07-08-2017, 09:26 PM | #1 |
Can a dimmer switch be bad, but still work?
Can a dimmer switch still change the low beam to high beam, but be bad as far as electrical continuity goes?
My dash lights went crazy again, with the high beam indicator, and both the directional indicators stay on. Also, the only light in the dash that works is the one on the far right. All the exterior lights work fine. I have one of the screws on the dash housing grounded now, so I am now going to ground the other, just to make sure. |
07-08-2017, 09:56 PM | #2 |
Re: Can a dimmer switch be bad, but still work?
The first thing I would check is the plug in the back of the cluster tight. It sounds like a ground problem. The printed circuit may be shot. These electrical gremlins can be tricky.
07-08-2017, 09:58 PM | #3 |
Usually the dimmer will make the headlights go dark if it is bad.
07-08-2017, 10:35 PM | #4 | |
I have to try to fix my tach too. |
07-08-2017, 11:22 PM | #5 |
Interesting you mention the far right light in the cluster. The ground gets to the cluster from pin 7 of the connector, and then it goes to the far right bulb and to the metal of the cluster through a screw, and then the rest of the printed circuit ground trace gets ground from the screw on the other side of the cluster. So if those 2 screws are not clean and are not making good contact with the metal trace in your new printed circuit, you could have a lack of proper ground to the cluster lights other than the far right one. Don't know if that is the whole problem, though. Here is a diagram of the cluster printed circuit.
http://67-72chevytrucks.com/vboard/s...d.php?t=709847 |
07-08-2017, 11:35 PM | #6 |
No Dimmer cant be bad and still change HI/LO. If it was open it would not allow current to pass.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
07-09-2017, 08:19 AM | #7 | |
07-09-2017, 12:47 PM | #8 |
Electrical continuity is simply a continuous path (conductor) for electricity to flow, which can be checked using a multimeter on the ohms setting. A multistrand copper wire can check out completely fine using a continuity test, if even all but just 1 strand are broken. However, when that wire is asked to support a load, it most likely will fail due to high resistance along that single strand.
Dimmers are notorious for going bad, especially most aftermarket garbage. Check for 12v at the plug on the dimmer. |
07-09-2017, 02:02 PM | #9 |
You could also have a amount of corrosion at any connectors in the lighting system.
I went through my old truck and cleaned up all the grounds and the packard connections. My lights do dim ever so slightly when at idle in gear yet they are as bright as the day it came off the showroom even at 47 years with original alternator and wiring. Its amazing what a little cleaning can do! |
