10-19-2017, 06:15 PM | #1 |
PA6 Optional Wheel ?
Recently came across this wheel and am not very familiar with it at all. I do "think" it is the square body factory "Sport Wheel" option PA6 very much like the after market wagon wheels. It is a 5 on 5 lug, 15x8, 4 3/16'' back space. 8 tri-angle shaped openings that have a in ward curved edge. Has threaded holes for a bolt on cap. Stamped on the inside of the wheel is "6 14 77" JJ 51038 MI over numeral 1? Shows white under the faded black or off gray paint. Can some one confirm for me it is the PA6 Sport Wheel. Had it spun on balance machine and ran good, will mount a tire and balance with no problem. Needs a scrub, blast and re-paint to original white color.
Being 5 lug won't fit my '71 4x4 6 lugger. Fair price for it would be ?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 10-22-2017 at 08:50 AM. Reason: Found out the cap bolts from the front. |
10-26-2017, 03:09 PM | #2 |
Re: PA6 Optional Wheel ?
Looks like you have the wrong make of wheel (Ford)
10-26-2017, 07:12 PM | #3 |
Well seeing as I pulled the wheel off a 72 Chevy 1/2 ton 2wd pickup don't think it will fit on a Ford, Ford being 5 on 5 1/2 stud pattern and Chevrolet is 5 on 5 stud pattern. Back in late 70s and earlly 80s everybody and his dog were making a "wagon wheel" type rim to include the big three truck mfg's. After some use of the search function l found it is a GM Sport Wheel PA6 option usedon both Chevrolet Sport Truck and GMC Sport Coupe trucks. The triangle have a stamped rolled inward lip and are marked JJ on the inside of the rim. Check the post in yhe 73-87 parts forum.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
10-26-2017, 07:22 PM | #4 |
