Old 06-27-2017, 08:03 AM   #1
72MARIO
72MARIO's Avatar
Problem with back feeding 5 volts..
I am having a problem with my ls swapped truck. I have not.changed any of the cab or chassis wiring since the sway. The problem is the center 4 diodes in My brake and running glow slightly with the ignition power on. It's not a big deal untill I hook onto my dump trailer and the brake controller sees 5 volts and apply the brakes...
So far I have added extra grounds changed the headlight and. Ignition switch. No chamge5 Then I unplugged the steering coloum taillight harness light switch ignition switch removed all fuses and flashers and still have 5 volts.
The only way I can stop the back feeding is when I remove
the ignition relays from my BP Automotive harness.
Am I making a bigger deal out of.this than it is because I have led tails ? As soon as I add a 194 bulb in line on the brake wire the diados go out
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-27-2017, 08:33 AM   #2
72MARIO
72MARIO's Avatar
Re: Problem with back feeding 5 volts..
Tail
2005 TAHOE DD
Old 06-27-2017, 08:42 AM   #3
72MARIO
72MARIO's Avatar
Truck
2005 TAHOE DD
Old 06-27-2017, 11:12 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Out of curiosity, does changing the ground on the tailights change anything? I have similar LED tails, and had to ground them to the frame instead of just the box/fenders. I've also noticed that I burned out a flasher sooner than I'd expect.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-27-2017, 11:27 AM   #5
72MARIO
72MARIO's Avatar
It was the brake controller lying to me supposedly I got one of the 200 P3 controllers that left the factory with the wrong program in it..there sending me a new one.
2005 TAHOE DD
Old 06-27-2017, 07:42 PM   #6
72MARIO
72MARIO's Avatar
I added extra ground from the deck to the frame and ran a ground from the battery to the taillight ground. There was no change. I just have had enough of working on this truck.... so I went and bought regular Gates lights pushed them in and the cruise works now. Perfect.
I couldn't find a clean detailed way to add a load to the brake light wire and make the leds work. If I come across that I might put the leds back in.
2005 TAHOE DD
Old 06-27-2017, 11:21 PM   #7
ls1nova71
ls1nova71's Avatar
What year is your engine?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-27-2017, 11:31 PM   #8
franken
Bad ground, not backfeeiding. Ground the needed. Drive.
Old 06-28-2017, 05:30 AM   #9
72MARIO
72MARIO's Avatar
2004 dbw I finally found the parts to make a cruise lever like the one I got from you.
2005 TAHOE DD
Old 06-28-2017, 08:25 AM   #10
Hart_Rod
Hart_Rod's Avatar
You can T into the white wire that goes to your brake light switch and run your resistor to ground.
Hart_Rod is offline   Reply With Quote
Old 06-28-2017, 10:12 PM   #11
72MARIO
72MARIO's Avatar
What kind of resistor do I need to use ?
2005 TAHOE DD
Old 06-28-2017, 10:48 PM   #12
ls1nova71
ls1nova71's Avatar
I use a relay. Just hook up the coil side of one from the wire on the brake switch that is HOT when the brake lights are ON, to 85 on the relay, then hook the other side 86, to ground. I know that will make your cruise work.
Old 06-29-2017, 12:03 AM   #13
dayj1
1k Ohm is a common easy to find value that will work fine as a pull-down resistor in this application. In theory, it'll dissipate about 0.2 watts, so a 1/4 resistor should work, but I'd spend an extra 5 cents on a 1/2 watt resistor.
I generally use a resistor because it can be easily hidden, but Eric's suggestion of using a relay coil is perfectly fine and will work if that's easier for you to source.
dayj1 is offline   Reply With Quote
Old 06-29-2017, 06:49 PM   #14
72MARIO
72MARIO's Avatar
Thank guys.
A relay is definitely easier to source and I have the bosch type bases with crimp on wire terminals so the wires can be continuous. I am not a fan of splices when it can be avoided.
2005 TAHOE DD
