Trying for fauxtina blue
Well I'm going to attempt a faux-tina look. Here we go.
Re: Patina blue
Started with this.
Re: Patina blue
Got down to this.
![]() Join Date: Dec 2006
Re: Patina blue
Nice, I'm planning on doing the same thing with mine! What are you using for paint?
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
Re: Patina blue
It is the hot rod flatz baby blue.
Re: Patina blue
Got the door mounted. The hot rod flatz is super easy to spray. Although the door came out a little more dull that the bed sides. Guess it doesn't make a difference because I plan to sand it down anyway.
Re: Patina blue
Is the top of the cab primer? or is that the color?
I like the flat blue. I HATE gray primer. Don't care much for flat black either.......... |
Re: Patina blue
It is primer. I needed to hand the doors to make sure I got the lines right for the white top.
Re: Patina blue
Hard work.
Re: Patina blue
Pp
Re: Patina blue
Pic
Re: Patina blue
Pic
![]() Join Date: May 2009
Re: Patina blue
Luv that blue luv the blues
Re: Patina blue
Got one of the front fenders done.
#15 |
Re: Patina blue
Is the white roof going to be flat also???
#16 |
Re: Patina blue
Yes classic white.
#17 |
Re: Patina blue
The sanding begins.
#18 |
Re: Patina blue
Pic
#19 |
Re: Patina blue
Nice. Looking forward to it.
#20 |
Re: Patina blue
Keep going?
#21 |
Re: Patina blue
Looking pretty cool. I like where your at with the patina look so far. . preference if you wanna go more. You mentioned the hot rod flatz laid down nice. would you recommend it to a first time painter such as myself?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
#22 |
Re: Patina blue
This is the first time I've sprayed a top coat I've sprayed epoxy primers. The hotrod flatz so far has been very easy to spray. This color covers real well I think my 13 year old could spray it.
#23 | |
Re: Patina blue
Awesome, thank you. Urs looks really nice. Ive only ever sprayed a top coat in a painting class so it was only single panels. Never a full truck. I just finished puttin mine together and I’m Gettin a new bed for it, two different colors so I wanna try to get it all one color. I’ve heard good things from people about hot rod flats. Might have to give it a shot. Yours is lookin great so far
#24 |
Re: Patina blue
Still sanding.
#25 |
A320 Pilot/USAF Retired
Re: Patina blue
Nicely done!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
