05-10-2017, 11:31 PM | #1 |
Re: 78 downlow-littledough
Do you plan on welding to the pumpkin?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-11-2017, 12:19 AM | #2 |
Ditto? Parallel 4-bar & a Panhard bar.
05-11-2017, 10:19 AM | #3 |
No, "I don't plan to weld to the pumpkin". It could be done by a very skilled welder following a strict pattern after heating the entire pumpkin, and slowly cooling it down, etc. but not by me. I was just looking at the option.
I will probably be installing a crossmember and pointing the bars inward to where they intersect (imaginary lines) near the front bumper. I have not ruled out the parallel bars and panhard yet either. Should have something in place by tomorrow evening.
"Life is too short to drive a boring vehicle". Later, Wayne |
