Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-25-2017, 09:38 PM   #1
drumyn61
can disc brakes be installed on a 62 c-40?
I can't do the front drums with one master.
drumyn61 is offline   Reply With Quote
Old 07-25-2017, 11:53 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: can disc brakes be installed on a 62 c-40?
Pics of the front suspension? If it's independent I believe later model til 87 1 ton would be an easy swap.
Old 07-26-2017, 12:03 AM   #3
drumyn61
It has torsion bars and no coil spring. Basically the same as the 1960 c-10 but bigger drums and maybe bigger spindles.
I've always heard of the 79-85 front suspension swap, I may do that from a 1 ton.
Old 07-26-2017, 12:12 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
I've heard the same. And I know they are really easy to get out, tie rods shocks brake hoses and about 6 bolts.
The whole x member and A arms come out as 1 unit.
Old 07-26-2017, 12:23 AM   #5
drumyn61
I like the way that sounds.
Old 07-27-2017, 12:49 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
While your there get the hydro boost master cylinder and proportional valve too.
Old 07-27-2017, 09:20 AM   #7
drumyn61
Definitely the hydro boost, thats my main objective.
I'm either going to buy a complete donor truck or buy parts from a truck.
I'll install disc brakes, hydro boost and a TH400 trans out of a newer chevy truck. Once thats installed, I can then run a hydraulic winch through my hydro boost system.
Most of these truck came with a 454 but I don't know if I want to go that big, but hey, if it comes with a truck then ya never know......
Old 07-27-2017, 10:34 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Very cool truck too.
Old 07-30-2017, 12:50 AM   #9
Softpatch
Softpatch's Avatar
I like this thread.!
........................S
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 08-19-2017, 11:44 PM   #10
drumyn61
Well, I'm installing hydroboost disc brakes, 454 engine and a TH400 trans. I started tearing into a truck today to get my parts.
I'm going to make a safe FAST and trustworthy 60's ramp truck!
Old 08-20-2017, 04:10 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Get the rear end out of the donor. Should be 4.10 or 3.73:1 should taller than what's in the current rear end be able to get parts
Old 08-22-2017, 10:33 PM   #12
Free Candy Inside
The later K members should swap over. On my 63 1 ton panel I used a donor 84 truck. The 3 main bolts that bolt in vertically should mount right up. 2 on the side should also bolt up. You will have to drill one new hole and oblong another and that's about it. That's assuming this has a similar width frame.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 08-22-2017, 11:56 PM   #13
drumyn61
I just looked at all 23 pages of your build, very cool!!
Old 08-26-2017, 05:59 PM   #14
drumyn61
I tore into my donor truck and now have a front and rear suspension along with a 454 and TH400.
I bought the truck delivered to my door for $1000, sold the aluminum box for $200 and the rest of the truck for $80.00, not bad.
Old 08-27-2017, 10:50 PM   #15
drumyn61
I found a badass lettering painter and he drew this up in like 2 minutes.
Old 09-01-2017, 12:55 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Love this truck. Knee knockers and all
Old 09-08-2017, 09:32 AM   #17
Free Candy Inside
Thanks! I did the K member swap on my panel. Wasn't hateful. Think I'm going to try to swap a K member from a 92 G30 onto my 66 C50!
Instagram: jaked937
