Old 10-07-2017, 10:26 PM   #1
abohler1
abohler1's Avatar
Pinion marks disappeared
So I made all of the proper pinion marks for a seal replacement with a paint pen. Now that I'm putting it back together I'm not confident the marks held up. Many threads appear not to have marks any longer. Am I screwed? If I'm close should I be good? The nut still has the marks and so does the top of the shaft, but just not sure how many threads to take the nut. Can I line up the lines and torque it to factory spec? Thanks for the help.
abohler1 is offline   Reply With Quote
Old 10-07-2017, 10:40 PM   #2
Captainfab
60-66 Nut
Re: Pinion marks disappeared
I do not understand what lines or marks you are talking about?
Old 10-07-2017, 10:57 PM   #3
abohler1
abohler1's Avatar
I marked the pinion nut, in relation to the yoke. And marked the nut along with the output shaft. And accounted for how many threads the nut was on the output shaft before removing to replace pinion seal. But the marks on the output shaft that showed where the nut needed to be, seem to have mostly rubbed off as the nut was removed.
Old 10-09-2017, 04:37 PM   #4
abohler1
abohler1's Avatar
So, I have a GM handbook, and it shows the steps without mentioning preload, or removing axels to take the pinion nut and torque to 270 lb ft. I am wondering if this is my best bet as now I cannot confirm the proper placement of the nut from original markings. Thoughts?
Additional Note: If the crush sleeve was originally set to the proper spec, I would assume torquing to the original spec would work.
Old 10-09-2017, 06:33 PM   #5
sprint_9
sprint_9's Avatar
Are you trying to reuse the old crush sleeve? Thats kind of the way this reads. If that is the case then dont do that, they are a one time use.
sprint_9 is offline   Reply With Quote
Old 10-09-2017, 06:40 PM   #6
kwmech
Stop making all the cross posting. What diff is this
Old 10-11-2017, 03:29 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
KW's right, kinda need to know which rear end we're talkin about?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-11-2017, 03:56 PM   #8
abohler1
abohler1's Avatar
12 bolt
Old 10-11-2017, 05:53 PM   #9
Ironangel
Ironangel's Avatar
Did you get a new crush sleeve? The crush sleeve holds a preload on the bearings by collapsing a pre-bent shoulder on the sleeve. So anytime you relieve that preload your supposed to replace that sleeve, that's why you have to re-torque the pinion nut to such a high value. Now with that said, if you re-install the old sleeve like many guys do, you'll tighten that nut until there is no end play in the pinion shaft and give it another half of a hex or 1/12th of a turn. Make sure you use red Loctite on the nut. (I suggest making a holding plate for the yoke and use a cheater pipe to hold it. Use a cheater pipe on a good 1/2" or better yet 3/4" break-over bar to crush the new sleeve to zero endplay and your good.)
"Two Seventy Two's"
02 3/4 ton Express
Old 10-11-2017, 06:31 PM   #10
Bigdav160
Bigdav160's Avatar
QFT.
This has been answered by experts in another thread. No, just removing the yoke does not require a new crush sleeve.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-11-2017, 07:58 PM   #11
abohler1
abohler1's Avatar
I didn't get a new crush sleeve. I put everything together, and lined up the paint marks on the nut. Hopefully the amount of threads was correct. I did try to eliminate the play. I cannot pull the yoke in or out at all in a straight line from the rear, but when I turn the yoke clockwise it jiggles a bit. I assume that is still supposed to happen and would be the lash. I'm just hoping i didn't leave too much play. The good news is, everything that is marked lines up so i would just add one full turn of the nut. I guess under torquing is always better than over torquing.
Old 10-11-2017, 08:24 PM   #12
Bigdav160
Bigdav160's Avatar
No. Under-torquing could lead to ring and pinion damage.
Over-torquing leads to early bearing wear/failure.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 10-11-2017, 09:55 PM   #13
YoungPup1977
I take it you have driven the vehicle already.....any leaks ? any noises ?
How was the seal surface of the pinion yoke where the seal rides ?
YoungPup1977 is offline   Reply With Quote
Old 10-11-2017, 11:23 PM   #14
Captainfab
60-66 Nut
This is what I would suggest
Old 10-13-2017, 06:29 PM   #15
abohler1
abohler1's Avatar
I took it out today. Everything ran great. No more seal leaks. I think since the nut and pinion still had paint on them, that may have been my saving Grace. I tightened the nut down until no play, then lined up all the paint marks with another few small turns. Seems to be all good. Thanks for everyone's help on this thread.
differential, pinion, rear end, seal, torque
