06-22-2017, 05:15 PM | #1 |
Wh yfor I can't pull my ignition lock cylinder?
I've done this many times on my first truck, and it should be a simple task. But not so much for my latest truck. Set on ACC, push the button, release pressure on the button while turning counter clockwise and done.
I'm doing just that, once I release the pin, it clicks maybe a degree or so counter clockwise. Looks right, feels right, doesn't pop out. WD-40, some jiggle & wiggle & nothing. Very frustrating.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-22-2017, 05:21 PM | #2 | |
The Older Generation
Re: Wh yfor I can't pull my ignition lock cylinder?
Once in a while I run into one like that. Try pushing in on the cylinder while turning it that last little bit. Sometimes that helps. LockDoc
06-22-2017, 05:26 PM | #3 | |
06-22-2017, 05:50 PM | #4 |
If it is turned far enough past acc you can unscrew the bezel and it will act like a puller
06-22-2017, 05:56 PM | #5 |
Tried that and pulling too. Time to take a break. Honest to God over an hour now.
06-22-2017, 05:58 PM | #6 |
Tried that too. I'll give it another shot in a bit. Thanks guys
06-22-2017, 06:22 PM | #7 |
Bingo. I did what Randy suggested, again. That wasn't enough, so I got behind the bezel with a hook, pulled, and now I can install LocDoc's legit cylinder. No rust. My guess is just junk repop. Thanks for your help guys.
06-22-2017, 08:20 PM | #8 |
I just did mine and it was a major pita also. Eventually just kept playing with it and it popped out. Thank God for Loc Doc
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
