Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-07-2017, 01:59 PM   #351
northern 85
northern 85's Avatar
Re: Power Brake Booster Adapter Bracket
Sent you an email about a purchasing a power brake bracket for a 66 c10. Thanks Ryan.
northern 85 is offline   Reply With Quote
Old 05-07-2017, 09:03 PM   #352
northern 85
My Gmail is messed up it wouldn't let me open your message, I sent you my wifes email if you could resend your email that would be great sorry for the screw up. Thanks Ryan
Old 05-08-2017, 12:08 AM   #353
Captainfab
60-66 Nut
I have sent you 2 emails..........
Old 05-08-2017, 05:50 AM   #354
northern 85
Paypal sent, thank you!
Old 05-08-2017, 11:28 PM   #355
Captainfab
60-66 Nut
Your booster bracket shipped today as promised.
Old 05-13-2017, 07:07 AM   #356
northern 85
Received my bracket, thanks for a really nice product and fast shipping!!
Old 05-13-2017, 11:33 PM   #357
Captainfab
60-66 Nut
Thanks for the compliments........ I appreciate the purchase
Old 05-14-2017, 09:23 AM   #358
northern 85
Captin,if you get a letter from me do not open it,its from my wife!!!! I opened the box you sent in the kitchen........ the shredded paper you used as packing went flying....whoops After it was cleaned up i heard her mumble i should send him a thank you letter filled with glitter. Thanks again for the great bracket. Ryan.
Old 05-18-2017, 04:57 PM   #359
pmeyers
Captainfab,
Just finished the brakes on my 62 C10 that has a hydraulic clutch - drum/drum. I want to add a booster using your kit including the mounting bracket and wilwood clutch cylinder.
I just picked up an early 90's Booster and master cylinder setup from a Chevy 1500. Bolts measure 3 3/8x 31/2 so booster should be fine. Wondering if I can use the mc that is already on it or do I need a different mc. Also from reading previous posts it appears that I can eliminate the proportioning valve since it is drum/drum? Posted a picture of the booster assembly if that helps. Will get my order in as soon as I am sure I have the right parts. Thanks for your help,
Paul
pmeyers is offline   Reply With Quote
Old 05-18-2017, 11:00 PM   #360
Captainfab
60-66 Nut
This for sale thread is for the '63-'66 standard booster bracket. Here is the thread for the '60-'62 trucks with the hydraulic clutch.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
You can not use a master cylinder designed for a disc/drum braking system on a truck that has a drum/drum braking system. You need a drum/drum master cylinder and the appropriate booster. With that booster you would have to use a master cylinder for a 1970 Buick Estate wagon with power brakes. Are you still using the original slave cylinder?
Originally Posted by pmeyers View Post
Captainfab,
Paul
Attachment 1653019
Old 05-18-2017, 11:09 PM   #361
Captainfab
60-66 Nut
Here is an excellent video showing a power brake upgrade on a '66 C10 using one of my brake booster brackets shown in this thread.
https://www.youtube.com/watch?v=XhVxzGUjq-g
Old 05-27-2017, 03:17 AM   #362
gijoecarlos
How much is your hydroboost brackets? And what hydroboost do you recommend?
gijoecarlos is online now   Reply With Quote
Old 05-27-2017, 11:14 PM   #363
Captainfab
60-66 Nut
The hydroboost mounting plates are exactly the same price as in post #1 of the for sale thread that is linked in my sig line. Here is the for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=347480
All GM hydroboost units are interchangeable once you remove the factory mounting bracket and install my hydroboost mounting plate. You might look thru the for sale thread and see what application others have used for a hydroboost.
Old 07-18-2017, 07:56 PM   #364
Slammed96
I saw you have a master/clutch master adapter for the 60-62 trucks, but do you have a similar setup for 64-66? I've got a 66 gmc that I'm putting a t56 in and your bracket looks like a cure for the headaches I'm having getting the clutch master figured out.
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop
66 GMC 1 ton stepside looooong bed- the tow pig/work truck.
Slammed96 is offline   Reply With Quote
Old 07-18-2017, 11:44 PM   #365
Captainfab
60-66 Nut
Yes I do make a booster bracket with a hydraulic clutch conversion for the '63-'66's. Here is the for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=651200
Old 07-20-2017, 06:48 AM   #366
Slammed96
Awesome! Thanks bud! I'll probably shoot you a message for payment info here in a day or so.
Old 07-30-2017, 12:08 AM   #367
Captainfab
60-66 Nut
Here is a thread with some good info on lengthening the booster pushrod and some plumbing pics.
http://www.67-72chevytrucks.com/vboa...d.php?t=740378
Old 10-17-2017, 11:54 PM   #368
Captainfab
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
Old 11-26-2017, 09:52 PM   #369
Salmon Slayer
Here are some installed pics.
I hava a 65 c10 4x4. ,,need a power brake booster assy with adapter ,,and a power steering conversion plate to mount a 79 Blazer power steering unit on this truck,,,
Jim 406 596 7277
Salmon Slayer is offline   Reply With Quote
Old 11-26-2017, 11:48 PM   #370
Captainfab
60-66 Nut
Sorry but I simply do not have time for phone calls, nor can I take your payment over the phone. Purchasing instructions are in post #1 of every one of my for sale threads. Send me a PM or an email and I will be happy to get you take care of. I went ahead and sent you a PM.
Jim 406 596 7277
Old 01-10-2018, 01:07 AM   #371
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 02-13-2018, 10:41 PM   #372
mjs94080
mjs94080's Avatar
do I need those brackets for either of these boosters?
my truck is a 66' Chevy C10.
Im trying to choose between CPP or POL.
Which will fot better?
Here are some pics of one powder coated satin black. I also forgot to mention in my first post (really wish we could edit for more than 5 mins) is that these come with grade 5 hardware.
mjs94080 is offline   Reply With Quote
Old 02-15-2018, 01:08 AM   #373
Captainfab
60-66 Nut
If you want to mount your brake booster correctly and without drilling holes, you will need one of my booster brackets. If you do not care about either of those criteria, then just use the universal mounting bracket that comes on the booster/ master assembly that you purchase. To my knowledge both companies sell the same universal booster which should fit any of my booster brackets.
Old 03-24-2018, 10:42 PM   #374
Chris04
Chris04's Avatar
I need a bracket for my 67! Pm sent
1972 Cheyenne super
1949 3100
Chris04 is offline   Reply With Quote
Old 03-25-2018, 01:21 AM   #375
Captainfab
60-66 Nut
I replied to your PM.
