Old 06-07-2017, 12:53 AM   #33
Captainfab
60-66 Nut
Re: Finally caught a break NP440 / MY 6
You can convert to a hydraulic clutch by either using a '84-'91 truck bellhousing or by installing a hydraulic clutch conversion slave cylinder and brackets from Novak onto your existing bellhousing. I make the booster brackets with the hydraulic clutch conversions for '60-'72 trucks which includes a new clutch master matched to the slave you are using.
Originally Posted by Blue666(2) View Post
Brad, do you know if a hydraulic clutch can be used with a trans originally set up for a mechanical clutch? Any info as to which part numbers would be needed? Thank.
