02-07-2017, 11:39 PM | #201 |
Re: Do you have a 1972 Plaid Blazer/Jimmy?
Here's a local truck I'm working on, curious how it's a non promo truck but reads Cheyenne equip. I'm fairly new to the blazer world so I'm just comparing to pickups
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
02-08-2017, 06:13 AM | #202 | |
Nothing wrong with that SPID though and an interesting combo. As you noted it is a trim upgrade Highlander and not a bundled promo package Highlander. Unlike the Fleetside pickups, Blazer Highlanders were an upgrade of the Z84 CST trim package. As such they also were the only bucket seat Highlanders. Of note Blazers required both the Z84 CST trim and the optional hardtop coded Z59 or Z58 but not apparently a rear seat.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-08-2017, 10:11 AM | #203 |
Just sold this survivor for a friend of mine. It is going to Green Bay WI. New owner is going to reupholster, fix the rust and paint. Just refresh not a full restore, it doesn't need much.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
02-10-2017, 12:55 PM | #204 |
Doesn't look to need much. Great looking truck.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
07-09-2017, 08:02 AM | #205 |
They're still out there! Garaged and used sparingly as a hunting rig since 2001. I found this one just outside Denver, CO.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 07-09-2017 at 08:14 AM. |
07-09-2017, 08:32 AM | #206 |
Nice ride...did you buy it? Those damn rockers!
07-09-2017, 08:41 AM | #207 |
Yes it followed me home. Goes in Monday for an estimate for rust repair.
07-09-2017, 09:42 AM | #208 |
Saw that. $15000?
07-09-2017, 10:29 AM | #209 |
Carpe manana
Great find - two things good to note:
1) speaker location (would use brackets w nutserts I believe, differs from AC brackets) 2) white rear wheel tubs - I've seen several now and like this one seem to be St. Louis builds. Did GM paint the wheel tubs white on some highlanders?????? My blue one is similar. Is the jack decal on top of the paint?
07-09-2017, 11:29 AM | #210 |
Carpe manana
Examples...
07-09-2017, 11:30 AM | #211 |
Carpe manana
07-09-2017, 11:31 AM | #212 |
Carpe manana
Vvvv
07-09-2017, 12:02 PM | #213 |
Carpe manana
One more.
07-09-2017, 08:03 PM | #214 |
Nice highlander sococ10. Plan on there being more than just rockers needing repair once they cut them off. I needed floors and floor brace and inner rockers with some rocker tortion box repair. I really need to replace the tortion boxes now as the repair has failed now too. Rust gets everywhere and eats inside out. Good luck on repair and hopefully everything else is solid. When I got mine repaired the first time at a shop it was 300 per side. This last time I did it myself and cost me 40 per side and a wire spool for my welder. It's not super difficult but my truck isn't in as good if shape as yours either. So it didn't need to be perfect. I just wanted it solid again.
07-09-2017, 10:52 PM | #215 |
Carpe manana
It's worth noting that in addition to the white wheel tubs the front face of the step on the floor pan is painted white on SoCoC10's Highlander - my blue St Louis highlander was as well but I dismissed it as an addition from a prior owner, which I no longer believe to be the case. Here are example pics - anyone with a highlander that has white rear wheel tubs please chime in as we may have have a plant specific variation.
Note white overspray on the retainer spring for the lug wrench.
07-09-2017, 10:54 PM | #216 |
Carpe manana
Pic of the step face.
07-09-2017, 10:59 PM | #217 |
Carpe manana
I can't find a good example pic of the white step face on mine but glimpses can be seen on the last two photos here: http://67-72chevytrucks.com/vboard/s...36&postcount=4
And this pic shows slight white overspray on the retainer spring like that above:
07-11-2017, 09:09 PM | #218 |
Carpe manana
The (upside down) smoking gun! Jack decal upon factory white paint.
Two tone OEM Highlander interior. Thanks Troy.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 07-11-2017 at 11:13 PM. |
07-11-2017, 09:11 PM | #219 |
Carpe manana
Additional documentation pics. Rear carpet strip used on the front - correct on some k5s.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 07-11-2017 at 09:16 PM. |
07-11-2017, 09:11 PM | #220 |
Carpe manana
....note white paint on the top to bedside bracket, some were body color.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 07-11-2017 at 09:18 PM. |
07-11-2017, 09:12 PM | #221 |
Carpe manana
Found a pic from my blue highlander...same white face. Rear carpet strip up front as well.
07-11-2017, 10:23 PM | #222 |
The rust repair estimate must've been very high since it's now listed on eBay for $20000 more but same pictures
http://www.ebay.com/itm/like/2225726...&ul_noapp=true |
07-12-2017, 10:00 AM | #223 |
Interesting on the white step face, I took a look at my truck, appears to original paint inside, and mine is body color, you can see the holes for the trim, but otherwise no white
Dark blue and 671 gray plaid highlander built in flint
1972 Dark blue, Cst, Highlander Last edited by ClassicStyle; 07-12-2017 at 10:13 AM. |
07-12-2017, 08:29 PM | #224 | |
Carpe manana
Next step is to try and figure out why some have "two tone" interiors while others do not. The orange blazer above and my blue blazer were built in January and February respectively (1972), both St Louis trucks and neither a promo-pacackage. I'm wondering if the added paint was a plant specific variation and maybe on k5s built before a certain date. Keep your eyes peeled for other examples.
07-12-2017, 10:29 PM | #225 |
I will pay attention in my travels.
I'll have to look at my build date, sequence number is 166648. Order number on the bottom jkg700 Amazing to me the differences between trucks right out of the factory
1972 Dark blue, Cst, Highlander |
Tags |
"ss tim", highlander, plaid |
