Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 08-25-2017, 12:09 AM   #1
Portland68
1967 Dana 60 Value?
I recently bought a 67 GMC (Super?) Custom 3/4 ton that has a dana 60 posi in the rear..and a 351E V6 up front, what a monster! Anyways I was hoping someone had an idea of what this rear end is worth, I bought the truck to put the buckets in my 68 and didn't know about the rear end until I got it home.
Portland68 is offline   Reply With Quote
Old 08-25-2017, 12:13 AM   #2
toolboxchev
Re: 1967 Dana 60 Value?
What gears does it have? The 3.54, 3.73, 4.11 are one carrier size. If you go the other directions the carriers may be a different size therefore more worth while due to be a little more or less a oddity.
The gearing listed above covers most 90 percent of the stock gearing from the factory as a generality.
toolboxchev is offline   Reply With Quote
Old 08-25-2017, 12:17 AM   #3
Portland68
My dad and I haven't taken the cover off to check or tried counting the rotations and figuring it out that way. There is no external tag on this year is there?
Old 08-25-2017, 12:39 AM   #4
BlueBullet
BlueBullet's Avatar
I sold a rear Dana 60 off a 72 3.54 gears and posi 8 bolt for $400. It took a while but a local forum member bought it.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 08-25-2017, 12:41 AM   #5
Portland68
Here's a picture for now
Old 08-25-2017, 12:51 AM   #6
kwmech
There still could be a small tag under one of the cover bolts
Old 08-25-2017, 06:51 AM   #7
Yeah, they came with an ID tag on a bolt. It won't be a 3.73 tear if it's got original gears. You need to know what you have to know what it's worth.
Old 08-26-2017, 10:56 PM   #8
Portland68
I was able to get the tag cleaned off, the rear end has 4.56 gears in it - good for climbing a tree paired with the 351E engine the truck has but is there any value in it?
