Old 06-10-2017, 10:49 PM   #1
KyleSeal
KyleSeal's Avatar
Looking For A Radiator
Well my stock 4 row developed a leak. Actually a couple of them. So I'm either going to get it fixed or get a new one,
how much is it for places to fix pinholes on a radiator?
If that isnt the way I go and decide to get a new one, who sells a brass/copper radiator (4 row) inexpensivley? I see them on ClassicParts and Brothers for like 500. Holy crap. Thats insane. I dont want an aluminum. I'd rather have stock style.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 06-11-2017, 12:15 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Looking For A Radiator
If you have a good repair shop close I would see about getting it fixed. I have had 3 or 4 of them repaired and have had good luck with them. The last one I had done was $65. I removed it and took it to him.
LockDoc
Leon
Old 06-11-2017, 01:32 AM   #3
BCOWANWHEELS
Rockauto
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-11-2017, 03:34 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
If your handy with a propane or butane torch you can make most repairs at home. Acid flux and 60/40 lead/tin solder and your in business. You can google "radiator repair pics" and get some ideas on how to approach a repair. I like the little refillable butane torches for pin pointing the heat. I use it soldering and for heat shrink tubing. If your leak is visible like a crack or split in a crossover, use a toothbrush sized wire brush to clean the paint and shine the copper. Smear some acid flux on the crack, use a pair of needle nosed pliers to close the crack. Now your ready to apply the heat, a dab or two of solder and your done. "Nothing fancy"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-11-2017, 08:04 AM   #5
BlueBullet
BlueBullet's Avatar
I just purchased a 4 core for mine. The manufacturer is called Northern. They are made in Willmar Minnesota. Our diesel mechanic has an account with them. $315 I had to modify the rubber inserts.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 06-11-2017, 08:46 AM   #6
gmc 2500 4x4
i have a harrison 4core for a 4speed truck, i cant decifer the metal tag. didnt leak but to restore it they wanted like 500.00! (recore)
gmc 2500 4x4 is offline   Reply With Quote
Old 06-11-2017, 09:57 AM   #7
74baggedbug
I got mine from Oreilly auto parts for around a couple of hundred bucks, lifetime warranty and metal not plastic
74baggedbug is offline   Reply With Quote
Old 06-11-2017, 05:04 PM   #8
racerop
racerop's Avatar
Do it like ironangel says. Too many people that work on theses trucks are swapping out parts and not learning what our fathers taught us. Repair , before replace.
racerop is offline   Reply With Quote
Old 06-11-2017, 09:28 PM   #9
KyleSeal
KyleSeal's Avatar
I'm interested - how did it fit? Was it a stock style or was it a generic aluminum radiator? I'd like mine to look very stock.
Old 06-11-2017, 09:48 PM   #10
weq92f
weq92f's Avatar
I've had them repaired in the past. It's usually a fair ( cheap ) price and in my experience, worth the wait for the savings. If you immediately pull it and take it to a shop, your turnaround time will approach the same as ordering new online. Plus you'll save bookoo buck!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-11-2017, 10:30 PM   #11
Ram-Man
Ram-Man's Avatar
Rock auto you can get a direct fit 4 row for about $130 and fits like the original.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 06-12-2017, 12:47 AM   #12
1968aj
You can patch up a 40 something year radiator and may luck out. Or you could have to pull it again annd again fixing leaks. I would get a new one.
1968aj is offline   Reply With Quote
Old 06-12-2017, 06:41 PM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
some of the 1973--87 4 core radiators are the same so are the 3 core Might want to look into them.if they are not and the tank is different.Just go to the radiator shop and have your tanks swapped
stsalvage is offline   Reply With Quote
Old 06-13-2017, 01:29 AM   #14
In The Ten Ring
I bought a brass and copper 4 row radiator from Rock Auto last year. I haven't used it as it sits up too high but I am going to hang onto it. It was on closeout and priced cheap, let me try and find the link.
http://www.rockauto.com/en/parts/vis...,radiator,2172
I am hanging onto my original radiator and later on I am getting it recored. I ground out the rivets holding my 4-row lower radiator brackets to the core support, I did that so I could use machine screws to bolt the brackets back in. That way I could replace those with the smaller brackets and put my recored radiator back in if I so decided.
