09-06-2017, 07:23 PM | #1 |
Re: 1967 front clip on 1972 K5 Blazer
Jim,
Thanks for the heads up. I checked out your build (~page 14?) but got the photobucket error instead of seeing images. Seems like your pieced together 67-68 front clip more or less bolted right on, so that's a good sign. Your build thread is HUGE! Do you know which pages deal with the front clip replacement? Thanks, Rob
Rob "1967 Wanna Be" 1972 K5 Blazer |
09-07-2017, 09:31 AM | #2 | |
I used a repro grille, and you will want to take out the rivets for the grille surrounds as the are not painted behind them, just a heads up if you go this route sorry my build is soooo big Also, the core support bushings will give you fits, since your frame bracket is set up for 72, but your core support is 67-68, buy both bushing and fit as needed, or change the bracket on the frame. Holes are a different size. You'll see the effect of this when you mount the fenders and the gap between the fender and door is off Jim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-07-2017 at 09:41 AM. |
09-07-2017, 11:57 PM | #3 | |
I was interested in your thread because you've already done what I want to do. If memory serves me correctly your build thread is 100+ pages. I found some front clip discussion on page 14 or so, but I don't know if there's more or what the sequence of the build was. Do you have pictures of the rivets and grill surrounds? I think I've read that the 67-68 core bushing is shorter than the 69-72 - is this what you're referring to? I was thinking of using a temporary spacer or even washers. What did you do? Your advice is greatly appreciated, as would be any related images you can provide. Rob
09-08-2017, 04:55 PM | #4 | |
[url=https://flic.kr/p/XfY1W7]20170908_1105
09-08-2017, 04:57 PM | #5 |
09-08-2017, 09:15 PM | #6 |
Jim,
Great, looks like I got the right core support after all. In the picture your core support looks like its hanging off one side of the bushing - am I seeing that right? Rob
09-08-2017, 09:16 PM | #7 |
By the way, did you POR your core support? That thing looks smooth as glass!
