Old 07-07-2017, 06:05 PM   #1
brian1971
brian1971's Avatar
OMG Honda door weatherstripping fits perfect no cutting required !!
I have seen a few threads where the 2006-11 2 door Honda door weatherstripping fits the 66 and earlier trucks but haven't seen many on the 67-72 trucks.So I went to lacal u-pull it today and picked up a really nice set from a 09' 2 dr civic they cost me $21.50 for both sides.I just installed them and the fit perfect,GM couldn't of designed them any better.When I purchased truck it came with a new set of LMC seals installed and doors never closed right even after many adjustments.Doors close perfect now with no effort and doesn't feel like windows will shatter anymore from being slammed.This is probably one of the easiest upgrades you can make.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 07-07-2017, 06:06 PM   #2
brian1971
brian1971's Avatar
Re: OMG Honda door weatherstripping fits perfect no cutting required !!
More pics
Old 07-07-2017, 06:09 PM   #3
demian5
demian5's Avatar
Dust it with some baby powder and make sure its sealing all the way around.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-07-2017, 06:12 PM   #4
brian1971
brian1971's Avatar
OK thanks for tip I'll give it a try,they seem to seal up pretty good.
Old 07-07-2017, 06:28 PM   #5
brian1971
brian1971's Avatar
A few more pictures with door closed.
Old 07-07-2017, 06:47 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I can see it now, junkyards will have a run on Honda w/strip and prices will shoot up....
Great tip, thanks for passing it along. I didn't notice the seam where it joins -- still under the door sill?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-07-2017, 07:06 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Dodge Dakota seals from 86-96 fit like a glove too. I imagine there are many clip on seals that will fit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-07-2017, 07:19 PM   #8
brian1971
brian1971's Avatar
Stocker I was thinking the same thing and yeah they join on bottom by sill plate.
Leddzepp I had been looking for a pair of those for awhile but every time I found one seals were shot I guess because those trucks are all at least 20 years old now.Doesn't seem like 20+ years since dakotas have been on the road.
Old 07-07-2017, 07:21 PM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Great tip, including the baby powder. Clip-on I take it.............And how about those corners, looks just right.
On a side, your cab looks real familiar. Difference being my ochre cab is in off-mode, and I'm getting "perturbed" with my brother who can't seem to return my calls, the (*^()^ . I'd like to pull it off the frame tomorrow. It's holding up progress and a month late already.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-07-2017, 07:27 PM   #10
brian1971
brian1971's Avatar
Hi Tony
Yeah there push on and if you need them to fit tighter just squeeze with your fingers before you install them.I almost had this truck back together then tore it apart again.Installing a LS3/4L85E.
Old 07-07-2017, 08:09 PM   #11
71CHEVYSHORTBED402
Originally Posted by brian1971 View Post
Hi Tony
At least the second time around is much simpler. That's going to be nice.
Tony
Old 07-07-2017, 10:32 PM   #12
Big Block
Big Block
Big Block's Avatar
Wow, just picked up a 71 truck that had new weather stripping in it sometime ago after it was repainted and you have to slam the doors. I think you just solved my problem. I'll be looking into this as a solution. Thanks. Looks great.
Big Block is offline   Reply With Quote
Old 07-08-2017, 05:03 AM   #13
In The Ten Ring
This is the kind of thread we all need.
Thank you so much for posting this.
In The Ten Ring is offline   Reply With Quote
Old 07-08-2017, 05:56 AM   #14
5spd540
This is some good info. I love it when you can use Orem parts and save some cash on conversion parts
5spd540 is offline   Reply With Quote
Old 07-08-2017, 05:58 AM   #15
Shaky
Six in a row makes it go...
Shaky's Avatar
I'm watching this thread with great interest. I restored a '66 and had to slam the doors to get them to close with the new weatherstrip. These were the doors that came on that cab from the factory. People said it would get better with time, but it still seems like too much.
Now here I am with my '67 and it's the same thing. Factory doors and cab that used to close very easily are a bear now. Some people suggest bending the flange that the weatherstrip attaches to, but I have been hesitant. It seems to me that the weatherstrip is the problem.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-08-2017, 04:01 PM   #16
NoNeck
NoNeck's Avatar
A friend of mine used weatherstripping from a 2013 Ram standard cab truck and it worked great. He said the holes in the weatherstrip were there to allow the doors to close easier. I'm wondering if drilling holes into my Precision weatherstrips would make them close easier?
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 07-08-2017, 04:02 PM   #17
NoNeck
NoNeck's Avatar
Oh, here is a picture that I found from a Ram truck. See those little holes?
POP
Old 07-08-2017, 04:02 PM   #18
Coley
Coley's Avatar
Another damn great find!!
....just one more reason why I love this site...lol.
Nice find and thanks for sharing!
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 07-08-2017, 06:01 PM   #19
brian1971
brian1971's Avatar
Thanks guys for the comments,I installed passenger side tonight went on just as easy as driver side.I hit a different u-pull it yard today by my house there was a 2010 2dr civic but someone ripped out door gaskets and had thrown them on the ground they were ruined.
Old 07-08-2017, 06:39 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Good to know about this. My truck has the original gaskets. As far as the gaskets being on the ground, there is no end to what people will ruin just for kicks. Sometimes people just stink.
~Steven
Simi Valley, CA
Old 07-19-2017, 03:27 PM   #21
brian1971
brian1971's Avatar
For anyone interested there are three 06-11 Honda 2dr civic door weatherstrippings in this car at LKQ U-Pull it in Davie/Ft.Lauderdale area.I think there are two pass and one driver side.They are decent quality no big rips or tears.
Old 07-19-2017, 11:44 PM   #22
jeffg1010
jeffg1010's Avatar
This is great info. I love threads like this.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 07-21-2017, 11:13 AM   #23
Precision Parts
Tech Help
Precision Parts's Avatar
Just an FYI, we make the push on style specifically for the 60-66 and the 67-72 which have the correct radius molded corner. You can see our install video here:
https://youtu.be/Ka5nMS05WIk
- Derek
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 07-21-2017, 01:46 PM   #24
Maximus
Maximus's Avatar
I just got into repairing my rusty floors on my K5, when removing the weatherstrip the sheet metal seam came with it!!! lol floors are going back in now, weatherstrip will be in my near future...
Maximus is offline   Reply With Quote
Old 07-21-2017, 09:28 PM   #25
volksworld
went to grab a set off a 2008 at LKQ today...the seal has an extra inner lip about 3/4 of an inch wide that covers the edge of the upholstery on the honda...not sure if it will touch the metal around the door frame ....looks like it may have 1/4 inch of standoff when installed....unfortunately the car i found had a light grey interior so this lip was grey 3/4 of the way around and black where it went under the rocker trim panel....so i guess these will only work if you find one with a black interior...at least it wasnt the only thing i went there for...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
