05-21-2012, 10:58 PM | #26 |
Re: Won't start when hot!
You need a solenoid heat shield. (the one below is just a generic search, but the GM one looks just like it... it may be the correct one...)
http://shop.advanceautoparts.com/web...___#fragment-2
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-22-2012, 12:02 AM | #27 |
Old member
After his latest post about the truck not shutting off when key is turned off I would say it's a timing issue maybe.
The timing may or may not fix the problem. The mini starter though is a good investment though for these trucks if you drive it regularly like I do.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-22-2012 at 12:08 AM. |
05-22-2012, 11:18 AM | #28 | |
Was the starter new or old/used? I haven't noticed heat soak being a big problem with exhaust manifolds, usually when headers are put on. I don't think I've ever had a heat shield in place on any of my rigs. Just strange there's a lot of seemingly not-related issues. If it starts or cranks fine when jumped, but a different battery has no effect I dunno? lol freshly painted engine, did you scrape all your grounds? But that doesn't fit with it starting fine when cold.
68 GMC C2500 - 305 V6 - 4spd Last edited by MrSchaeferPants; 05-22-2012 at 11:24 AM. |
09-02-2012, 08:46 AM | #29 |
Well I know it has been a while since I started this thread but I finally got the time to install a new mini starter from DBElectrical. It was $58.90 shipped. After installation I drove it for about 30 minutes in 90 degree heat. When I got home I shut it off and then fired it right back up three times in a row. Hopefully that problem is now history. Thanks for all the advice.
How 'Bout them Dawgs! '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
09-02-2012, 10:01 AM | #30 |
The new mini starter won't work on my truck. My starter mounts with 3 bolts going front to back. Can't find a mini starter like that. What did GM do in the past to prevent a heat soaked starter? Have never seen a heat shield on them in the past. Starter on mine weighs a ton, and is there an easy way to get the starter out around the exhaust pipe? Looks like I might hafta drop the exhaust on that side? Any answers or suggestions would be appreciated.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
09-02-2012, 06:23 PM | #31 | |
08-03-2017, 10:05 AM | #32 |
I know this topic is old but I am having the same issue with my truck I replaced battery, positive cable and bought a new mini starter. Still didn't fix the issue. But I'm leaning towards the fusable link that runs to the starter from the ignition it seems unraveled and possible no good.
Posted via Mobile Device |
08-03-2017, 10:43 AM | #33 |
I have had similar symptoms with a fuel pump going bad.
08-03-2017, 11:27 AM | #34 |
I am by far no mechanic I know basics like starter swaps and what not but can someone verify those fusible links if bad would cause this issue?... I have a new fuel pump and a flow meter I am getting the correct amount of gas and psi.
My Distributor is brand new street fire MSI so I doubt its a coil problem. Pics below. |
08-03-2017, 09:30 PM | #35 |
I had the same issue on and off for a long time. It was such a pain that if I had the truck out I would go places where I didn't have to turn it off, or if I did I was going to be there for over an hour. I too had starters checked when cold and they worked fine.
My headers don't do anything to help the problem, but large tube factory manifolds are both hard to come by and expensive. My solution was to use a 48 inch ground cable attached to the inside starter bolt (for a more direct ground), and a reflective Kevlar Heat shield blanket around the whole starter Assembly. I haven't had a problem since, but I hold my breath every time I do a hot start. |
08-03-2017, 10:15 PM | #36 |
I just had the same issue.
First of all heat soak from aluminum carb isn't going to make the starter crank slow. But yes the phenolic plate helps if u have to pump the gas to start after it sits a bit when hot. The heat off the exhaust pipe is probably heating up the starter and making it crank slow. I just installed a heat shield on my truck and problem solved i too thought it was a battery issue at first. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
08-03-2017, 10:19 PM | #37 |
Pic of the heat shield I used.
08-20-2017, 03:52 PM | #38 |
alright so here is an update....
purchased mini high torque starter put a heat shield on it also wrapped my headers with DEI heat wraps. The issue still persists. changed out my battery and re did all my ground wiring. The issue still persists. shortened my gas line and removed them from every possible heat source in case of boiling/peculation. could this be trimming? |
08-20-2017, 10:59 PM | #39 |
Who Changed This?
I added a couple of extra straps to ground the engine to the frame, and ran new battery cables. The battery ground cable is now bolted directly to one of the starter mounting bolts, to eliminate the potentially high resistance connections in between. I did all that after I put a mini starter on it, because it still had hot start cranking issues. Now, it starts "hot", but if I'm pulling my 26' travel trailer, it gets hot enough (230F to 240F) that I have to pop the hood when I'm refueling (if I shut it off). I'll be going into the radiator next- it's warming up running up a hill (200F with a 180F thermostat) with no trailer, and the radiator is 13 years old, or so. Needs rodding out, probably. The engine's due for a rebuild, so I'll be diving into it pretty soon to prep it for the long hauls with the trailer. It'll all get done in that time frame.
08-21-2017, 12:34 AM | #40 |
it won't hurt to run a straight ground, ill try that.
08-21-2017, 07:48 AM | #41 |
Use a " heat blanket" around your new (if u go that route, which I bet u eventually will) mini starter. That will reduce the heat soak even more. Fix it right the first time, and forget about it!!!!
08-21-2017, 01:03 PM | #42 | |
I posted a few pics a couple posts above this one I already bought the mini starter and a DEI heat shield. Hard start when hot still persist. |
08-21-2017, 01:36 PM | #43 |
I am a big fan of the Ford solenoid fix. Cost about 19 bucks
