |
Thanks Bill would have been nice to see you again, hopefully I can make it over for CTC this fall. Thanks! Thanks! Thanks Keith! I almost didn't go as the Suburban is not totally finished and I hate showing it like that. But at some point, you get tired of working on them and just want to drive them, . It drove really well and everything worked as it should. I'm still working on the tune, but the drivability was good and I got around 15 mpg running around 75. I think that will go up as we have the tune somewhat rich. Other than that, I'm still working on the interior. My door panels are repainted and I received the restored Cheyenne door trim from CSM. I think it came our really well, . Will get everything put on in the next couple of weeks as I wrap up the interior.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-09-2017 at 08:44 AM. |
05-09-2017, 08:29 AM | #1722 |
Was really wanting to check this thing out in person but I guess I got there after you had left Saturday.
07 GMC Sierra 2500 compound turbo' duramax 99 GMC Yukon solid axle swapped 67 Chevy c10 small window swb stepside supercharged ls6 70 Chevy c10 suburban 72 K5 Blazer 4wd |
05-09-2017, 05:40 PM | #1723 |
Those interior panels look good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
05-10-2017, 09:44 AM | #1724 | |
Thanks! I'm really happy with them and thing they will compliment the interior, . Did an LED headlight install last night, it's really a night and day difference, . Got the idea for the lights from looking at boardmember JWALL's square build: http://www.ebay.com/itm/322177905990...AIT&rmvSB=true
05-10-2017, 10:04 AM | #1725 | |
C10 Club Tennessee
