Old 09-08-2017, 08:12 PM   #1
In The Ten Ring
Getting hood hinge springs back on.
Assuming I get my grill back on without too much trouble (see my other thread tonight on that), do you put the hood hinges on first and then put on the hinge springs or do you put the spring onto the hinges first and then put both onto the truck?
In The Ten Ring is offline   Reply With Quote
Old 09-08-2017, 08:21 PM   #2
GR8-68
GR8-68's Avatar
Re: Getting hood hinge springs back on.
I would mount hinge first then add the springs.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 09-08-2017, 09:09 PM   #3
kwmech
With the hinges mounted I use an old hay hook to keep the fingers out of the way
Old 09-09-2017, 01:44 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I don't have a hay hook. I use a loop of 1'' nylon tubular webbing like climbers use, and make a 3' long sling. I hook one end of the sling on the spring hook end, put one foot on the front bumper and lean back, pulling on the spring and putting the spring onto the upper hinge notch.
Old 09-09-2017, 04:01 PM   #5
bill3rail
bill3rail's Avatar
Need pictures! We prefer video...
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 09-09-2017, 04:03 PM   #6
Hidesertchevy
Use cherry picker super easy
Hidesertchevy is offline   Reply With Quote
Old 09-09-2017, 04:12 PM   #7
Steven R
this is the way I have done this in the past, just be sure to use good zip ties. I set this up with bad ties just for the photo. I use my clamps in reverse.
Steven R is offline   Reply With Quote
Old 09-09-2017, 05:02 PM   #8
'68OrangeSunshine
Dude, if I was that much into high tech, I'd drive a late model car, not an ''old'' pickup.
Old 09-09-2017, 05:04 PM   #9
'68OrangeSunshine
Quick links would be safer. Other wise, good concept.
Old 09-09-2017, 05:29 PM   #10
bill3rail
bill3rail's Avatar
Great Idea!
Carabiner.
Old 09-09-2017, 07:43 PM   #11
In The Ten Ring
Great suggestions guys, thanks!
Dad and I made big progress today on the fenders, we may be ready for the hood in a day or so.
Old 09-09-2017, 08:05 PM   #12
'68OrangeSunshine
Great Idea!
Carabiner.
Perfect. Just use the steel ones. The cheezy aluminum 'biners you get with the fake-Sigg water bottles will fail on you.
Old 09-09-2017, 10:44 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I made use of the steel posts I set to paint car parts, I mean for my wife's clothe's line, some chain and quick links, and a ratchet tie down or two.
Edit, I should mention I tied the spring up first, just in case (yikes).
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-10-2017, 12:09 AM   #14
Bob B.
I put the springs on before I put the hinges on the truck. I put the hinge in a vise and use a very large pair of 'truck' brake spring pliers. Works every time!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 09-10-2017, 08:45 AM   #15
BugzC10
BugzC10's Avatar
That's funny...but we do love pictures!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 09-10-2017, 04:54 PM   #16
bill3rail
bill3rail's Avatar
You may very well be older than I am...
Please have a child, grandchild or great grandchild take video of you putting springs on the hinges. This could be fun to watch!
Old 09-10-2017, 07:14 PM   #17
'68OrangeSunshine
Still single after all these years.
Besides, shooting a 5 minute instructional flick in 16mm, then developing it, and running it on a telecine to transcribe to VHS, then converting VHS to floppy disc, then floppy to whatever is next, for an uploadable format, is technologically unfeasable.
Sorry.
I've had this truck since I was 23.
Printed directions... What's so difficult?
Old 09-10-2017, 11:58 PM   #18
Boog
laying low
Boog's Avatar
Some guys bolt the hinge to the fender then hook the spring at the back of the hinge and use an old fan belt to pull the spring forward, (extend it) far enough to hook on the front of the hinge. Back before high tech was a thing.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-11-2017, 01:47 AM   #19
'68OrangeSunshine
Sounds familiar. I've also used my service web belt.
Old 09-11-2017, 05:08 PM   #20
davepl
davepl's Avatar
Sorry.
Adapt or perish!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-11-2017, 09:36 PM   #21
bill3rail
bill3rail's Avatar
Sorry.
But video is so much more fun sometimes. Redneck videos are the greatest!
Old 07-20-2019, 08:23 PM   #22
External
External's Avatar
Thank you all Again for your posts.
Web sling and my little weight pulled it off and new ones back on.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 07-20-2019, 10:36 PM   #23
Lunnb
I just use a piece of rope about 4’ long . Hook the spring on the hinge ,double up the rope , run it thru the other end of the spring , pull it back with one hand and slip the hook in the slot on the inner fender bracket. Easy peezy
Lunnb is offline   Reply With Quote
Old 07-20-2019, 11:29 PM   #24
Astro-Balls
Astro-Balls's Avatar
It really doesn't take that much pull to reload a hood spring, I use an old seat belt with the chrome male end with the hole in it to pull the spring.
just like this..
https://www.youtube.com/watch?v=bpspWtE26Iw
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-21-2019, 12:40 AM   #25
71CHEVYSHORTBED402
just like this..
Don't get easier than that.
Tony
