Old 03-22-2013, 06:19 PM   #1
jorgensensc
jorgensensc's Avatar
Has anyone modified thier core support for donor radiator?
I picked up an extra core support to try it out. I got the donor '08 escalade radiator and fan setup. Seems like if I can modify the core support to make it fit right then I save the headache ( and added expense) of radiator hoses, steam line, tranny line mods. Would make replacement parts easier i think? Has anyone taken this approach?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-22-2013, 11:34 PM   #2
solidaxel
solidaxel's Avatar
Re: Has anyone modified thier core support for donor radiator?
Subed.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-23-2013, 05:24 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
Someone used an oversized Dodge radiator and intercooler for a diesel swap but I havent seen the what you're talking about...I think they actually swapped the frame too... I was looking at using the fan from a similar truck.. the dimensions were off.. I think the radiator is both wider and taller....
Rich
1972 K5 Blazer CST Click HERE
Old 03-23-2013, 12:22 PM   #4
jorgensensc
It is definitely wider and taller. I think if I put round holes for the bottom radiator supports I can mount it like the factory mounted it in the newer vehicles. The width will be an issue, but I think I can make it work. I'm thinking that I can move the 'wings' on the core support for the stock radiator out a little bit. Instead of having the radiator be at an angle like stock on the '72, I think I can have it mount straight upright in the core support by slightly trimming the backside of the top Rail of the core support. I would also need to enlarge the opening from the front where the air hits the radiator. I guess we will just have to see.
Old 03-24-2013, 11:25 PM   #5
Robznob11
Robznob11's Avatar
Im running a 02 vette radiator with a set of 02 camaro fans. Just the right hight but narrower i had to trim very little off the top inner lip of the core support. Drilled two holes like you said. Then used two pices of aluminum strap bent with a 90 and drilled holes to go over the top pegs and secure it. The camaro fans need just a little trim to fit the vette radiator. But look like they are made for it. I got the radiator off ebay for 100$ it has oil and tranny cooler built in. Fans cost me 25 bucks from a guy on craigslist parting a v6 car. I used a resivore from a doner caviler
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-08-2017, 02:43 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Any progress?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-08-2017, 05:16 PM   #7
jorgensensc
Ha!
I forgot all about this thread. Yes I had great success. I have 40k miles on the engine swap at this point. I used the stock radiator and fans. I had to do some trimming on the core support, but nothing that takes away from the integrity of the support. I had a cover made out of sheet metal for the top to cover the gap and hold the radiator in place worked out really nice. Hoses are all good.
Old 10-08-2017, 05:28 PM   #8
LostMy65
LostMy65's Avatar
Thanks for the update.
Old 10-09-2017, 12:09 AM   #9
mcmlxix
mcmlxix's Avatar
Any pictures or link to a thread that already has some?
Rich
Old 10-09-2017, 03:10 PM   #10
Rich84
Rich84's Avatar
I used an Escalade radiator also..Like they said, just drilled to holes in the bottom of the core support for the mounts. I used some angle to make a mount
and covered it with a piece of 18ga steel.
Rich84 is offline   Reply With Quote
Old 10-10-2017, 03:29 PM   #11
Willie Makeit
Willie Makeit's Avatar
I used a stock 4 core radiator. No mods needed.
Willie Makeit is online now   Reply With Quote
Old 10-22-2017, 11:13 PM   #12
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
V502, he did a escalade radiator swap on his build.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-23-2017, 12:11 AM   #13
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Same here for my 5.7. I don't get why this is such an issue. Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
