Old 08-20-2017, 07:28 AM   #26
Re: Nobody has restored or repaired a steering wheel yet
Originally Posted by dmjlambert View Post
Brand new cracks may appear in any new place on the wheel and I would not call that a failed repair. I was looking at the threads where the repair cracked again in the same place, and my main interest in starting this thread is to hear news, especially about old repairs that are holding up over time.
There were a number of posts about repairs just done, and they look great. I like to see the reports especially about what works in the long run. I've been repairing way too many things on my truck 2 or 3 times per item.
I don't know what others did and never tried Eastwood's kit. What I was saying is a job done right will not fail, but it could still crack elsewhere. I guess those jobs that failed weren't done right. I can tell you but I have no pictures to show because I no longer have the trucks. But I talk to the owners of both and so far so good and it's been over ten years. Both are garage kept fair weather cruisers.
A good job requires thoroughly cleaning contaminants/dust and a good epoxy. You can also drill little holes in the v-cut to help epoxy grab. I only used bondo for minor filling. I first used JB because it's runny to get it "into" the material. Then I used a pasty epoxy like PC7 to fill.
Old 08-20-2017, 11:12 AM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Nobody has restored or repaired a steering wheel yet
The first coat of blue is on and drying in the sun. Suppose to be 90's here today. I'll wet sand it some tomorrow if needed before I spray the clear. Two tone white & blue as it came from the factory.
It's not perfect but it beats what it did look like.
I redid the Chevelle wheel back in 2012 and it looks as good today as back then.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-20-2017, 11:13 AM   #28
ThePunisher67
Junior Member
Keep the pictures coming
ThePunisher67 is offline   Reply With Quote
Old 08-20-2017, 12:35 PM   #29
dmjlambert
dmjlambert's Avatar
Thanks, nice progress. What is the filler product you used?
Old 08-20-2017, 01:35 PM   #30
4oldcars
4oldcars's Avatar
Here's my 61 Impala wheel
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 08-20-2017, 02:05 PM   #31
GMCGrim
GMCGrim's Avatar
Here are some pics of my steering wheel. Like I said it seems to be holding up very well. As mentioned in an earlier post I used PC-7 two part epoxy to fill all of the cracks. Also this was not my original wheel, it was too far gone in my opinion. I bought this three spoke version at a wrecking yard.
GMCGrim is offline   Reply With Quote
Old 08-20-2017, 04:37 PM   #32
Andy4639
Old member
Andy4639's Avatar
The 67 SS Chevelle wheel I used bondo the cracks where not that bad.
The wood and the 64 Impala wheel I used what is in the picture.
You have to cut off just enough to work with because it will harden up pretty fast on you. Keeping it wet helps though. That's why I didn't worry aboy excess I just ground it off after it dries good.
restore, steering wheel
