Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-12-2017, 09:33 PM   #476
UGAK5
Re: Attempting my first build 72 K5
Hey Mike -
Don't mean to hijack, but do you have the top bracket in this pic under your steering column? We both have 72 CST Blazers, and I cant find this part at all in the pile o'crap that the PO put in a few boxes from his initial disassembly. Its made me wonder if it was only on trucks pre 72, or trucks with manual transmissions. I say that because I have seen it called a 'pedal stop'.
Appreciate any help you can offer!
UGAK5 is offline   Reply With Quote
Old 08-12-2017, 10:43 PM   #477
1rippen6
Originally Posted by UGAK5 View Post
Hey Mike -
Yes, all blazers should have them also, I think I should still have a couple.
1rippen6 is offline   Reply With Quote
Old 08-13-2017, 02:04 PM   #478
UGAK5
Thanks Dwayne!
Old 08-21-2017, 01:23 AM   #479
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
I think it's time for a little update. I've basically been a hermit in my garage all summer, but that's because I really want to get this on the road.
I cleaned up my heater and AC evaporator core box. Took it apart, cleaned it and painted it black using SEM Trim Paint. I swear that stuff is the best paint in a rattle can.
Name:  AC Box Painted.jpg
I sent all my AC stuff out to Classic Auto Air in Florida (Compressor, Hoses, POA Valve, Exp Valve, AC Controls) and had them go through a refurbish or replaced with OEM.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 08-21-2017, 01:31 AM   #480
72K5CSTDarkOlive
I ended up swapping out carburetors and adding a fuel pressure regulator. I went with this carb because it has the fuel inlets coming out the passenger side and this makes routing the fuel line much easier.
I used Summits SS braided lines and fittings for the plumbing
Name:  Fuel Reg 1.jpg
Size:  55.1 KB Name:  Fuel Reg 1.jpg
Name:  Fuel Regulator 1.jpg
Old 08-21-2017, 01:51 AM   #481
72K5CSTDarkOlive
I had to redo the routing for electrical to make room for the duct hoses so I took everything out and started from scratch.
Finally figured out how to get the speaker mounted under the dash. Ended up having to drill two holes for the bracket because there wasn't anything for me to mount it to.
Size:  55.6 KB Name:  Fuse Panel.jpg
Name:  dash wiring left.jpg
Size:  106.3 KBName:  dash wiring right.jpg
Name:  Wiper Motor.jpg
Old 08-21-2017, 01:59 AM   #482
72K5CSTDarkOlive
Rear Carpet installed. The Chrome strip in the back was a PITA to get the carpet seated inside of it.
I know the rubber floor mats are upside down but I didn't take another pic when I corrected them.
Attachment 1683070Attachment 1683075
Attachment 1683076
Quick disconnects to remove rear bench seat
Attachment 1683077
Old 08-21-2017, 02:10 AM   #483
72K5CSTDarkOlive
The engine bay is just about done. Need to get a battery and run the electric choke wire back to the fuse panel.
I should be firing the motor up by next week if I don't run into any setbacks.
Size:  62.2 KBName:  Engine_DriverSide.jpg
Grille and bumper mounted. It's starting to look like a truck.
Size:  104.7 KBName:  Emblem.jpg
Steering wheel in. I really liked how this looked on Ironcaine's.
Name:  Steering Wheel1.jpg
Old 08-21-2017, 06:08 AM   #484
UGAK5
WOW!
Everything is looking so awesome! Great work!
Where did you get that rear rubber floormat for the bed?
Chris
Old 08-21-2017, 07:26 AM   #485
IronCanine
I'm trying....
IronCanine's Avatar
What an update! Fantastic work Mike. Everything looks great. I was especially impressed with the A/C bits. You are so close. Fingers crossed for you that you get to turn her over this week. Can't wait to see her roll out. FINISHING KICK!!!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 08-21-2017, 07:44 AM   #486
Greenlee
Greenlee's Avatar
Nice work!
Greenlee is offline   Reply With Quote
Old 08-21-2017, 08:30 AM   #487
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work on the AC box! Thanks for the tip on Classic Auto Air. I'll speak w them about refurbishing my compressor and redoing the hoses. Did you get a replacement evaporator and condenser?
Old 08-21-2017, 09:53 AM   #488
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
BEUTiful! Isn't it amazing how much room those under dash AC hoses take up? I was always in awe when I thought of how the assembly line workers did that all day every day. Lol
Tom Vogel is offline   Reply With Quote
Old 08-21-2017, 08:05 PM   #489
72K5CSTDarkOlive
WOW!