In The Ten Ring is offline   Reply With Quote
Old 06-13-2017, 08:55 AM   #15
Shinysideup
Shinysideup's Avatar
I thought this was a direct replacement unit? What is the problem exactly with it?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 06-13-2017, 09:09 AM   #16
my56chevytruck
my56chevytruck's Avatar
I bought mine from Auto City Classics and switched from a 4 core to a 2 core. Check them out..
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-13-2017, 10:29 AM   #17
ho70
ho70's Avatar
JohnR has one for sale in parts-I was gonna buy it but exchange rate kills me
http://67-72chevytrucks.com/vboard/s...d.php?t=739222
ho70 is offline   Reply With Quote
Old 06-13-2017, 12:24 PM   #18
In The Ten Ring
I think it will sit up too high: the top of the radiator is so high that the upper retainer brackets are at such an angle as to look wrong. I'd have to shim them on the core support side.
Now in my case, one of the lower retainer brackets had been smashed in, making that side a 3 row radiator bracket. That kept it from fitting and made it sit up even higher. I have since rectified that but not before I bought an all aluminum 3 row radiator.
Originally, my truck had a 1 or 2 row radiator that didn't sit on lower brackets at all! It sat on a piece of long, thin rubber placed on that lower shelf of the core support.
I haven't reassembled my front end yet, I could still put in that (all copper and brass) radiator if I wanted to. I don't need that much cooling with just a 250 I6 though.
Old 06-13-2017, 12:33 PM   #19
leftybass209
leftybass209's Avatar
Yep. Those parts store copper 4 rows look the part, but don't exactly fit the part. I had to return mine for the same fitment issues. I went with a Champion/American Eagle 2 row radiator with verified 1" rows. Engine won't even attempt to get hot in 100+ degree weather even at idle, with a stock mechanical fan w/ clutch.
leftybass209 is offline   Reply With Quote
Old 06-13-2017, 12:37 PM   #20
leftybass209
Forgot to mention. Mathematically, a 2 row radiator with 1" or larger tubes should cool more efficiently than a 3 or 4 row radiator with smaller diameter tubes. Now, I've seen plenty of small tube 3 or 4 rows cool engines just fine depending on climate and use, so take it FWIW.
Old 06-14-2017, 01:19 PM   #21
Z10
Z10's Avatar
Go to this post and read. Lot's of good info.
http://67-72chevytrucks.com/vboard/s...39#post7888239
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 06-25-2017, 11:35 AM   #22
1SG.Rob
1SG.Rob's Avatar
I just discovered my radiator is leaking also. Already removed and am now trying to decide if I want to fix it or just get a replacement. There's a reputable radiator guy here in town and my gut says take it to him. However, does anyone have any experience with the ones that Wes offers on his site? $389 for an OEM replacement is within my price range.
1SG.Rob is offline   Reply With Quote
Old 06-25-2017, 01:01 PM   #23
CastIron
CastIron's Avatar
I've been looking at radiators as well. I have the original 2 row and have been thinking about getting something that would cool a little better, I've got a question for you guys that have switched over to 4 row radiators. It looks like I'd need different upper mounts and to move the lower, but is the shroud the same or would I have to find a different one?
CastIron is offline   Reply With Quote
Old 06-25-2017, 01:12 PM   #24
toolboxchev
Imho, do not scrap out your old brass and copper radiators. The tanks on the sides are what is valuable. I had a local guy rebuild mine with a heavy duty forklift core for a decent price.
Cools like a dream! I would not use a aluminum unit on these old trucks unless its a show piece. You cannot clean the insides of them with the radiator flushs on the market today. EPA had made most radiator flushs reduce the harmful environmental chemical to using Sodium Citrate as the main ingredient.
In the days when these vehicles where developed we used a chemical called Oxalic Acid which is harmless to brass, copper, and cast iron. It eats red oxide, which is rust!
toolboxchev is offline   Reply With Quote
Old 06-25-2017, 01:21 PM   #25
leftybass209
Shroud is the same. The only difference in shrouds is between I6, sbc, and bbc.
brass, copper, radiator
