Old 06-27-2017, 03:35 PM   #1
Rockin'70Stepside
Rockin'70Stepside's Avatar
Cool Bench Seat Foam Interchangeability
My old 71'/72' seat foam has holes in in and I was wondering if some of the newer trucks would have the same foam in them.
Rockin'70Stepside is offline   Reply With Quote
Old 06-27-2017, 03:43 PM   #2
CraigT
Junior Member
Re: Bench Seat Foam Interchangeability
I just put in the bench seat foam kit from LMC in my 72 today. Huge improvement! Fairly inexpensive fix too.
Took me about 3.5 hours start to finish, including removing the seat from the truck and putting it back. Order the hog ring plier kit and extra hog rings. They take a few to get the hang of crimping them just right.
CraigT is offline   Reply With Quote
Old 06-27-2017, 03:50 PM   #3
Rockin'70Stepside
Cool Re: Bench Seat Foam Interchangeability
Thanks for taking the time to reply, but there is a salvage yard nearby that I can get stuff from for a very reasonable price and so I was wondering if some of the newer trucks had the same foam.
Old 06-27-2017, 04:16 PM   #4
68Gold/white
Exactly HOW inexpensive??? Everyone has different opinions on $$$ value.
The foam pieces I've seen have been around $300-$500, too rich for me...
68Gold/white is offline   Reply With Quote
Old 06-27-2017, 04:28 PM   #5
CraigT
Junior Member
Yes, "expensive" is relative. The LMC bottom and back kit is $349.
I'm older and have some neck and back issues. I can't drive these trucks without good foam. The $350 is worth it to me. Foam doesn't last forever and picking it up cheap at a salvage yard doesn't guarantee it'll be an improvement.
Old 06-27-2017, 04:32 PM   #6
Grumpy old man
Grumpy old man's Avatar
No , There is no direct interchangeable foam from a newer year truck , you may find some that can be reshaped to fit but it depends on which seat you have in your truck . Use the search box above ^ there are many threads on repairing seat foam .
Old 06-27-2017, 04:45 PM   #7
Larry Weaver
Any foam deteriorates from sun over time, even if there is a seat cover on it, I would buy new and bite the bullet especially if you drive it a lot.
Larry Weaver is offline   Reply With Quote