Thank you, Chris. The 2 piece rubber floor mats came from the factory. I don't know if there are any repos being made.
Chris
Thank you, Brad. I hope you didn't mind me going with the same look on the steering wheel
Originally Posted by Greenlee View Post
Nice work!
Thanks, Greenlee
I had my evaporator pressure tested and it checked out okay. I got a new condenser from GMC Pauls which I think comes from Old Air Products IIRC.
Classic Auto Air did a great job and their customer service is awesome to work with. Highly recommend them.
I know right! When I just had the wiring in there, I was like... "Wow look at all that empty space".
Old 08-21-2017, 08:33 PM   #490
72K5CSTDarkOlive
Correction on the rear carpet strip hold down. The tail gate strip seats underneath and the chrome strip sits on top of the carpet.
Old 08-21-2017, 09:09 PM   #491
72K5CSTDarkOlive
The parking brake cable housing is moving when I set the parking brake cable.
The pic on the left is when park brake is off and the pic on the right is when it is on. When I release the PB it barely comes back and I think this is bc the cable housing moves.
The clamps holding it to the frame and inner fender are tight and I even used a 1/4 clamp to squeeze down on it even more.
I don't know what I'm doing wrong. Unless the clamp that is on the parking brake itself needs to be clamped tightly? You can see a little bit of free play in there. I did have to pry it open to get this over the cable
I'd appreciate any help on this subject.
Name:  Park_Brake Cable_Off.jpg
Size:  62.4 KB Name:  Park Brake_Cable_On.jpg
Old 08-22-2017, 05:54 AM   #492
UGAK5
I just installed mine this weekend as well. There may be other opinions, but here is what I did:
* I took the retainer clamp and pried it open wide enough to fit over the solid metal piece of the cable. I did this with one side in a vise and used a pry bar to open it open.
* Once I put it back in the Blazer and got it over that solid metal piece of the cable, I used channelock pliers to close it back down enough to get the retainer bolt started.
* Then, tightened it all up - no more slippage.
Keep in mind the cable slides inside that sheath, so you can position it around a little bit to get it where you want it.
Now, If I did it wrong, someone can correct me and help us both!
BTW - does anyone have a source for the return spring on the ebrake assembly? My PO must've thought those were optional - I don't have one.
Old 08-22-2017, 03:19 PM   #493
72K5CSTDarkOlive
Thanks, Chris. I'll give it a try and see if that works. Did you ever get your splash shields on? I'm having the hardest time getting the bottom bolt in. Wondering if there is a sequence to doing the trick.
Old 08-22-2017, 07:26 PM   #494
UGAK5
I did, but I do not like the way they fit at all. There was no one way to get them on for me, just a lot of fiddling and fussing with them.
Old 08-22-2017, 09:37 PM   #495
72K5CSTDarkOlive
I was in the process of assembling my seats and the drivers side adjustment rod & hardware doesn't seem right to me.
There's the two pieces (with small spring and clip) that slide through the mounting brackets and guide rails. The one on the inside (toward pass seat) looks correct to me.
The other side is throwing me off. It only goes in one way and I think they should go in the same way, but the square hole on the left side mounting bracket only allow it slide in this way shown here.. see pics
Looking for any help on this. Thanks
Name:  Driver seat_Left side_adjsuting rod.jpg
Size:  59.1 KB Name:  Driver_rightside_adjusting bracket.jpg
Name:  Driver bracket side view.jpg
Old 08-22-2017, 09:46 PM   #496
72K5CSTDarkOlive
I found the answer. Did some more searching and found this pic and it does show that I have the keys going the right way.
I'm missing the second clip.
Name:  seat adjust dirver door side.JPG
Size:  68.8 KB Name:  seat adjuster .jpg
Old 08-22-2017, 09:55 PM   #497
1rippen6
Here you go, do you need the spring.
Old 08-22-2017, 10:04 PM   #498
72K5CSTDarkOlive
You the man, Dwayne.. What would I do without you!
I have the spring. How much to ship 95062?
Old 08-22-2017, 10:09 PM   #499
1rippen6
9 shipped that will cover pp fees and shipping let me know if you need my pp info.
Old 08-27-2017, 06:33 AM   #500
UGAK5
Hey Mike - I think we are using the same AED throttle cable bracket. I am struggling to get the cable to fit, have broken two trying to 'bend' them into an S shape to make the angle back into the firewall. It also looks like you went back to the factory kick down bracket versus the one you fabbed up.
What cable brand/part number did you use and any issues with making that angle?
Also, did you switch back to the factory kick down bracket?
Thanks!
Heres the pic I noticed:
